Old 05-10-2016, 02:54 PM   #29
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by dallenj View Post
Thanks for the help. Correct me if I'm wrong, but what I got out of all the help is get the 5858 with a big a/r and launch control and I should be good. But shouldn't I just go with a 6262 they are the same price and if I ever want to make more power the turbo has a lot of room to make more power. Just want the experts opinions on this. Lag doesn't really matter I'll get the trap speed from the spool go big or go home, but I could be completely wrong. I don't have any experience with turbos only cubic inches.
You have to hook the car up along with making the power.. Hooking up and hitting a 10s pass with a 5858 is far easier than a 6262...
I have a 6266 on the street if I roll on the gas I can fog the tires all the way to 4th gear. That's cruising at 2k and rolling on the gas at 4k I'm up in smoke...
I bolted the slicks on it the other day and went for a cruise 3rd gear broke loose mid way. You won't have these problem with a 5858. If your spinning your not winning. A 5858 is much more controllable and way easier to put the power to the ground. Oh and by the way I was on a 7psi wastegate spring...
Ultimately the choice is yours, but if I wanted to do what you want to do I would hands down get a 5858. A 10s pass is no joke.
Now with this being said a 6262 with the smallest housing will be equivalent to a 5858 but you will loose top end choking it down. That's why I would suggest the 5858 you will get the best of both worlds.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-10-2016, 03:30 PM   #30
dallenj
Drives: Grey FR-S
Thanks a lot I'll go with the 5858. What turbine housing should I use to get the best times? I do want to use the 3" v-band discharge should i go for the 64 or 82?
dallenj is offline   Reply With Quote
The Following 2 Users Say Thank You to dallenj For This Useful Post:
FRS Justin (05-10-2016), Kris86 (05-11-2016)
Old 05-10-2016, 03:39 PM   #31
mrk1
Drives: Sterling BRZ Ltd
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
#maverick# (05-10-2016), FRS Justin (05-10-2016), Kris86 (05-11-2016)
Old 05-10-2016, 03:53 PM   #32
dallenj
Drives: Grey FR-S
How do you guys combat the transmission going through gears other than having a spare one lying around? I already have problem with my 4thr gear and I'm only running 300hp
Old 05-10-2016, 03:56 PM   #33
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Theyre cheap enough, Justin and I both have access to a couple each lol. I only just recently broke my first though, which was surprising.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
The Following User Says Thank You to #maverick# For This Useful Post:
Old 05-11-2016, 03:21 PM   #34
Kris86
Kris86's Avatar
Drives: RHD Gt86
Don't mean to hijack the thread but, what the comparison like between the pte5858 vs the gtx3076r?
Like hp ratings, full boost at what rpm etc
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 05-11-2016, 03:27 PM   #35
FRS Justin
They are almost identical, 58-76 trim. Actually the 3076 is a 76.60 and the 5858 is a 76 trim
710whp
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
Kris86 (05-11-2016), NyC Zn6 (05-11-2016)
Old 05-11-2016, 03:31 PM   #36
Kris86
Kris86's Avatar
Drives: RHD Gt86
Thanks for ur reply,
Which turbo do you think can take more harassment, stronger
The Following User Says Thank You to Kris86 For This Useful Post:
FRS Justin (05-12-2016)
Old 05-12-2016, 09:24 AM   #37
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Both are around the 620-640 hp mark. I know the gtx3076r uses water lines. Not sure about the 5858.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Kris86 (05-12-2016)
Old 05-12-2016, 10:45 AM   #38
FRS Justin
The 5858 has ceramic ball bearing and is oil cooled. Back in the day precision turbos had a high failure rate but they got their shit together and now are making awesome turbos. Garrett has been the standard forever... Cant go wrong with either the 5858 or the gtx3076r...
710whp
Old 05-12-2016, 06:55 PM   #39
#maverick#
#maverick#'s Avatar
PTE makes a little more power top end from what ive seen and gtx turbos make better power mid range for whatever reason
Old 05-13-2016, 02:40 PM   #40
dallenj
Drives: Grey FR-S
I'm looking to get the 5858 v-band inlet and outlet with the .82 a/r, but do you know if v-band inlet will be better or would sticking with a T3 inlet be better. Also do you know the inlet size of the v-band inlet i have looked everywhere for the info with no luck.Thanks for all the help.
The Following User Says Thank You to dallenj For This Useful Post:
#maverick# (05-13-2016)
Old 05-13-2016, 03:20 PM   #41
FRS Justin
@Maverick is your best source for this info or @mrk1
I believe Maverick ran a 5858 vband
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
Old 05-13-2016, 05:00 PM   #42
#maverick#
#maverick#'s Avatar
The Vband inlet is the same size as a t3 inlet. I ran the vband and loved it. Plus a vband is much lighter than a bulky ass t3 flange
Perrin Crank Pulley, Precision Turbo PW39 Wastegate - SOLD Amir Ghadiri Engine, Exhaust, Bolt-Ons 7 02-07-2016 09:59 PM
SOLD Precision Turbo tumbla.jr Engine, Exhaust, Bolt-Ons 2 05-21-2015 11:15 PM
Invida n1 exhaust motiv overpipe injen intake precision 4854 turbo for sale Anthony7515 Engine, Exhaust, Bolt-Ons 7 09-16-2014 11:28 PM
9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ SUB-ZERO Forced Induction 44 07-09-2014 10:44 PM
