Slow I am, boost I must..
Drives: Whiteout 2013 FRS
T56 to FA20 adapter.
Does anyone out there make an adapter to mate the t56 to the FA20 or any other real trans for that matter? I'm tired of the stock transmission it's a piece of junk
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti |
#2 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Do a MT to auto swap
#3 |
I like shifting
Plus auto=****less shifting
#4 |
Not Bаnned Anymore
#5 |
Drives: Toyota 86
sequential boxes are available
#6 |
#7 |
#8 |
I'm just looking to adapt a good strong trans to my car before boost. R154,t56, that sort of thing. Something fairly affordable but strong
#9 |
#10 |
#11 |
#12 |
TRACKBREAD
How is it a piece of junk? It's an Aisin box based on the same tranny that was universally loved in the S2000. Unless it's very broken this transmission is fantastic.
Change your fluid and try again. -Josh |
#13 | ||
Most of the issues in the manual can be fixed and it can handle the normal boost levels of an sc or turbo at 260-300 whp. I would honestly change fluids, take the clutch spring out if you don't like the clutch feel, and get a short throw to tighten it up if you want it more notchy
#14 | |
Panda Trueno
Drives: No twin now.
It is pretty well documented that this trans can have issues even stock, let alone when you start pushing boost. It isn't a fluid issue. |
| What is the thinnest adapter I can use without having to cut the lug nut? | lupindub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-11-2016 08:32 PM |
| WtB short hub adapter | P_say86 | Want-To-Buy Requests | 0 | 07-18-2015 07:39 PM |
| Adapter help | lookchris | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-09-2013 10:39 AM |
| Worksbell hub adapter!?? | _F-R-S_ | DIY (Do-It-Yourself) Guides | 1 | 12-14-2012 01:27 PM |
