Old 03-20-2014, 11:15 PM   #393
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Hi gang.
Can someone review my logs and let me know if this look safe?
My mods are in my sig. I do not have a modified snorkel. I am running 93 pump gas.
I hope I recorded and posted this log correctly. With this link you should be able to highlight the parameters you prefer to view. I hope
http://www.datazap.me/u/boofneenee/b...e?log=0&data=1
thanks in advance
Ohh.. and this is 1.55 tune stage 1.
Josh
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 03-21-2014, 12:16 AM   #394
Drofnum
Drives: CBS Subaru BRZ
Running 1.56 Stage 1 map. My IAM is dipping down it was as low as .79 but its been pretty steady at .9-.98 now. Any idea whats going on/is it ok?
Heres a small log a pull through gears 1-3
http://www.datazap.me/u/drofnum/0320...=0&data=1-9-12
Drofnum is offline   Reply With Quote
Old 03-21-2014, 12:23 AM   #395
s2d4
s2d4's Avatar
Originally Posted by Victor Draken View Post
http://www.datazap.me/u/victor-drake...0&data=1-2-4-7
4 3rd gear pulls and quite a bit of driving in traffic.
stg1 1.56 after 400km on 100RON fuel (EU).
Only mods: Blitz drop in filter.
how is it?
@shiv@vishnu @nelsmar
Same FBKC when ramping on high load at low rpm.
I am starting to think it's because the other guys don't bother reproducing/logging it.
The Following User Says Thank You to s2d4 For This Useful Post:
steve99 (03-21-2014)
Old 03-21-2014, 12:39 AM   #396
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Boofneenee View Post
Hi gang.
thanks in advance
Josh
Hi Josh,
Logs look a little on the lean side. Nothing dangerous at all but you can run richer without loosing power. Give the Stage 2 map a try. The exhaust and high-flow cat you have may just be needing the extra fuel that the Stage 2 EL map will give you
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Boofneenee (03-21-2014)
Old 03-21-2014, 12:42 AM   #397
Shiv@Openflash
Drives: 2013 FRS
That behavior is pretty normal on 91oct. The fact that IAM climbed back up close to 1 is good. If you routinely see it dip down to .7 or lower it may be worth running a slightly less aggressive ignition map. But nothing in your log suggest that is the case at this time. AFR and timing look good.
Old 03-21-2014, 12:43 AM   #398
Shiv@Openflash
Drives: 2013 FRS
how is it?
Those logs look really good to me. Can't really suggest any changes. In fact, you can probably make it a bit more aggressive if you wanted to.
Old 03-21-2014, 02:10 AM   #399
Vmax911
Drives: WRB BRZ
So I pulled a little bit of timing from my advance map. Does the car need some relearning to accurately assess knock, or can I log right away?
Vmax911 is offline   Reply With Quote
Old 03-21-2014, 03:34 AM   #400
steve99
If your on petrol not E85 should be fine, accelerator might feel a bit unresponsive for a bit as it learns 0 to max will sort itself out fairly quickly.
Old 03-21-2014, 06:35 AM   #401
Victor Draken
Drives: Toyota Gt86
How could i make it a bit more aggressive?
Thanks for the review shiv
Victor Draken is offline   Reply With Quote
Old 03-21-2014, 07:17 AM   #402
AL008
Drives: Celica 04
Awesome tune for my UEL headers full exhaust and drop in filter. Completely changed the car!
@shiv@vishnu:
Could you please kindly have a look at my datalog please , you're doing an awesome service to this community!
http://www.datazap.me/u/toy-sooby/3r...=0&data=1-9-12
Thanks in advance!
AL008 is offline   Reply With Quote
Old 03-21-2014, 07:28 AM   #403
Kodename47
Kodename47's Avatar
Drives: UK GT86
I add 0.5-0.7 deg to the advance table above 2600 and load over 1/1.1. I use the advance map as it makes it easier to keep track of. Do it in steps; add a bit, test, repeat if applicable.
The reason I would only touch those areas as that is where you are WOT. Then if you see any FBKC/FLKC, back those cells off by 0.35 deg.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-21-2014, 07:43 AM   #404
troek
troek's Avatar
Drives: 2012 Toyota 86
@shiv@vishnu:
Thanks in advance!
what gas are you running, ur adv multiplier has dropped.
Old 03-21-2014, 07:50 AM   #405
AL008
Drives: Celica 04
I'm running 98 Octane.
Old 03-21-2014, 08:00 AM   #406
troek
troek's Avatar
some of the other ausie guys have had the issue of the multiplier dropping at lower rpms, id read back a few pages and get with them.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 12:12 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 01:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 10:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
