Old 01-25-2016, 09:09 PM   #29
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by wise345 View Post
I think I have a buyer in place for my GReddy so I need to get a new exhaust fairly soon
To be fair I am sure you will be happy with borla. Its not like its ebay china crap quality. Have you looked into Corsa?? They make a nice cat back although it is a little heavy. Quality seems good on those too
Old 01-25-2016, 09:12 PM   #30
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Originally Posted by JimmyMac View Post
The problem is the catback.... Like I said, I ran the same headers and frontpipe. Swapping catbacks solved the drone problem.
Reason for me considering borla is I know a guy that has basically the same setup I'll have and it sounds nasty...over video at least
wise345 is offline   Reply With Quote
Old 01-25-2016, 09:15 PM   #31
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Video never does it justice haha. Mine doesn't sound nearly as good on video as it does in person.
Old 01-25-2016, 09:37 PM   #32
wise345
wise345's Avatar
I think I'll just try and find something used and if i don't like it try another
Old 01-25-2016, 09:54 PM   #33
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
The drone isn't even my biggest issue its just the overall sound. I can't stand it
A different catback will also solve that issue. Solved mine as well. But I said all that already.
JimmyMac is offline   Reply With Quote
Old 01-25-2016, 10:24 PM   #34
wise345
wise345's Avatar
That's the plan!
Old 01-26-2016, 12:55 AM   #35
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I'd try the Q300. I did and it saved my ears when going up hills. If that's still not enough you'll probably need to go back to a catted header (I'm guessing you don't have any).
stockysnail is offline   Reply With Quote
Old 01-26-2016, 01:45 AM   #36
wise345
wise345's Avatar
I am ore than ok with loud as long as it is a good noise
Old 01-26-2016, 11:14 AM   #37
stockysnail
Just the tip
Watch the videos in my build thread closer to the bottom of the first post to hear what my car sounds on the track. Plenty loud at full throttle.
Old 01-27-2016, 11:27 AM   #38
Pekingduck
Drives: 4 wheels
Have you look into Evasive ssp 70mm single exhaust? I had a Tomei 80mm exhaust and it was to loud for my taste. No drone and it sounds nice and it pretty quiet..
Pekingduck is offline   Reply With Quote
Old 01-27-2016, 06:08 PM   #39
wise345
wise345's Avatar
I'm actually going to look at a 80r today and hear it. If I don't get that then I'll check it out!
Old 01-27-2016, 06:12 PM   #40
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
80r is also a very very loud catback
Instagram: trevor.parque
Old 01-27-2016, 06:15 PM   #41
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Thing 2 also agrees. A type 80R stock the rest of the way up is almost as loud as my full catless setup
Old 01-27-2016, 07:21 PM   #42
Pekingduck
Drives: 4 wheels
Thing 2 also agrees. A type 80R stock tHe rest of the way up is almost as loud as my full catless setup
At a cold start my max decibel was 108db with Tomei 80mm my current setup and on the dyno max decibel was 114. Now after I change to evasive version i tested and it 99db on cold start with the same setup exempt of different exhaust.
Making an axel back sound louder. Possible? geruta Engine, Exhaust, Transmission 16 04-20-2015 12:23 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
Nicer Hvac knobs? brillo Cosmetic Modification (Interior/Exterior/Lighting) 19 06-17-2014 07:31 AM
Quieting Race Brakes Jericon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2014 02:07 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
