Old 01-16-2014, 04:38 PM   #29
HapaHaole
Drives: Grocery cart
Do this.. there is no Tach / engine RPM signal from the ECU to the DLC, newer cars all use CAN communications. You can tap into the coil pack and it will give you an RPM signal when the ECU grounds the coil for it to fire.
for the Number one cylinder its called IGT1, its white red at the ECU and at the coil pack its blue yellow..
HapaHaole is offline   Reply With Quote
The Following User Says Thank You to HapaHaole For This Useful Post:
liquidsky44 (01-21-2014)
Old 01-21-2014, 10:10 PM   #30
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Thank you for the info. But would you happen to have the diagram and the way to tap into the vehicle speed signal as well? I've never done this or any electrical wiring on a car before let alone a new car with CAN signal.
liquidsky44 is offline   Reply With Quote
Old 01-22-2014, 12:50 AM   #31
HapaHaole
There is no Speed sensor wire from this type of system. The ABS system takes each wheel speed sensor reading them calculates it to a vehicle speed then sends it via the CAN BUS system. Only place you can pick one up is from the wheel speed sensor, BUT its not recommended.
Old 01-22-2014, 11:26 PM   #32
liquidsky44
Currently my Defi Advance ZD is only displaying the oil and water temperature and oil pressure.
Old 08-24-2014, 09:44 PM   #33
xbb1024
Drives: Toyota 86 GTS
Originally Posted by Jeff Lange View Post
Looking into it further, it looks like the ECU has a dedicated "TACH" output signal, pin A35-15 on the ECU. This is the 35-pin connector.
It probably heads over to the DLC2 connector or something, because it isn't heading to any other systems in any of the wiring diagrams which is where I initially checked. Every other ECU, etc. uses the CAN-BUS to get the tach signal, but as I said there is an output dedicated to it on the ECU. It's not shown in any wiring diagrams, but it is mentioned in the RM.
Nice of them to do that.
Jeff
What about AD2-37 on the driver's side? I think that's where A35-15 leads to (unless I've read the wiring diagram wrong).
Also, where in the engine bay would I find TACH?
xbb1024 is offline   Reply With Quote
Old 08-18-2015, 08:06 AM   #34
Enalband24
Drives: Subaru BRZ Limited MT
I know it has been a while....but is anyone still looking for a wire to tap for Tach signal? There is a gray wire coming off of one the modules on the passenger side you can tap. I tapped it last night to my boost control gauge to get the shift light working. Worked like a charm. Let me know if anyone needs a picture.
Enalband24 is offline   Reply With Quote
Old 08-24-2015, 09:48 PM   #35
Bodalenko
Steve Bodalenko
Smile
Yes please!! About to add a shift light and desperately need a source.
http://www.ft86club.com/forums/images/icons/icon7.gif
Bodalenko is offline   Reply With Quote
Old 08-28-2015, 08:26 AM   #36
Enalband24
Steve, hang in there! I'll get a picture after work today, around 5pm and post it for you.
Old 09-08-2015, 12:49 AM   #37
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Picture please
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 09-22-2015, 03:41 PM   #38
Bodalenko
Steve Bodalenko
Thanks but all good. Tapped into the W-R (White with red stripe) wire out of Pin 9 of the AC1 connector.
It's on top of the wire bundle and was relatively, for the Auto electrician, to get to.
Worked a treat for anyone interested. Can be traced to Pin 21 the ECM A36(D) which is inside the cabin.
Old 01-19-2016, 11:16 PM   #39
simpleisbest
Senior Citizen
Drives: Scion FR-S
Can I ask what shift light you are using?? That wire would be for the Ignition Coil #1. Were you able to use its signal as an RPM signal or did your shift light have a way to convert the signal to use for RPM?
simpleisbest is offline   Reply With Quote
Old 02-24-2016, 08:59 PM   #40
svnintl
Drives: scion frs
So there is no speedometer signal wire we can tap into? I'm getting a tach gauge with optional display which I want to make into the speedometer reading. Anyone found a solution or know which wire that'd be?
svnintl is offline   Reply With Quote
BRZ NAV system GPS signal issues? DigDloppyFonkeyBick Electronics | Audio | NAV | Infotainment 73 06-07-2016 02:14 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
BRZ signal light bulb ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 8 06-20-2012 01:26 AM
Scion FR-S Tach Sweep Video F1point4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-15-2012 03:53 PM
plastic in front of tach feldy Cosmetic Modification (Interior/Exterior/Lighting) 8 06-10-2012 12:03 AM
