Old 02-14-2017, 01:17 PM   #29
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Just went from PSS B14 Bilsteins to ST coilovers yesterday.
I find the ST ride quality to be quite soft, almost floaty. The Bilstein B14 coilovers definitely rode firmer but it has a very well damped firm feeling. The best way to describe it was it feels like the engineers at Bilstein really took their time to dial in the setup for our cars, it feels like it should come this way from the factory. Firm yet comfortable, feels really stable!
The build quality and attention to detail on the Bilsteins are better also, for example the bracket that holds the speed sensor line clips fit perfectly. On the ST coilovers the top hole is drilled too wide so it feels like the clip is loose and about to fall out. Also the top of the shock stud on the ST coilovers extends too high above the top hats, you won't be able to reuse the rubber dust covers, by leaving them off your top hat bearings are exposed to the elements and dirt and grime can get in. No issues with the Bilsteins, they fit perfectly like OEM.
I would have kept the Bilsteins but unfortunately they use a wider spring similar to stock up front so with wide 9.5" tires and a 40 offset, it gets really close to rubbing. I'm planning to run more camber up front so I'm pretty sure it will make contact if I add more aggressive front camber.
Dan37BRZ is offline   Reply With Quote
Old 02-14-2017, 01:32 PM   #30
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
How much more camber were you planning on adding?
Roneezy is offline   Reply With Quote
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 09:33 AM
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 01:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 09:02 AM
Stock Suspension comfortable? dannythetran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-10-2015 08:17 AM
Lowering the car and a comfortable ride etherealfall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-21-2014 04:03 AM
