Old 12-25-2013, 08:16 PM   #379
Darkrune
Darkrune's Avatar
Drives: 2017 86
Originally Posted by shaunsweeney View Post
You people are too willing to overspend on this platform. Never seen parts this expensive for an NA car in my life!
I'm not saying that this header will be, but I think $1k for a NA header is a little ridiculous.
Tubular turbo manis go for more than that and these manis look just as complicated to make. Throw in a cat on top of that and less than 1000 is good. But you are right in the sense that a small % gain isn't worth dumping money. On the the other hand, small gains in a light car is pretty noticeable.
Sent from my XT907 using Tapatalk
Darkrune is offline
Old 12-25-2013, 09:02 PM   #380
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
The power/$ is what I meant. I'm waiting to see where this goes price wise to determine if I want this and a SC or just go turbo.
shaunsweeney is offline
Old 12-25-2013, 09:03 PM   #381
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
I would not use an aftermarket high flow cat with a supercharger. You run too high a risk of melting the cat with forced induction.
| Mark Dorman | Performance Specialist | markd@stillen.com| IG @Mark_STILLEN | www.STILLEN.com
Team STILLEN is offline
Old 12-25-2013, 09:20 PM   #382
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
But what is the difference between the OEM catted header and an aftermarket HFC header. And then what about the OEM header and a HFC front pipe....or aftermarket header (no cat) with a aftermarket HFC front pipe?
kurbkilla is offline
Old 12-25-2013, 09:23 PM   #383
Team STILLEN
Mark @ STILLEN
FT-86 SpeedFactory Catted UEL Header
The amount of materials in the cats (short answer) make the HF ones not tolerate as much heat. A HFC further down the exhaust stream would probably be less of an issue but I can't say as all our superchargers are on cars without secondary cats.
I would worry more about running a catless header with HFC front pipe than running a stock header with HFC front pipe (I would assume with the amount of heat the stock cat is absorbing, the second HFC would be okay).
The Following User Says Thank You to Team STILLEN For This Useful Post:
kurbkilla (12-25-2013)
Old 12-25-2013, 09:56 PM   #384
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
To further your point with a question, that I think I know the answer to, but want to bounce it off someone who knows significantly more than I do....
If I have a aftermarket header with HFC and a front pipe with HFC, would that make any difference on the HFC in the header or would it only really help the secondary HFC? Also, would NA put out enough heat to be increasing wear on the HFC? I'd ideally like to have only a single cat as that is what the law around where I live requires, but if two would be less likely to have issues...
I've said it many times, but I'll say it again, I am a complete newbie to modding and tuning cars; this car has awakened a new hobby that I am finding that I love. I want to do this intelligently and correctly the first time (as much as possible).
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline
Old 12-25-2013, 10:02 PM   #385
Team STILLEN
Mark @ STILLEN
I admire that you are willing to learn how to modify your car. Very smart of you as it will save you a lot of time and money in the long run.
A secondary HFC should have no effect on a HFC in the header. It would further reduce emissions but it would be fine to just run one in the header. From what I have seen, the FA20 doesn't seem to put out enough heat to wear out a HFC at an increased rate. With heavy track use any cat will wear out a bit faster, but I don't see spirited driving and light track use making a major difference. Any of the other manufactures or experienced track guys have any input?
Turkish (12-25-2013)
Old 12-25-2013, 10:16 PM   #386
shaunsweeney
So I basically can't go FI. I live in MA and cannot eliminate all of my cats and pass inspection. If that is the case I will just be using this header and a catback. This makes me sad.
Old 12-25-2013, 10:20 PM   #387
Team STILLEN
Mark @ STILLEN
You can keep the stock cat with FI, it's just the HFC that I would not combine with FI.
Old 12-25-2013, 10:42 PM   #388
shaunsweeney
I wouldn't keep the stock header if I went SC and not a possibility with a turbo. That just defeats the purpose IMHO. Oh well NA for me. At least I get to rock an awesome header!
Old 12-25-2013, 11:57 PM   #389
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Guess I am too used to getting screwed on parts for the F355... one header is $2800.00 (OEM) or a pair of after-markets for ~$3000.00 (need two). This is NA.
355rockit is offline
Old 12-26-2013, 12:14 AM   #390
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
If the price is $1000 there is no purpose in buying it. I can buy OFT + OFH for the same price, and get the same results, and also have a data logging tool. Just not even close to worth it. **edit - I live in texas, I'm not considered about emissions really, and also still have my 2nd cat **
I agree that the prices for headers are absolutely absurd on this platform. But this platform is new.
R&D costs aside, they will be making huge margins on these. If ft86 speed factory really knows what they are doing, they will price it right. Forget the R&D costs, people are so much more willing to buy a $600 header than a $1000. I can almost guarantee they will sell more this way.
86-tundra is offline
The Following User Says Thank You to 86-tundra For This Useful Post:
Boofneenee (12-26-2013)
Old 12-26-2013, 12:22 AM   #391
shaunsweeney
Did you seriously just compare Ferrari parts to the twins? C'mon now.
Old 12-26-2013, 12:24 AM   #392
MidnightRunner
MidnightRunner's Avatar
Check out some of the dyno runs bob@driftoffice ran comparing a sc setup vs the sc with an aftermarket header (hks if I'm not mistaken). The header made a very small contribution to hp and tq.
So at the price of $1000+ it becomes a tuner's dilemma whether to keep stock header when going with a sc. It was either jackson or kraftwerks for the dyno run.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline
The Following User Says Thank You to MidnightRunner For This Useful Post:
Team STILLEN (12-26-2013)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
