#29 |
Drives: Grocery cart
Do this.. there is no Tach / engine RPM signal from the ECU to the DLC, newer cars all use CAN communications. You can tap into the coil pack and it will give you an RPM signal when the ECU grounds the coil for it to fire.
for the Number one cylinder its called IGT1, its white red at the ECU and at the coil pack its blue yellow.. |
| The Following User Says Thank You to HapaHaole For This Useful Post: | liquidsky44 (01-21-2014) |
#30 | |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
#31 |
There is no Speed sensor wire from this type of system. The ABS system takes each wheel speed sensor reading them calculates it to a vehicle speed then sends it via the CAN BUS system. Only place you can pick one up is from the wheel speed sensor, BUT its not recommended.
#32 |
#33 | |
Drives: Toyota 86 GTS
Also, where in the engine bay would I find TACH? |
#34 |
Drives: Subaru BRZ Limited MT
I know it has been a while....but is anyone still looking for a wire to tap for Tach signal? There is a gray wire coming off of one the modules on the passenger side you can tap. I tapped it last night to my boost control gauge to get the shift light working. Worked like a charm. Let me know if anyone needs a picture.
My Build Thread: http://www.ft86club.com/forums/showthread.php?t=76898
#35 | |
Steve Bodalenko
http://www.ft86club.com/forums/images/icons/icon7.gif |
#36 | |
#37 | |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#38 | |
Steve Bodalenko
It's on top of the wire bundle and was relatively, for the Auto electrician, to get to. Worked a treat for anyone interested. Can be traced to Pin 21 the ECM A36(D) which is inside the cabin. |
#39 | |
Senior Citizen
Drives: Scion FR-S
#40 | |
Drives: scion frs
| BRZ NAV system GPS signal issues? | DigDloppyFonkeyBick | Electronics | Audio | NAV | Infotainment | 73 | 06-07-2016 03:14 AM |
| Turn Signal Repeaters | Ben_G | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-22-2012 11:26 PM |
| BRZ signal light bulb | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-20-2012 02:26 AM |
| Scion FR-S Tach Sweep Video | F1point4 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 06-15-2012 04:53 PM |
| plastic in front of tach | feldy | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-10-2012 01:03 AM |
