Old 06-28-2012, 01:58 PM   #29
danthedirt
Hadouken
danthedirt's Avatar
Drives: Whiteout FR-S
Originally Posted by yayforaddison View Post
The crank shaft position sensor sounds like the same issue some of the others are also having with the idle issue. Have you happened to notice any strange idle dip? Does your idle ever randomly drop below 400rpm? Would love to know if this is all related to this little sensor, or even the crank shaft itself.
Yea! Right before the EC light came on, the car rpms dipped for a few seconds causing the car to shake. Was the first and only time it happened though. Feels good knowing there is such a supportive community growing around such a new car that can offer great feedback.
Whiteout MT
Car Blog: downrightfrs.blogspot.com/
danthedirt is offline   Reply With Quote
Old 06-28-2012, 02:05 PM   #30
trifenix
Drives: Toyota Tacoma
I smell tsb coming soon?
trifenix is offline   Reply With Quote
Old 06-28-2012, 02:51 PM   #31
excited86
Drives: none
if this continues, its gonna hurt both toyota and subaru real bad.
excited86 is offline   Reply With Quote
Old 06-28-2012, 03:13 PM   #32
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Nah. This happens a lot on 1st year cars.
If engines start blowing up and/or people get hurt from a problem, then it's time to complain.
So instead of WPP (White People Problems, you have First Year Problems. FYP.)
86'd is offline   Reply With Quote
The Following User Says Thank You to 86'd For This Useful Post:
civicdrivr (06-28-2012)
Old 06-28-2012, 03:16 PM   #33
the_3d_man
Drives: 2007 Legacy GT
Dealerships are always so quick to say that the ECU must be defective. I've NEVER seen a car with a bad ECU. They don't just fail but I know so many people who in the process of trying to diagnose a problem have had the dealership replace the ECU. It's just the answer that dumb service techs like to give.
the_3d_man is offline   Reply With Quote
Old 06-28-2012, 03:28 PM   #34
excited86
Drives: none
that messed up.
Old 06-28-2012, 03:30 PM   #35
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
AGREED. The only time I've seen a bad ECU was on a 12+ year old Dodge Stratus. However, I've heard tons of people having their ECUs replaced and the problem persist (not in the FRS/BRZ, other vehicles).
The crankshaft position sensor would definitely be causing issues like this with rough idle and potential stalls. The sensor must be just a little off or something because with a real bad sensor you'd get problems starting and misfire codes (and noticeable problems accelerating). Then again, this is a brand new car so maybe a bad batch of parts from OEM? However, why the ABS light stays illuminated is also interesting. Those are pretty unrelated!
I figured the car would have at least one FYP, something minor hopefully. This isn't too bad, the 06 Si had tranny problems and I am glad ours does not (*knock on wood*).
eriktherod is offline   Reply With Quote
Old 06-28-2012, 03:38 PM   #36
danthedirt
Hadouken
danthedirt's Avatar
Originally Posted by eriktherod View Post
The crankshaft position sensor would definitely be causing issues like this with rough idle and potential stalls. However, why the ABS light stays illuminated is also interesting. Those are pretty unrelated!
Actually after looking over the manual again, its the Slip indicator light that is stuck on. The same light that comes on when your TS and SC kicks in.
In the manual in the fine print reads:
If indicator does not turn off within a few seconds of starting engine, there may be a
malfunction. Have vehicle inspected by your Scion or Toyota dealer.
Im going to update my OP.
Whiteout MT
The Following 2 Users Say Thank You to danthedirt For This Useful Post:
eriktherod (06-28-2012), LivingLegend (06-28-2012)
Old 06-28-2012, 03:43 PM   #37
eriktherod
Oh, that is interesting. Wonder if that's a code for particular engine issues, doubt your diff is broken!
Old 06-28-2012, 04:01 PM   #38
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
Maybe try turning the TC/SC off and on again? Just outa curiousity, still need to have it checked out though...
R8 is offline   Reply With Quote
Old 06-28-2012, 04:18 PM   #39
yayforaddison
yayforaddison's Avatar
This all sounds very related to the idle issue some of us are having that may have to do with that sensor. Some others have also reported misfires, rough idle, ect.
The more I hear about it, the more it's narrowing down to the same problem.
yayforaddison is offline   Reply With Quote
Old 06-28-2012, 05:38 PM   #40
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by Asterisked Accolade View Post
Something i noticed was when you enter the FRS forum, the first thing you see is at least 3 threads about car problems. When you go to the BRZ forum, this problem is nearly non-existent.
This is true...probably because all the BRZ threads are along the lines of "Why the hell don't I have my BRZ yet?"
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following 6 Users Say Thank You to Laika For This Useful Post:
5oo (06-29-2012), Asterisked Accolade (06-28-2012), eriktherod (06-28-2012), Hawaiian (06-28-2012), HotLeopardMama (06-29-2012), Wes (06-28-2012)
Old 06-28-2012, 06:35 PM   #41
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
So true, they can thank all of the FR-S guys for being the beta testers and keeping them from going through this.
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
Asterisked Accolade (06-28-2012), HotLeopardMama (06-29-2012)
Old 06-28-2012, 06:43 PM   #42
Thunderchicken
Drives: 2008 STi
From what it looks like Toyota has done the something as Subaru and holding off shipments till they get this nailed down. On a side note it like to see the 5why notes.
Thunderchicken is offline   Reply With Quote
My car is in and still 1,304 miles away! joshua BRZ First-Gen (2012+) — General Topics 16 06-28-2012 08:02 PM
Some Miles White_OUT_FR-S Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2012 02:00 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 05:07 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 05:06 PM
