Old 07-05-2017, 07:55 PM   #1
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
New Perrin exhaust - lost torque
I just installed a Perrin 2.5" resonated cat back. I've been driving it around a week or so and I've noticed my low end torque is gone. It doesn't zip off the line anymore. It smooths out the power band nicely and sounds a bit better, but there is definitely a loss of low end torque.
I see I have two choices: 1) rinstall the OEM pipes. 2) add another upgrade to gain it back.
If I go number 2, which power mod will be the most economical to get the job done. I just want to keep the higher rpm gains and just give. Ack the low end torque I lost.
Last Lemming Alive is offline   Reply With Quote
Old 07-05-2017, 07:58 PM   #2
OND
OND's Avatar
Drives: 2023 BRZ
You could get your butt dyno calibrated
OND is offline   Reply With Quote
Old 07-05-2017, 07:59 PM   #3
moliver
Drives: FR-s
Or a header and a tune for some real gains...oh and E85.
moliver is offline   Reply With Quote
Old 07-05-2017, 08:02 PM   #4
Last Lemming Alive
I've been honing this butt dyno for 46 years - it's a finely tuned machine!
Old 07-05-2017, 08:03 PM   #5
Last Lemming Alive
A header and tune would do it. It I feel the cost is too sever.
Old 07-05-2017, 08:05 PM   #6
moliver
Drives: FR-s
sell the exhaust and get flex fuel adapter thingy.
Old 07-05-2017, 08:05 PM   #7
Last Lemming Alive
I'd prefer not to do a tune. Only because we have a-holes for a dealer here and they would just love to void my whole engine warranty.
Old 07-05-2017, 08:27 PM   #8
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
How do you lose power from a simple catback exhaust, wouldn't you gain even the slightest HP, not lose? Does this apply to all aftermarket exhausts?
dinfern22 is offline   Reply With Quote
Old 07-05-2017, 08:34 PM   #9
Last Lemming Alive
In my experience on a NA engine when you typically gain on the top end you sacrafice on the low end and vice versa. This isn't iron clad of course there are exceptions. I thought this might be one when I looked at the dyno on perrins website. It showed no loss of torque at low rpm, but to me the loss is evident.
As far as how you loose low end power, if you just bolt on a more free flowing exhaust you will gain top end, but the reduction in back pressure will typically loose you low end torque. A tune would most like help with reducing the loss I imagine.
HP is meaningless for the most part. For a street car it's all about torque.
Old 07-05-2017, 08:41 PM   #10
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
My Perrin catback 2.5 arrives in a few days, I'll keep an eye out for any loss of low end torque and report back if I see the same result.
DandoX is offline   Reply With Quote
Old 07-05-2017, 08:44 PM   #11
Last Lemming Alive
Thanks. I would be very interested.
Old 07-05-2017, 08:48 PM   #12
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
This is interesting because i believe the 2.5" Perrin is the same as Stock (correct me if i'm wrong). I noticed the same thing but i have a 3" exhaust installed because i was boosted for a bit. I was thinking about either going back to stock to be a bit more sleeper (i have UEL headers) or going with a 2.5" exhaust for better back preassure
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 07-05-2017, 08:52 PM   #13
Last Lemming Alive
I think it is the same 2.5" diameter pipe, however I'm not sure if the internal structure of the mufflers are the same. If they were there would be no power increase, so this leads me to think they are internally different.
I'm going to bet if you went back from 3 inch to 2 1/2 inch you would feel an increase of torque just because of that alone.
Old 07-05-2017, 08:56 PM   #14
extrashaky
Drives: 2014 BRZ Limited
I wouldn't believe it without actual dyno numbers. A change in sound can do a lot of weird things to how you perceive a car's performance. Sometimes it "feels" faster when it really isn't. Yours probably sounds like it should come off the line faster than your visual cues tell you.
FS: Perrin 3" Intake, Torque Solution engine mounts jonesy Engine, Exhaust, Bolt-Ons 4 01-10-2017 04:03 PM
FS: Perrin 3in Catback Exhaust, Perrin 3in Front Pipe, Perrin Overpipe SOLD johnb831 Engine, Exhaust, Bolt-Ons 13 05-21-2015 05:27 PM
FS: Short Antennas: Craven Speed, Perrin and Torque Solutions BRZNutt Exterior Parts (Aero, Lighting, Etc.) 6 03-12-2014 03:42 PM
Exhaust torque specs Prowl647 Engine, Exhaust, Transmission 0 08-13-2013 12:57 PM
Does Perrin catback exhaust LOSE torque? wbsrazzle Engine, Exhaust, Transmission 23 04-30-2013 08:32 PM
