BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
12-16-2021, 08:32 PM | #29 |
Drives: 2011 WRX
Ok guys so help me out here. I was trying to follow but got a little lost. Early on dsc pat mentioned swapping the lower crash bolt and the upper larger collared bolt. Is that correct, or does the lower smaller oe "crash bolt" stay in the lower hole and another set of crash bolts needs to be ordered to go in the top hole?
Also afterward I just need to force the hub at the top as far as I can before touqueing it down correct?? Will I need an alignment after, since no other changes are being made? Last edited by Scoobtothenoog; 12-16-2021 at 08:34 PM. Reason: Spelling |
12-16-2021, 09:07 PM | #30 |
Drives: 22 BRZ limited
You can put another set of the smaller bolts in the upper hole, or you can put the lower bolts in the upper hole and camber bolts in the lower hole.
In reality, I think there are 6 options. Upper camber bolt. Lower camber bolt. Crash bolts in upper. Crash bolts in upper, camber bolts lower. Upper camber bolts, lower camber bolts. Stock. |
12-16-2021, 09:25 PM | #31 | |
Drives: 2022 BRZ
Upper camber bolt, lower camber bolt > crash bolt in upper, camber bolt in lower > lower camber bolt > upper camber bolt > crash bolt in upper in terms of how much negative camber can one get from the config? Also dual camber bolt isn't the safest? |
12-16-2021, 09:31 PM | #32 | |
Drives: 17 Asphalt 86
You can also pair the 81305 lower bolt with 81280 upper lobbed bolt. Some say this is less safe. Opinions vary. Adding 1° camber you can either: - Change lower bolt with SPC 81305 - Change upper bolt with OEM crash bolt (from dealer) - Change upper bolt with SPC 81280 Alignment is a good idea. Verify camber settings and check/make adjustments to toe. If you have aftermarket wheels make sure to check clearance from the top of the wheel to lower spring perch. Adding camber this way shift the wheel closer to the strut. |
The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
12-16-2021, 09:32 PM | #33 | |
Don't forget about the pedders top hats also. |
12-16-2021, 09:48 PM | #34 | |
Maybe next year The idea of ripping apart my struts for a third time is Less appealing |
12-16-2021, 09:53 PM | #35 |
Drives: 2011 WRX
Thanks guys. That's exactly what I needed!
12-16-2021, 09:56 PM | #36 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
I actually recently took mine off the car because they aren’t legal in SCCA solo spec coupe class. They are currently mounted to a set of TS springs/dampers. Not sure if I’m gonna sell them or keep them at this point. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to BlueWhelan For This Useful Post: | RToyo86 (12-18-2021) |
12-17-2021, 03:02 PM | #37 |
Drives: 2022 BRZ
Anyone confirmed if aftermarkets gen1 rear LCA fits the gen2 ?
12-17-2021, 03:30 PM | #38 |
Drives: 2022 GR86
Adding camber in the front will cause toe in — you're basically turning the knuckle relative to the diagonal axis going through the LCA joint and the tie rod joint when you change camber. If the camber change is significant, it is useful to check the toe. Also, some alignment shops might be able to squeeze out a few more tenths of a degree of camber for you.
12-18-2021, 02:19 PM | #39 |
Drives: 2015 FRS for daily and track use
12-26-2021, 02:22 PM | #40 |
Drives: '22 BRZ
I installed the OEM crash bolts. I got around -1.3 degrees of camber on both sides with my camber gauge. Toe was nearly unchanged, as it was on the first gen.
The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
12-26-2021, 04:23 PM | #42 |
Drives: Subaru BRZ
The Following 4 Users Say Thank You to SpectreRT For This Useful Post: |
Similar Threads | ||||
Simplest Bestest Mods to tighten up steering, turn in and body flex | Broz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 05-13-2021 02:06 PM |
Simplest possible install for tablet | transition | Electronics | Audio | NAV | Infotainment | 9 | 02-11-2014 05:43 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
