Old 03-14-2014, 12:44 PM   #3935
OrbitalEllipses
Drives: Attitude
I didn't the couple times I changed mine.
Bad habit. When you're messing with electronics you should open the circuit and discharge any latent juice in the system by stepping on the brakes until the lights no longer illuminate.
Old 03-14-2014, 12:49 PM   #3936
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It's a MAP sensor. Deal with it.
Old 03-14-2014, 12:52 PM   #3937
OrbitalEllipses
Drives: Attitude
Old 03-14-2014, 12:53 PM   #3938
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Got my intercooler yesterday
Sent from Samsung Galaxy Note 3
Area86 is offline   Reply With Quote
Old 03-14-2014, 01:00 PM   #3939
swift996
swift996's Avatar
For comparison purposes, here was my run last week when I was having the misfire issues, I should be in pretty good shape to put up some solid numbers. Previous run was unintercooled and the 75mm pulley. New setup is 72.5mm pulley and intercooler:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-14-2014, 01:10 PM   #3940
xxscaxx
Drives: 2013 SWP BRZ
ugh...I want to swap back to my stock sensor damnit
xxscaxx is offline   Reply With Quote
Old 03-14-2014, 09:37 PM   #3941
phloozy
phloozy's Avatar
Drives: Scion FR-S
Dyno video!
[ame="http://www.youtube.com/watch?v=iUgxl8f1dck"]Supercharged FR-S on the dyno, 285whp/235wtq - YouTube[/ame]
phloozy is offline   Reply With Quote
The Following 2 Users Say Thank You to phloozy For This Useful Post:
Lawnik (03-14-2014), mikalem (03-14-2014)
Old 03-15-2014, 11:21 AM   #3942
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I've had a couple of people ask about this so I figured I'd share for any who are interested. All I did was run a 1/4" tap to switch the threads from BSPT to NPT threads. Just run the tap for a few threads, then screw in one of the fittings until it stops and then count the number of full turns it takes until it comes out. Repeat this until you get at least 3 full turns before the fitting releases from the threads. The fittings I got from my local ACE hardware store and they were 1/4" male X 3/8" barbed hose fitting and 1/4" male X 5/16" barbed hose fitting. And I only did the two outer ones since the middle one is already brass and I don't believe anyone is having issues with this one. I did remove it though and added teflon tape just for peace of mind.
Dustin is offline   Reply With Quote
Old 03-15-2014, 11:33 AM   #3943
evan
Drives: fr-s
311.5whp on the juice
http://www.ft86club.com/forums/showthread.php?t=60785
evan is offline   Reply With Quote
The Following 3 Users Say Thank You to evan For This Useful Post:
clayrush (03-16-2014), DarrenDriven (03-16-2014), swift996 (03-15-2014)
Old 03-15-2014, 12:27 PM   #3944
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
What is the thread size for that small fastener to the bottom right if the elbows. It screws into the manifold. I believe it is for a boost gauge. I am trying to find a nipple that will screw in there
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 03-15-2014, 04:19 PM   #3945
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi Guys and Gals,
I have been basically out of touch for quite some time working on current updates to our tunes across the board and will be releasing them over the coming weeks. We are also working on some new products that we are trying to finish up (FlexFuel Kit - Special Edition, and some other cool pieces). Plus we are in the process of moving in the coming weeks, so be on the lookup for an announcement. As far at the point of this post, we are pleased to release version 8.5 of the Innovate Supercharger tune for the following.
Revision 8.5 applies to the following: (autos and manuals)
- Innovate Supercharger Kit with 75mm, 72.5mm and 70mm on 91,92,93,94, E85 and FlexFuel
- Innovate Supercharger Kit with Intercooler and 75mm, 72.5mm, 70mm on 91,92,93,94, E85 and FlexFuel
All previous customers are offered the free upgrade to the latest 8.5 revision. This has some major improvements in the following areas. (Tunes will be available tomorrow for all to request).
Improvements Include:
1. Dead stop (stop light, etc...) acceleration
2. Light throttle cruising at very low RPM's, deliciously smooth
3. More throttle control for autocross and track goers
4. Improved fuel economy for those long trips and around town
5. Better cold start for all fuels especially E85
6. Smoother power delivery on 50-80% throttle
7. Smoother top end (past 5K to redline)
I have to say this is one of the best tunes I have done so far and with nearly 500+ hours tuning on the Innovate Supercharger kit this should be pretty nice for everyone. I will warn everyone the throttle has changed quite a bit. At first I was not sure if I was happy with it, but I gave it a chance and have really grown to like it A LOT and I am sure you will also. Enjoy...
Cheers,
William Knose
The Following 7 Users Say Thank You to DeliciousTuning For This Useful Post:
Area86 (03-15-2014), calispec (03-15-2014), Dustin (03-15-2014), Ethan (03-16-2014), Lawnik (03-15-2014), Ryan86 (03-16-2014), TemeCal (03-15-2014)
Old 03-15-2014, 04:21 PM   #3946
Dustin
Twin Screw You
Dustin's Avatar
Originally Posted by DeliciousTuning View Post
Hi Guys and Gals,
Cheers,
William Knose
Looking forward to purchasing your tune. Just have to build my oil cooler and then you're next on the list. Can't wait to get everything installed. I'm tired of looking at a pile of parts on my living room floor.
Old 03-15-2014, 04:40 PM   #3947
Area86
Area86's Avatar
Hi Guys and Gals,
Cheers,
William Knose
Awesome!!! I will definitely be looking to pick up the flex fuel kit when its ready. One question though I just received my intercooler from Innovate so would the update still be free if I need to change my tune for the intercooler?? And can we run all 3 pulleys on the same map now or are they still separate?
Old 03-15-2014, 05:40 PM   #3948
swift996
swift996's Avatar
Need some help (Intercooler/Coolant)
So my coolant level has been fine for about 6-8 weeks. Last week I noticed a sudden drop in the coolant level. It was at the bottom of the reservoir. I filled it up and today (the next day) it was down to the bottom. I filled it up and drove 2-3 miles and it went down by about an inch.
I can't find a leak anywhere. Not going in or out of the manifold, the reservoir, the t-fitting, the fittings by the front mount, the intercooler itself. I fear it might be leaking into the engine but the engine seems to be running fine. Does anyone know what else it could be? I'd hate to have to take the manifold back off. I'm closer to just pulling the kit and being done with it. cc: @mines13
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
