#29 |
Thanks
Hmm I find my trans actually shifts better under track driving (WOT). And is notchy as fuk on the street. I have Motul in it
#30 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Keep in mind that an adapter plate is not the only thing you'll need even if you find one. The spline count depending on which variant of the T56 you get will be either 27, 30, or 31 (most likely will be 27). The spline count on the FRS is 24. So you'll need to get a different output shaft or find a clutch disk that works with the correct pressure plate and has the correct number of splines.
#31 | |
Dismember
Drives: 2013 Red Scion FR-S
#32 | |
Slow I am, boost I must..
Drives: Whiteout 2013 FRS
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti |
#33 |
Off Topic
@FullBlown was making a V160 conversion kit a few years ago. That might work for you.
http://www.ft86club.com/forums/showthread.php?t=53454 |
#34 |
Drives: Late 2014 Subaru BRZ
Spline count doesn't matter much. Just need to find the same clutch pads as stock but with the new spline count. The real trick isn't the mount either it's the dam new drive shaft. Car can also use a hydraulic throw out bearing to fix weak fork while doing it.
The factory Subaru fluid is great when cold and around town just at top of the RPMs is I guess not great, I guess.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#35 |
Drives: 2013 Asphalt FRS
T5 upgraded!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#36 | |
$560 with universal Chevy truck joints, driveshaft was the nicest thing on that POS when I sold it aside from how cold the AC was. If my corner shop will do it for less than the price of a set of OE tires I think the driveshaft is one of the least of your worries. |
#37 |
Drives: Scion Fr-s fully built engine
| What is the thinnest adapter I can use without having to cut the lug nut? | lupindub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-11-2016 08:32 PM |
| WtB short hub adapter | P_say86 | Want-To-Buy Requests | 0 | 07-18-2015 07:39 PM |
| Adapter help | lookchris | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-09-2013 10:39 AM |
| Worksbell hub adapter!?? | _F-R-S_ | DIY (Do-It-Yourself) Guides | 1 | 12-14-2012 01:27 PM |
