#29 |
Off Topic
| The Following 4 Users Say Thank You to gramicci101 For This Useful Post: |
#30 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
#31 |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | KR-S (12-12-2016) |
#32 |
Sporadic Member
| The Following User Says Thank You to KR-S For This Useful Post: | gramicci101 (12-12-2016) |
#33 |
Dismember
Drives: 2013 Red Scion FR-S
For me, if you keep the frame and most of the body, it's still an FR-S. If you tube frame and put lookalike panels over it, I don't think it's an FR-S anymore, even if it has an FA20 inside. An Exocet is not a Miata, but it does use a lot of Miata parts. A Bradley GT is not a VW Bug. It's Bug-based.
| The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | KR-S (12-12-2016), strat61caster (12-12-2016) |
#34 | |
I am no purest but the body shell is the last thing that makes a car a car. It is just what makes it look like an FRS.
#35 | |
not playing cards
Actually your argument immediately made perfect sense but Hitler memes always win.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | gramicci101 (12-12-2016), strat61caster (12-12-2016) |
#36 |
Dismember
Only if it's fast.
| The Following 4 Users Say Thank You to EAGLE5 For This Useful Post: |
#37 | |
Sporadic Member
These are not 86s: |
| The Following User Says Thank You to KR-S For This Useful Post: | EAGLE5 (12-13-2016) |
#38 | |
Huge E85 fan!
Drives: 2016 Scion FRS
| The Following User Says Thank You to guybo For This Useful Post: | Ultramaroon (12-12-2016) |
#39 |
not playing cards
*giggle* Heraclitus
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gramicci101 (12-12-2016) |
#40 |
If you put an RB26 in Mustang GT 5.0, do you still call it a 5 litre?
If you remove the item it takes its namesake from, the namesake is removed. It can still be an FR-S or a BRZ, since those names have nothing to do with the 86mm bore and 86mm stroke, but it can no longer be an, "86". |
#41 | |
Drives: '23 BRZ
Flat-engine architecture giving a lower c.g. is IMO kind of a myth. A lot of the c.g. height advantage is lost because you have to situate the crank centerline higher in order to have clearance for exhaust headers. This means the crank itself, flywheel, and transmission are situated higher than they would be with a V or inline engine. This is apparent in a cutaway view of the FT86 ![]() Also apparent is how far forward the flat engine has to be situated to clear the steering shaft. Flat-4 FR also precludes use of double-wishbones for suspension, so the promise of a low hoodline is somewhat killed by strut suspension in addition to the engine being mounted somewhat high and forward. IMO, a V4 would be the ideal powerplant for an FT86 or MX-5 class sports/sporty car. |
#42 |
Off Topic
If you get a heart transplant are you still the same person afterwards? What about lungs, liver, kidney, cornea, joint replacements, artificial limbs, etc...? At what point are you no longer you?
| The Following User Says Thank You to gramicci101 For This Useful Post: | ToyotaFan84 (01-21-2017) |
| Am I the only one who thinks the 86 emblem looks like a swastika? | zaptorque | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 03-05-2017 02:17 PM |
| She thinks I'm crazy | Firestormdriver | Northwest | 9 | 02-14-2016 09:56 PM |
| Am I the only one that thinks those waiting for 2015.... | snoflewis | BRZ First-Gen (2012+) — General Topics | 91 | 09-05-2013 11:18 PM |
| Who thinks the FR-S looks like a Maserati? | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 07-26-2012 05:39 PM |
| Who else thinks neons can look good? | LexusFman | Other Vehicles & General Automotive Discussions | 19 | 11-07-2011 12:35 AM |
