Old 05-08-2016, 03:15 PM   #15
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by dallenj View Post
My goal is inbetween about 450 to 500hp. That should get in the 10 with a proper suspension set up. I thought the 5931 was a good choice, but I was listening to someone with experience with a turbo 86 that said the 6262 was the way to go.
Go look at the dyno page to find your motor setup you will see how easy it is to make 450 to 500
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-08-2016, 03:15 PM   #16
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Yes, 5858 is a great deal and I'm a garrett fan boy that likes to pay tomuch.
The pte5858 with BB upgrade is a direct competitor to the gtx3076r. Both have similar hp, 4inch intake, 2.5 exhaust.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-08-2016, 03:15 PM   #17
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by FRS Justin View Post
Don't listen to your friend, hes got you way off course. If 10s is all you want run a 5858 And you don't need nitrous...Good God I hope you have deep pockets if you try all his Nitrous and 6262
Hell for his 450-500 goal I'd say go with the 5558. Bit smaller, bit less lag, but everything counts when you're actually trying to run fast 1/4 times.
Not even going to comment further on this. Can't help everyone, he'll learn on his own I guess.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 05-08-2016, 03:35 PM   #18
dallenj
Drives: Grey FR-S
I already have the nitrous on my car now it's just not enough to get me where I want. I already have it so I might as well use it. I'm fibbing up my own kit and will be cheaper than all the turbo kits built by the performance companies. But I am copying some of there ideas for my kit.
dallenj is offline   Reply With Quote
Old 05-09-2016, 08:48 PM   #19
mrk1
Drives: Sterling BRZ Ltd
Nice not having to pay for R&D, just copy.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-09-2016, 09:06 PM   #20
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Originally Posted by BRZoomTX View Post
Why such a big housing on a T3 manifold? You're asking for more lag for no reason.
Precision turbos don't even really get going until 20+ psi. You'll spool it slower, make less boost at a specific RPM level, and overall make less power throughout the powerband where it counts early in the run.
Here is a hint. In the 1/4, the race is over before you even hit the 1/8th mark. You need to focus on good 60ft times and keeping your car in the powerband as much as possible before the 1/8th. Going too big of a turbo with too big of an A/R housing size is going to kill your times, even if you may make more peak power than the 86 next to you. Take some time and review the dyno thread, see where these cars actually make power on 55-67mm turbos, and go from there. You're not going to run good times making all your power past 6k RPM.
Thats not that big, I ran a .82 a/r housing on a t3 vband with no issues and good spool on a 5858 Ball Bearing
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 05-09-2016, 09:08 PM   #21
#maverick#
#maverick#'s Avatar
Just so you know my anti lag system is a shot of nitrous to boost my 60' times as soon as my turbo is spooled the nitrous will shut off
You seriously dont need nitrous, get yourself a 5858 bb and good tune, you should be building 5 - 6 psi on ecutek launch control which is more than enough to get going.
Old 05-09-2016, 10:54 PM   #22
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
In the drag racing world, lag means nothing to us and power/mph means everything lol.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 05-10-2016, 01:06 AM   #23
FRS Justin
Mostly MPH lol
710whp
Old 05-10-2016, 01:10 AM   #24
FRS Justin
There you have it from 3 of the most hard core drag racers using a FA20, @Maverick, @spitfire481, @FRS Justin and, @BRZoomTX along with @mrk1 for the hottest TRUE street setups
710whp
Old 05-10-2016, 11:46 AM   #25
dallenj
Drives: Grey FR-S
Thanks for the help. Correct me if I'm wrong, but what I got out of all the help is get the 5858 with a big a/r and launch control and I should be good. But shouldn't I just go with a 6262 they are the same price and if I ever want to make more power the turbo has a lot of room to make more power. Just want the experts opinions on this. Lag doesn't really matter I'll get the trap speed from the spool go big or go home, but I could be completely wrong. I don't have any experience with turbos only cubic inches.
Old 05-10-2016, 12:41 PM   #26
mrk1
My philosophy has always been run the smallest turbo that will do the job. Sure spool isn't the biggest concern with drag but you still want a fat mid range, going to big may give you the peak number you want but your mid range will suffer.
Far to often guys build there car for some "down the road" scenario that never comes together. I have been developing my car on a turbo that most said was to small, gets no bar stool attention. However anyone who has been involved has just been blown away at what has come out of it.
The Build Thread
Old 05-10-2016, 12:42 PM   #27
GsxrMe
GsxrMe's Avatar
This argument over the 5858 vs 6262 seems to be the same as the gtx3076r vs gtx3576r fight.
2014 Subaru BRZ
Old 05-10-2016, 12:50 PM   #28
#maverick#
#maverick#'s Avatar
Hell if you want room to grow a 6062 shouldnt be much laggier than a 5858. But unless you want to go stupid like Justin & I a 5858 is more than enough turbo
Perrin Crank Pulley, Precision Turbo PW39 Wastegate - SOLD Amir Ghadiri Engine, Exhaust, Bolt-Ons 7 02-07-2016 08:59 PM
SOLD Precision Turbo tumbla.jr Engine, Exhaust, Bolt-Ons 2 05-21-2015 10:15 PM
Invida n1 exhaust motiv overpipe injen intake precision 4854 turbo for sale Anthony7515 Engine, Exhaust, Bolt-Ons 7 09-16-2014 10:28 PM
9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ SUB-ZERO Forced Induction 44 07-09-2014 09:44 PM
