#29 | |
Drives: 2013 Asphalt FRS
I have a 6266 on the street if I roll on the gas I can fog the tires all the way to 4th gear. That's cruising at 2k and rolling on the gas at 4k I'm up in smoke... I bolted the slicks on it the other day and went for a cruise 3rd gear broke loose mid way. You won't have these problem with a 5858. If your spinning your not winning. A 5858 is much more controllable and way easier to put the power to the ground. Oh and by the way I was on a 7psi wastegate spring... Ultimately the choice is yours, but if I wanted to do what you want to do I would hands down get a 5858. A 10s pass is no joke. Now with this being said a 6262 with the smallest housing will be equivalent to a 5858 but you will loose top end choking it down. That's why I would suggest the 5858 you will get the best of both worlds.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#30 | |
Drives: Grey FR-S
#31 |
Drives: Sterling BRZ Ltd
#32 |
Drives: Grey FR-S
How do you guys combat the transmission going through gears other than having a spare one lying around? I already have problem with my 4thr gear and I'm only running 300hp
#33 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Theyre cheap enough, Justin and I both have access to a couple each lol. I only just recently broke my first though, which was surprising.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#34 |
Drives: RHD Gt86
Don't mean to hijack the thread but, what the comparison like between the pte5858 vs the gtx3076r?
Like hp ratings, full boost at what rpm etc
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#35 |
They are almost identical, 58-76 trim. Actually the 3076 is a 76.60 and the 5858 is a 76 trim
#36 | |
Drives: RHD Gt86
Which turbo do you think can take more harassment, stronger
#37 |
Drives: Late 2014 Subaru BRZ
Both are around the 620-640 hp mark. I know the gtx3076r uses water lines. Not sure about the 5858.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#38 |
The 5858 has ceramic ball bearing and is oil cooled. Back in the day precision turbos had a high failure rate but they got their shit together and now are making awesome turbos. Garrett has been the standard forever... Cant go wrong with either the 5858 or the gtx3076r...
#39 |
PTE makes a little more power top end from what ive seen and gtx turbos make better power mid range for whatever reason
#40 | |
Drives: Grey FR-S
I'm looking to get the 5858 v-band inlet and outlet with the .82 a/r, but do you know if v-band inlet will be better or would sticking with a T3 inlet be better. Also do you know the inlet size of the v-band inlet i have looked everywhere for the info with no luck.Thanks for all the help. |
#41 | |
I believe Maverick ran a 5858 vband
#42 | |
| Perrin Crank Pulley, Precision Turbo PW39 Wastegate - SOLD | Amir Ghadiri | Engine, Exhaust, Bolt-Ons | 7 | 02-07-2016 08:59 PM |
| SOLD Precision Turbo | tumbla.jr | Engine, Exhaust, Bolt-Ons | 2 | 05-21-2015 10:15 PM |
| Invida n1 exhaust motiv overpipe injen intake precision 4854 turbo for sale | Anthony7515 | Engine, Exhaust, Bolt-Ons | 7 | 09-16-2014 10:28 PM |
| 9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ | SUB-ZERO | Forced Induction | 44 | 07-09-2014 09:44 PM |
