#29 | |
2022 BRZ Build 2013 FR-S Build |
#30 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | RB-BRZ (11-04-2016) |
#31 |
German Castrol! I used to use that on my STI. A lot of the Subaru guys love it since it's a little thicker like you mentioned.
#32 |
Or 50.
I run M1 0w40, for both street and track. It's one of the last oils in their lineup that's still PAO base stock and UOAs show it's worth well more than the $30/5L (Canadian) I pay at Walmart for it. I don't let EPA required fuel economy number dictate how I protect my motor. Last edited by Tokay444; 11-04-2016 at 09:53 AM. |
| The Following User Says Thank You to Tokay444 For This Useful Post: | RB-BRZ (11-04-2016) |
#33 | |
Mr.Fujitsubo
Drives: 2018 STI
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#34 |
#35 |
Mr.Fujitsubo
Drives: 2018 STI
#36 | |
The specs that an oil meets are more important than the base stocks that are used. These days Mobil 1 uses GTL base stocks in the 0W40. https://bobistheoilguy.com/forums/ub...containing_GTL |
#37 | |
I haven't bought a jug of M1 0W40 that didn't say Eruopean Formula on the label, so none of this GTL stock has been in my engine. I'll be monitoring the UOAs for it, and provided it tests well and maitains the current price point, I'll give it a shot. |
#38 |
Drives: 2019 MX-5 RF
http://www.hendonpub.com/resources/a...etails?id=3965
This is important. I really do not think it is good to use non 0-20. If you track your car, get hardware to increase flow of your oil or increase cooling capacity. |
| The Following User Says Thank You to ~el~jefe~ For This Useful Post: | OND (11-06-2016) |
#39 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
You need to check your oil. Is your oil sheering down below the recommended viscosity during your track day. If it is I would use a thicker oil or another oil of same thickness that does not sheer down. Using a thicker oil for a track day will not likely hit your engine. Running too thick as a DD could cause trouble over time.
#40 |
thicker oil vs larger oil pump and more volume. I dont think people are getting the difference. Pressure itself is only a valid indicator of what is going on if the oil is the same oil in each system. If thick oil, it is simply needing more force to move but it is not getting to the parts it needs to lubricate any faster.
I remember many street racers getting larger oil pumps. I guess it would help if flow rate is increased. |
#41 |
Drives: brz 2017 hksv2
Sprry for upping an old thread
how does Motul Eco-clean 5w30 look to you guys? it s not very thick, and where i live in summer is very warm so i would like to change from 0w20 motul eco lite, also intend to do 1 or 2 light track days my concern is that 5w30 eco clean like other motul oils, is SN compliant (that is good) but not gf5 is it a problem? i always change oil every 7500km and go back to 0w20 or 0w30 in winter |
#42 | |
Drives: Toyota Corolla
Hi everyone! I just want to give my vote on this. I have a similar experience to this. I tried Mobil1, and Eneos. Yet my FA20 engine reacts differently in Motul. Even the engine noise vanished since I changed to Motul. Am using Motul Xcess 5W-40 in a hot climate. On the other hand, is the amount of oil important to maintain a good oil pressure? Am hearing some suggestion that i should overfill my engine oil capacity of atleast half a liter. Is this correct? Hoping to hear from you guys. |
| Tags |
| driving, maintenance, oil, performance |
| High Performance Clutch | FR-Shred | Engine, Exhaust, Transmission | 6 | 11-09-2015 05:32 PM |
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 10:23 PM |
| Does anyone else notice a high pitched squeak while driving ? | Frsultramarine15 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 11-25-2014 06:47 AM |
| Effects of driving at high revs daily | fidelacchius | BRZ First-Gen (2012+) — General Topics | 30 | 08-22-2014 10:35 PM |
