Old 02-16-2016, 12:53 AM   #393
ollie
ollie's Avatar
Drives: GT86
Was looking at updating my tune, currently running v84 UEL E85.
Have downloaded the latest tune files v95 / v97 and was wondering which tune I should use.
My setup is E85 / OFH / BPB
Should I just use Stg2 UEL E85 v95.US.Lean
Thanks Amigos.
ollie is offline   Reply With Quote
Old 02-16-2016, 03:24 AM   #394
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Thanks Amigos.
AT? Which Model Year?
If your car is originally A01I then
- Stg2 UEL_Tomei E85 v95.US.Lean
if you have Tomei/PSR/Gruppe-S
- Stg2 UEL E85 v95.US.Lean
if you have another brand
One will feel better than the other between 3000-4000.
If you have earlier MY AT, then you will likely need to run the maf scale from the MT rich version.
The Following User Says Thank You to Wayno For This Useful Post:
ollie (02-16-2016)
Old 02-16-2016, 03:48 AM   #395
ollie
ollie's Avatar
Drives: GT86
Thanks buddy I have a 2013 GTS auto with Openflash header running A01I. On a side note, do you still over paid custom tunes? Think I might benefit from it as I have BPB.
Thanks Ollie
Old 02-16-2016, 06:20 AM   #396
Wayno
Wayno's Avatar
Thanks Ollie
You don't need any custom timing for bpb on e85.
ollie (02-16-2016)
Old 02-16-2016, 06:54 AM   #397
ollie
ollie's Avatar
Drives: GT86
Great thanks, always helpful mate really appreciate what you do.
Old 03-07-2016, 12:15 AM   #398
Wayno
Wayno's Avatar
Added v98.
- Restored port injection above 5000 rpm on petrol.
- Completely removed US (E10) maf scales from 98 tunes.
US people should use OTS maf scales and base timing as starting points.
The Following 3 Users Say Thank You to Wayno For This Useful Post:
cawith (03-07-2016), dar3d3vil (03-07-2016), elBarto (03-07-2016)
Old 03-07-2016, 12:43 PM   #399
dar3d3vil
dar3d3vil's Avatar
Drives: 2015 BRZ Limited
Just wanted to say thanks for this, I've been using this since around v86 and between this and the guide it's been a huge learning experience for me. I do have one questions though, I seem to remember that the earlier versions had the readme.txt in them telling you which tables to modify for certain versions. I don't have that readme anymore and I see that the newer versions don't have it included anymore. Would you possibly be able to post it up so that I can grab a copy of it, just so that I don't end up ham-fisting something by accident when I'm tweaking from a newer version, or has it been completely superseded by the guide now?
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS
dar3d3vil is offline   Reply With Quote
Old 03-07-2016, 10:34 PM   #400
Wayno
Wayno's Avatar
Download any OFT 2.0x package from openflash, compare the examples to the matching roms of the same calibration code (A01I/A01G) from 2.0x.
Some tables will be applicable to some regions, some won't. RR table descriptions, your logs and all the many threads here should tell you which are needed. Many won't be required.
Those threads (such as all steve's threads) explain what the changes do, these are here to make it easy to copy+paste. You still need to understand for yourself what you're doing.
Old 03-07-2016, 10:51 PM   #401
dar3d3vil
dar3d3vil's Avatar
I'd been using the guide to tailor certain areas to my specifics, just a couple of areas in the example maps that I wasn't sure about, so I figured I'd leave them as opposed to copying them, especially as I'm converting to US MT 93 Oct setup for myself. Primarily that was the Idle Speed Stability and the Misfire Maps.
Old 03-07-2016, 11:00 PM   #402
Wayno
Wayno's Avatar
You also need to compare it to the same calibration code, do not compare an EU region map to US region because you'll get a ton of different tables different.
I say don't try to fix what ain't broke. Fix cranking, fuel, etc as required. If your car idle's fine, don't touch idle.
Old 03-07-2016, 11:04 PM   #403
dar3d3vil
dar3d3vil's Avatar
Exactly what I figured, thank you again for everything you've done for this community with both these maps and guides. I know this place would be a very different place without yourself, Steve and everyone else who has put so much time into tweaking the OFT maps.
Old 03-08-2016, 07:11 AM   #404
iChan
Hi when I tried to upload new data for updated cranking fuel injector for E85 I always get this error. Any help? VV
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Unable to load DLL 'Cktrl.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E). "
iChan is offline   Reply With Quote
Old 03-14-2016, 04:15 AM   #405
tha_alkaholiks
tha_alkaholiks's Avatar
Drives: DMG Subaru BRZ
Hey Guys,
Getting my OFT soon, I've got a MY13 AT. Essentially stock, but will be getting a UEL header in the future.
If I'm running stock everything and 98Ron fuel, should I just stick with shiv's latest OTS tunes? Stage 1 91oct or 93oct?
Or should I look at running wayno's Stage 1 98?
Cheers!
tha_alkaholiks is offline   Reply With Quote
Old 03-14-2016, 04:21 AM   #406
steve99
Originally Posted by tha_alkaholiks View Post
Hey Guys,
Cheers!
the stock tunes will run ok
i think the auto tunes were missing the p0420 cel code disable for header on some tunes
European and ausies only get one level of petrol tune the 91 version (98 ron version)
but wayno mods are well worth doing
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 10:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 11:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 01:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 06:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 05:26 PM
