Old 11-02-2016, 08:46 AM   #29
DarkSunrise
DarkSunrise's Avatar
Originally Posted by solidONE View Post
During the summer months were ambient temps in some places can be consistently in the triple digits or average close to and above 40*c for the metric folks, it might be a good idea to run a thicker oil if you tend to drive hard even if you don't beat on it at a track, I'd say.
Yeah I think the manual specifies a slightly higher grade oil can be used in extremely hot regions or for extended high RPM usage (or something like that). Just a balance between maintaining proper oil pressure on the hottest days vs. cold start viscosity and bearing clearances on the coldest days. I use a 5w30 synthetic during the summer track season and 0w20 synthetic during the winter.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
RB-BRZ (11-02-2016), solidONE (11-03-2016)
Old 11-03-2016, 09:41 AM   #30
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Same here, but I like to swap between 0w-20 oils and the Castrol 0w-30. Supposedly the Castrol runs a bit thicker than most 0w-30's and 5w-30's. Plus Pep boys runs a special on castrol synthetic oils every other month.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
RB-BRZ (11-04-2016)
Old 11-03-2016, 10:06 AM   #31
DarkSunrise
German Castrol! I used to use that on my STI. A lot of the Subaru guys love it since it's a little thicker like you mentioned.
2022 BRZ Build
2013 FR-S Build
Old 11-03-2016, 10:32 AM   #32
Tokay444
Originally Posted by Mr.Impreza View Post
The best Oil.
Eneos Sustina 0W20
Or 50.
I run M1 0w40, for both street and track. It's one of the last oils in their lineup that's still PAO base stock and UOAs show it's worth well more than the $30/5L (Canadian) I pay at Walmart for it.
I don't let EPA required fuel economy number dictate how I protect my motor.
The Following User Says Thank You to Tokay444 For This Useful Post:
RB-BRZ (11-04-2016)
Old 11-03-2016, 11:24 AM   #33
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Originally Posted by Tokay444 View Post
Or 50.
I run M1 0w40, for both street and track. It's one of the last oils in their lineup that's still PAO base stock and UOAs show its worth well more than the $30/5L (Canadian) I pay at Walmart for it.
They sell Eneos at Walmart? Do they also sell Sustina 0w20?
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 11-03-2016, 11:27 AM   #34
Tokay444
huh?
Old 11-03-2016, 11:29 AM   #35
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
huh?
Never mind, just noticed you wrote M1
Old 11-05-2016, 01:08 PM   #36
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Or 50.
The specs that an oil meets are more important than the base stocks that are used. These days Mobil 1 uses GTL base stocks in the 0W40.
https://bobistheoilguy.com/forums/ub...containing_GTL
bluesubie is offline   Reply With Quote
Old 11-06-2016, 10:59 AM   #37
Tokay444
Interesting process.
I haven't bought a jug of M1 0W40 that didn't say Eruopean Formula on the label, so none of this GTL stock has been in my engine. I'll be monitoring the UOAs for it, and provided it tests well and maitains the current price point, I'll give it a shot.
Old 11-06-2016, 11:46 AM   #38
~el~jefe~
Drives: 2019 MX-5 RF
http://www.hendonpub.com/resources/a...etails?id=3965
This is important. I really do not think it is good to use non 0-20. If you track your car, get hardware to increase flow of your oil or increase cooling capacity.
~el~jefe~ is offline   Reply With Quote
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
OND (11-06-2016)
Old 11-06-2016, 10:07 PM   #39
Ernest72
You need to check your oil. Is your oil sheering down below the recommended viscosity during your track day. If it is I would use a thicker oil or another oil of same thickness that does not sheer down. Using a thicker oil for a track day will not likely hit your engine. Running too thick as a DD could cause trouble over time.
Old 11-22-2016, 04:56 PM   #40
~el~jefe~
thicker oil vs larger oil pump and more volume. I dont think people are getting the difference. Pressure itself is only a valid indicator of what is going on if the oil is the same oil in each system. If thick oil, it is simply needing more force to move but it is not getting to the parts it needs to lubricate any faster.
I remember many street racers getting larger oil pumps. I guess it would help if flow rate is increased.
Old 04-10-2018, 10:22 AM   #41
tomm.brz
Drives: brz 2017 hksv2
Sprry for upping an old thread
how does Motul Eco-clean 5w30 look to you guys?
it s not very thick, and where i live in summer is very warm so i would like to change from 0w20 motul eco lite, also intend to do 1 or 2 light track days
my concern is that 5w30 eco clean like other motul oils, is SN compliant (that is good) but not gf5
is it a problem?
i always change oil every 7500km and go back to 0w20 or 0w30 in winter
Old 11-27-2023, 05:06 PM   #42
Benedict86
Drives: Toyota Corolla
Originally Posted by tomaszjanczak View Post
Overall quieter, smoother running engine. With Mobil 1, the engine has this rattle sound, that I have concluded is related to the timing chain. Once I fill up with Motul, that noise is completely gone and this is 100% repeatable. I can switch back to Mobil and the noise instantly comes back. I am certain Motul provides better lubrication for this engine. It's not a coincidence. The engine revs smoother with Motul. That is a small difference but the timing chain noise is not. Power wise, I don't feel any major difference between the 2 and have no data to prove anything.
Like I said above, I don't sense any power differences. The differences go way beyond power in my situation. Your MR2 doesn't have an FA20 engine. The same oil can behave differently in different engines and I have no doubts Mobil 1 worked well in your MR2.
Hi everyone! I just want to give my vote on this. I have a similar experience to this. I tried Mobil1, and Eneos. Yet my FA20 engine reacts differently in Motul. Even the engine noise vanished since I changed to Motul. Am using Motul Xcess 5W-40 in a hot climate.
On the other hand, is the amount of oil important to maintain a good oil pressure? Am hearing some suggestion that i should overfill my engine oil capacity of atleast half a liter. Is this correct? Hoping to hear from you guys.
Benedict86 is offline   Reply With Quote
driving, maintenance, oil, performance
High Performance Clutch FR-Shred Engine, Exhaust, Transmission 6 11-09-2015 05:32 PM
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 10:23 PM
Does anyone else notice a high pitched squeak while driving ? Frsultramarine15 Scion FR-S / Toyota 86 GT86 General Forum 23 11-25-2014 06:47 AM
Effects of driving at high revs daily fidelacchius BRZ First-Gen (2012+) — General Topics 30 08-22-2014 10:35 PM
