Old 08-19-2016, 07:30 AM   #29
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
That price for coolant is very high, the Toyota version is priced that way. Super blue from the Subi dealership on 50 is less than $25.
Your heating system is part of the overall coolant system as well and if you run low enough on coolant it will blow cold instead of hot. If your radiator is full and the engine temp is now fine but the heater doesn't work then you need to bleed the line for the heater core. The bleed valve is up near the firewall.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 08-19-2016, 07:34 AM   #30
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by itsjustdavep View Post
Car is at 40k. And I was second owner
I believe there is a 3 yr warranty on most components, transferable.
Old 08-19-2016, 07:38 AM   #31
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Eeeee. I'm likely on the cusp then. It's a 13.
I'm bringing it to the dealer now since I have to work and they'll courtesy shuttle me the mile and a half down the road.
Just gonna tell em drain and replace coolant check thermo/water pump/rad. Gonna have em change ze oil while they got it up too.
First time in the two n a half years I've had this car that I've had an issue :/
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 08-19-2016, 08:08 AM   #32
itsjustdavep
So just flew to work like I normally do laying into 4th on the turnpike to pass and scoot through. Trying to get temps up. Never passed 190.
What Inthe blue hell is going on
Old 08-19-2016, 01:43 PM   #33
itsjustdavep
Alright. So. I see the dealer go to pressure test the radiator and it basically exploded. YAY. problem solved.
Thanks for all the wisdom guys, I appreciate it greatly.
Old 08-19-2016, 01:48 PM   #34
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
How much is it going to cost you?
Old 08-19-2016, 04:05 PM   #35
itsjustdavep
So Toyota of Orlando, God bless em, do a goodwill warranty program.
I brought my car in for a coolant leak July 2015. They didn't think anything was wrong then. So because of that they're going to retro act my warranty since I'm past the 3/36K and cover it.
I've never had a dealer do that. So they're gonna do my fuel system cleaning, brake fluids, oil change, and take care of my radiator issue for 400.
The Following User Says Thank You to itsjustdavep For This Useful Post:
stevesnj (08-20-2016)
Old 08-19-2016, 07:15 PM   #36
ryoma
ryoma's Avatar
so you're still paying money even though they say they will cover it under "warranty"? as I was reading through your post I thought to myself, "oh wow, this is a nice dealership" then at the very end it turned out to be a typical dealership that is taking your money. lol. but as long as you're content with it then everything is fine
Old 08-19-2016, 07:19 PM   #37
itsjustdavep
Well yeah. But they were quoting me double what I'm paying for parts and labor on just the radiator. With them catching me up on routine maintenance (fuel system brake fluid) I'm getting it all done for cheaper. Plus they'll wash the car. Something I haven't done in a while. What I'm paying is pennies so it's not too bad
Old 08-19-2016, 07:36 PM   #38
itsjustdavep
Originally Posted by Norville Rogers View Post
How chubby?
5'6" 220. *drums belly*
Old 08-19-2016, 09:02 PM   #39
Ultramaroon
not playing cards
Ultramaroon's Avatar
fucking chubster
itsjustdavep (08-19-2016)
Old 08-19-2016, 09:06 PM   #40
Ultramaroon
not playing cards
<--------- 6'5" 320
Old 08-20-2016, 11:05 AM   #41
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Ugh stupid dealer taking my money.... I got a nice radiator in the garage. I am less than 3 hours away I woulda made the drive and did all the same stuff for 300.... Can't make no monies around here lololol
tofurun is offline   Reply With Quote
Old 08-23-2016, 04:09 PM   #42
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Basically dealer is charging you $400 for oil change and fluid change. lol
Coolant Temps Running High Dezoris Tracking / Autocross / HPDE / Drifting 43 09-29-2016 11:58 AM
High coolant temp at idle with A/C off extrashaky Issues | Warranty | Recalls / TSB 11 11-11-2014 04:50 PM
Anyone notice this car eats coolant at a high rate? Liquidsnake Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 04-23-2013 04:25 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
ECU pulls timing at high oil temps? brillo Engine, Exhaust, Transmission 24 03-31-2013 09:10 PM
