Old 07-06-2012, 04:06 PM   #29
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Lightweight TE37 C1 (CONCEPT ONE). This wheel comes in at 7kg, or 15.43lbs, for 19x8.5" sizing..........
These are the rims for me.... Awesome, strong, light, expensive, awesome!!!!........... I'll probably get them in 17x9 front, 17x9.5 rear in black special edition.......
TE37SL in 18" weighs 18lbs.. Sorry guys was copy and paste don't know what PCD or width for TE37SL.....
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
The Following User Says Thank You to FT-86GOD For This Useful Post:
tripjammer (08-24-2012)
Old 07-06-2012, 04:15 PM   #30
xwd
Originally Posted by yoshiharadesign View Post
sorry.. forgot about the pics.
I just ordered a set of PG-5S from Velox and they said there were only 2 wheels left and they didn't know when they would be making/getting any more in the 17x7 5x100 +42 size. Just as a correction they are +42, not +40.
Also another member has the VX-6R and when weighed on his scale they were 15.4lbs, as opposed to the 14.5 stated weight. Was his scale broken?
Old 07-06-2012, 04:46 PM   #31
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Ah yeah the Velox PG-5s were the lightest obtainable 17s I found for this car. 12.5 pounds. Sadly they don't make very many and they only offered it in 17x7. It would be awesome wheels for anyone in stock class.
industrial is offline   Reply With Quote
Old 07-06-2012, 05:01 PM   #32
yoshiharadesign
Yes. the wheel spec is 42 offset... I kept thinking 40 as we did have a few offsets originally. As to VX-6R weight, 15.4lb might be due to the offset he was running? Because some offsets usually require thicker padding which will contribute to slight variances of a pound or more. This actually applies to most wheel companies out there who advertise weight. A few mm difference along with cap goes a long way in terms of weight and most companies advertise the lightest possible weight from the wheels. In addition, lightweight wheels are usually the result of taking out material while still being able to support load. With certain wheels, load rating is reduced so that more weight can be taken out. However, problem with that is usually wheels usually bend and crack easier due to a lower load rating. So, when purchasing wheels, its always ideal to review load rating as well.
yoshiharadesign is offline   Reply With Quote
Old 07-06-2012, 07:26 PM   #33
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
There's a slightly outdated Excel sheet w/ weights, brands, and sizing if someone wants it, I can find it and post it.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 07-06-2012, 09:24 PM   #34
xwd
Yes I specifically got them to run in stock class. I originally wanted the Tracklites but everyone seems to be out of them. I called Velox directly and found they had 6 wheels left in stock. They only sell the PG5S directly none of the dealers had access to them from what I found.
Old 07-06-2012, 11:27 PM   #35
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
And what brand/model are these mystery wheels?
they are, as written "Custom made" on a military plant here in Russia )
No brand, no model, just pure racing sexyness
as you may see, they are un-painted, coming right off the lathe
maybe I won't even paint them, just cover with varnish
MSTiFK8R is offline   Reply With Quote
Old 07-30-2012, 08:14 PM   #36
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
quik1987 is offline   Reply With Quote
Old 07-30-2012, 08:21 PM   #37
quik1987
quik1987's Avatar
te-37 mags in 18x10 is 14lbs
18x9.5 are $1700 each.
te37 c1
The Following 2 Users Say Thank You to quik1987 For This Useful Post:
Slartibartfast (08-27-2013), tripjammer (08-24-2012)
Old 07-31-2012, 03:39 AM   #38
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Do they still make te37s in mag? And are they actually gonna sell the te37c1s?
cyde01 is offline   Reply With Quote
Old 07-31-2012, 04:12 AM   #39
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
would be so good if they did
Old 08-23-2012, 08:31 PM   #40
quik1987
quik1987's Avatar
I think we have a winner
The Following 3 Users Say Thank You to quik1987 For This Useful Post:
boarder1995 (08-23-2012), chulooz (08-23-2012), tripjammer (08-24-2012)
Old 08-23-2012, 10:45 PM   #41
cyde01
cyde01's Avatar
yeah good luck trying to find a set of those for sale. have those ever been seen outside of the tokyo auto salon?
Old 08-23-2012, 10:52 PM   #42
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
WedsSport TC105N 17x8 14.85lbs Sub $500 wheel too.
The Following User Says Thank You to Draco-REX For This Useful Post:
F1point4 (08-28-2013)
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
TRD Wheels Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 06-27-2012 07:11 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 06:03 PM
O.Z. Wheels Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-28-2012 04:21 AM
Top 10 Lightest 300 Horsepower Cars Axel Other Vehicles & General Automotive Discussions 2 11-22-2009 03:23 AM
