Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-19-2014, 09:25 AM | #29 | |
I've had my fr-s for about two weeks so I'm still sorting out the differences. The higher-end headers seem to be equal length. Which would you recommend to someone with an OFT on the way? |
12-19-2014, 09:32 AM | #30 | |
That Guy
Drives: 2013 asphalt FRS MT
All of my bushing on this car are Whiteline. I highly recommend them. That said AVO has some great reviews and also shows a lot of support to our community. I think Energy Suspension, and Powerflex also sell bushings for our car. Generally, a good rule of thumb is that if RCE and/or CSG are willing to list the part, it's worth buying. FT86Speedfactory seems a little more liberal in this regard, though. Just my .02, your mileage may vary. |
The Following User Says Thank You to Calum For This Useful Post: | twag4 (12-19-2014) |
12-19-2014, 09:33 AM | #31 | |
The very title of your thread means you will have responses that say stock is fine and if not the info you are looking for there is no need to get rude and go on the attack. My car is not stock and has several mods planned but that does not mean that I need to belittle those that don't. Oh, and at least I had a mother that taught me manners! I am outta here.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
12-19-2014, 09:33 AM | #32 | |
And another dyno comparison of UEL vs. EL. Again same dyno and tuner (this time Shiv), but on e85:
2022 BRZ Build 2013 FR-S Build |
12-19-2014, 09:45 AM | #33 |
Drives: frs
Cat back exhaust, then no need for stupid sound generator. MTEC shift springs, whiteline rear subframe bushing inserts, wheels and tires look so much better when wider with a little more "poke", and improve cornering (yet reduce oversteer which isn't neccessarily a good thing), 1" lower to close the wheel to fender gap, although problematic when crossing deep gutters in driveway entrances and the like. I'm pretty sure I will add forced induction to this list, just don't have or wish to spend that much money on something that could result in a costly non warranty covered incident. Maybe after warranty is up. I have a few other inexpensive mods, but nothing earth shaking. I have a 10 series and I love love the HID headlights. I modded for the led daytime lights that are in the headlight housing to be on at a lower intensity when the headlights are on, and that looks super. All frs models should have come with these headlights as toyota installed them in their gt86 everywhere else but North America. Then do the drl mod I just mentioned. Just a few. OP, I get what you are asking, what makes this car better to the individual, what would the individual like to have seen as OEM on this car. Not what would best appease the masses. I get it
12-19-2014, 09:45 AM | #34 | |
12-19-2014, 09:50 AM | #35 | |
12-19-2014, 09:52 AM | #36 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Some sort of variable valve lift with a 8200 rpm redline.
12-19-2014, 09:56 AM | #37 |
No problem. Just remember that's just the general rule. There are certain EL headers that seem to do a good job eliminating the dip. P&L and JDL catted are two off the top of my head.
12-19-2014, 10:09 AM | #38 | |
Any reason to go with another header? |
12-19-2014, 10:09 AM | #39 | |
Sweeper
I can see you're frustrated so I'll end that sentiment there. Here's a list of items I feel should be the default operational package (Manual only, no experience with AT variant): - Clutch pedal adjustment to one's liking (typically lower) - Ultramaroon's 3/4" Slave Cylinder swap - Mtec shifter springs - ~70-80A duro transmission bushing hardness - ~70-80A duro subframe bushings - Lowered ~1" - No sound tube - Oil cooler ala Forester XT style - Camber bolts - Re-engineered engine/exhaust and tune setup to minimize that torque dip while retaining emissions and MPG targets Not a unique list, and funny that I am in congruence with others here on this one . Notice around half of those suggestions pertain to the clutch and driveline- that vague stock clutch feel is terrible. I personally would love a throatier exhaust, HIDs, fogs, etc. standard on the FR-S but those aren't imo a wise choice for a stock manufacturer package.. too much individual tastes there. Sans exhaust those items aren't expensive to source and retrofit to the platform so not a big concern there. As far as stock goes, for the most part they hit home where it counts (chassis, bodylines, balance of power and suspension geometry, total overall driving experience in general) |
The Following 2 Users Say Thank You to Koa For This Useful Post: | GT86_PRAGUE (12-19-2014), Ultramaroon (12-20-2014) |
12-19-2014, 10:34 AM | #40 | |
Rave reviews from those that have done it and on my list for next spring. http://www.ft86club.com/forums/showthread.php?t=77390
The Following User Says Thank You to Tcoat For This Useful Post: | GT86_PRAGUE (12-19-2014) |
12-19-2014, 10:41 AM | #41 | |
Sweeper
http://www.ft86club.com/forums/showp...6&postcount=38 |
12-19-2014, 10:45 AM | #42 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Automatic climate control for base models
Similar Threads | ||||
"Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
"Required" mods | KarMa14 | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 07-27-2013 12:44 PM |
Stock width, stock "feel" bigger rim? | Trashed675 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-12-2013 12:39 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
