View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-19-2012, 07:20 PM   #393
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
So far switching from Costco 93 octane premium to Shell V 93 octane 10% ethanol has made it run less noisy, but it still does soft chirping on soft gear changes when revs drop. The crickets have lost most of the battalion! Lets get the rest out of there!
NeedsmoreCowbell is offline   Reply With Quote
Old 07-19-2012, 07:24 PM   #394
Brimford
Drives: Whiteout / MT FR-S
Your correct, i tried some Mobile gas for the last fill up and it's louder than ever! Going to switch back to shell after this tank!!!
Brimford is offline   Reply With Quote
Old 07-19-2012, 07:25 PM   #395
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Originally Posted by sierra View Post
What should void the warranty is using fuel that's not up to the specification that this car was designed for.
As White64Goat points out, 2T is designed to disperse in any fuel, even diesel.
Some of you just don't seem to understand that others are trying to help with this problem, by offering a solution until Toyota/Subaru can engineer and install the fix.
Well that's all fine and dandy but peoples solutions can be quit costly because no mater how you feel about this topic your warranty will end if they find anything in your gas tank bottom line sorry!!! trust me i make the call you dont!!! So i guess dont bring your car into my dealership!!! I am just trying to help before somebody does something that they will regret. In my opinion as and owner of an FRS is that if my Eng blows up Toyota will find whats wrong with it and make that repair for free because i have the factory warranty. Yes i would be sad to have my car down for the time but if that helps find the problem for all of us have at it. I'll just Drive my GTS!!!
:b onk:
20valvewynn83 is offline   Reply With Quote
Old 07-19-2012, 07:28 PM   #396
20valvewynn83
Originally Posted by cobrabyte View Post
As mentioned before, 2-stroke oil blends completely with gasoline. You'd have a hard time even telling it was ever there. You'd find ethanol deposits before finding good quality 2T oil -- especially at the 1:1000 ratio that we are talking about. Using such a small amount will have zero ill effects on a modern vehicle.
As i have never tried this i cant guarantee anything but i do have a question. can you light 2-Stroke oil on fire with a match?
Old 07-19-2012, 07:39 PM   #397
20valvewynn83
Originally Posted by Fenrir View Post
Subaru and Toyota have issued several statements on the issue, this forum just chooses to ignore them.
Latest from the Subaru rep I've been working with on my front bumper cover fitment issues is that they've logged enough complaints and a resolution is being worked on by Toyota. No info past that.
He stressed again, and cited Toyota as saying this as well, that it is not a detrimental problem to the engine or the fuel system. Adding anything other than actual fuel lubricant (he mentioned zMax, but I'm sure other brands are fine) such as 2-stroke oil can be potentially harmful to the motor and would recommend against it.
To anyone looking for a repair in the form of a TSB that's pouring gunk in their fuel tank should consider this, as your claim could very well be denied if they detect additives in your fuel. They have eyes on these open forums and know what users are doing with a surprising amount of clarity.
:happy0180:
Old 07-19-2012, 08:57 PM   #398
sierra
Drives: Skoda Yeti DSG diesel 4x4
So what is 2T if it isn't an actual fuel lubricant? It's the most tried and tested fuel lubricant out there.
Why would something like zmax and other 'fuel lubricants' be recommended as alright to use?
How would they analyse the fuel to find which fuel lubricant had been used and then decide which one is acceptable?
sierra is offline   Reply With Quote
Old 07-19-2012, 10:21 PM   #399
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
480 miles and no chirping sounds. Changed my oil @ 450 miles and use 93 octane.
ShoGun is offline   Reply With Quote
Old 07-20-2012, 02:42 AM   #400
sierra
Good question.
Pour some in your underpants, drop a match on it and pull them back up.
If it gets hot you can let us know, yes it does burn.
Old 07-20-2012, 03:09 AM   #401
20valvewynn83
Good question.
Dude really you can put whatever you want in your car, i dont give a $hit truthfully.
What I am saying for the people in the US just leave it because we will find out an additive was dumped into the system weather its found in the gas tank, the lines, the filter and or spark plugs. We will check pressures and I'm sure one burns slower then the other and we will light gas on fire (away from the buildings and cars, in a safe location)
Old 07-20-2012, 03:26 AM   #402
fistpoint
Drives: Supercharged Golf Cart
Translated to mean: as expected, the dealership will do everything in its power to deny your warranty claim first and foremost.
Thanks for being honest!
fistpoint is offline   Reply With Quote
Old 07-20-2012, 03:40 AM   #403
Thunderchicken
Drives: 2008 STi
Just so you know no dealership will run a fuel sample in a lab to see what is in your fuel it is too costly, plus they would have no clue what additives are in the fuel from station to station. I went rounds and rounds with a dealership trying to say I had water in my tank but they couldn't prove it and refused to show me the sample they said they pulled.
Thunderchicken is offline   Reply With Quote
The Following User Says Thank You to Thunderchicken For This Useful Post:
sierra (07-20-2012)
Old 07-20-2012, 04:14 AM   #404
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
:b onk:
What dealership do you work at?
sho220 is offline   Reply With Quote
The Following User Says Thank You to sho220 For This Useful Post:
sierra (07-20-2012)
Old 07-20-2012, 09:26 AM   #405
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
~200 miles and heard the chirping of the injectors sitting at a light last night for the first time. Seems to remain for just a moment during rev up before releasing the clutch and then dies out, so maybe there a flow aspect to it.
Stu baru is offline   Reply With Quote
Old 07-20-2012, 10:03 AM   #406
sierra
I've now got a vision of this hi tech forensic procedure out in the car park,
with a sample of the customer's fuel in an open container being set on fire.
If there's any sticky residue on the end of the testers burnt finger when he wipes the empty container the customer is declined warranty and that evidence will be tendered in court as evidence by the expert witness.
Sorry dude, just having a laugh. No offense.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
