#393 |
Drives: 2013 Ultramarine FRS
Need Help.
I plugged my oft into the computer to update. I assumed it autoupdates. It did do some form of updating. When it stopped I went out to my car to hook it up to flash the new stage 2 93 oct uel map. The map wasn't there. None of the new maps were there. How do you get the new maps? |
#394 |
@Shiv@Openflash & and everyone
I just got dyno session today & here is the result. 169.1 whp with no correction factor applied Temp was mid 80 with 74% humidity Dyno Dynamic dyno The stock graph is not my car but its stock BRZ on same dyno on much cooler & dry day in October. Mods are following: OFT 2.01 stg 1 93 oct map Perrin OP Tomei catless front pipe Invidia Q300 Apexi filter perrin inlet. |
#395 | |
SuperTek http://supertekindustries.com/index....-fr-s-brz.html |
#396 | |
Drives: BRZ Limited
#397 |
Drives: 2025 BRZ, ex-2012 GT86
Looking forward impatiently for EUDM versions!
BTW in the 700l Stg 2 UEL v1.59 P0420 CEL code is not disabled - would be nice to fix it in v2!
#398 |
after 30 miles of driving normal i did a second gear pull to see how the car is running. im on stage 2 uel 93 rom.
http://www.datazap.me/u/lucid215/sta...l?log=0&data=1 |
#399 | |
Drives: '13 BRZ Ltd
#400 |
Yes I noticed ltft is pretty high.
#401 | |
It not rearly that bad once its off idle/low rpm, just needs lower end of MAF scale re-done , unless it an intake that creates turbulance near MAF at low rpm, possibly MAF sensor is relocated too close to throttlebody. |
#402 |
Drives: '13 BRZ Ltd
Which header? Does it sound like it might be leaking?
I noticed occasional LTFT in the 7's, haven't logged on OFT yet but I see it on the Torque app. It's very transitional, seems to be during very low load and higher-than-idle rpm. I'm wondering if a header leak could cause something like this. |
#403 | |
#404 |
He has OFH I think
#405 |
Drives: FR-S Whiteout
#406 |
Sorry for the late reply. Yes I have the ofh and aftermarket intake. I didn't have those hi ltft with the stage one rom. She felt a lot better on the stage one. I don't have any leaks I torqued the bolts down a bit more then stock specs. She's starting to feel a bit better but still the vvt still doesn't kick in as hard. I'm running Takeda intake, ofh, invidia over pipe, invidia catless front pipe, and jdm TRD axle back exhaust.
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
