Old 06-19-2017, 05:28 AM   #29
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
It's at Church; the before dynos are the same as any other FRS/BRZ tuned there, there are hundreds of dynos scattered throughout the forums. A CARB JRSC should put down approximately 245-255whp on ACN91.
Here's the CSG BRZ on HBP (9% more boost), and a A/350 (non-ceramic) on E70.
Not shown: CSG BRZ on HBP and A/350 (non-ceramic) on ACN91 puts down approximately 335whp.
For reference, here's a stock 2105 ACN91 vs A/350 ACN91 vs A/350 E70
and my 2017, stock, on VP101
Mike, currently I have the Edelbrock SC setup on my MY2017. Have you or Delicious Tuning worked on any MY17s utilizing the EBSC and the CS400 yet?
I plan on getting that (due to me not being in 6k-7k range a lot) along with the ACE stainless steel FP then applying the DT.
If you have dyno results for 91/92/93 octane for aforementioned kit, let me know
Sent from my SM-G935T using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 06-19-2017, 02:36 PM   #30
Sure have. A/350 results are almost universally better for SC cars though. Unfortunately most owners ask for their dynos to not be posted, and we have to honor that request.
I make over 200whp on the DT dyno with just the A/350 header alone, no boost
Old 06-20-2017, 09:32 AM   #31
gtengr
Drives: 2017 BRZ
Good info as always. Does the CS400 not retain any low end advantage? I'm looking at the JRSC with hbp and 7k redline after the newness wears off on my BRZ. I DD mine and would prefer the low end benefits if they still exist though.
gtengr is offline   Reply With Quote
Old 06-20-2017, 12:14 PM   #32
You want the Edelbrock SC if you want low end power, not the Jackson Racing SC. The SC will amplify the header gains, and vice versa, with a good tune. If low end is what you want, get the Edelbrock + CS400.
Old 06-20-2017, 03:41 PM   #33
Moue
Drives: 2014 Lightning Red Subaru BRZ
Originally Posted by Calum View Post
I haven't dyno'd it, and my only supporting mods are a drop in air filter (Cosworth) and the DT tune. The rest of the exhaust is 100% stock.
I can tell you that this setup has much more torque than I was expecting. It has usable torque even down at 2000 rpm. It's not unusual for me to be putting along in traffic at about 65 km/h in 6th gear. From there, the power just builds like a freight train (well, ok, an NA freight train) all the way to red line. You will not be disappointing.
Oh lawd you got me excited. Can't wait to get mine
Moue is offline   Reply With Quote
Old 06-20-2017, 04:47 PM   #34
gtengr
Drives: 2017 BRZ
The car is ok imo in the sub-3500 rpm range as it is stock, I would just prefer to augment that range if it was a simple trade off in the header selection. Not looking for big low-rpm boost.
Old 06-20-2017, 08:05 PM   #35
Can you define "that range"?
Old 06-20-2017, 08:05 PM   #36
There's a few on the shelf at CSG looking for a home
Old 06-21-2017, 06:49 PM   #37
gtengr
Drives: 2017 BRZ
~1500 to 3500 rpm
Old 06-21-2017, 09:27 PM   #38
~1500 to 3500 rpm
Yup you want CS400.
Old 06-21-2017, 10:41 PM   #39
icybrzzz
Drives: 2015 Scion frz
Yup you want CS400.
I want to keep my car NA... Ace 350 type A vs anaconda 42.7mm?
No plans for boost in the future. Looking to get the 2017 manifold with a bigger throttle body too.
icybrzzz is offline   Reply With Quote
Old 06-22-2017, 02:24 AM   #40
A350. Anaconda is for race applications only.
Old 06-22-2017, 10:32 AM   #41
Moue
I've ordered one from Ace's Canadian distributors already. Patiently waiting.
Old 06-22-2017, 07:24 PM   #42
Hags86
Drives: Toyota GTS 86
Sorry to re-post from another thread but I hoping to get an answer and move forward and order some headers.
Being RHD I can go for the 250 or the 400. Other than 'the 250 is better at high revs and less so at lower revs' versus 'the 400 is better at lower revs and less so at high revs' I can't find any qualitative assessment of the two. Am I sacrificing 10% power at 4000rpm to get 2% better at 7000rpm on the 250? If that is the case I'd probably go with the 400.
If anyone can help please shout out otherwise I'll have to flip a coin!
The main plan is to optimise for track days and hopefully get a good bump for DD and flatten the torque curve. I think the 400 is better for linear torque but at what expense at the top end?
Hags86 is offline   Reply With Quote
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
Shiv dyno day 2 in lewisville, OFT users custom dyno tunes malubawla Southwest 14 11-21-2015 01:53 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
