Old 08-30-2013, 03:04 PM   #379
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by nelsmar View Post
Better? Well that depends on what you consider better...
I dont know what the cooling system is like on the innovate but the non-intercooled edition is much easier to install than the vortech (though you do have to remove fuel components so as long as you are comfortable). And removing the belt is much simpler. The oil is harder to change, but you do it much less often than the vortech, which i like.
Vortech has been around longer, and has a long reputation and stands by their products. I feel their kit is much more complicated to install.
However when it comes to power delivery? As we don't have access to an intercooled edition in the US yet we cannot test, but we will likely be running comparison tests once they start to pop up. As for non intercooled? The vortech has a nicer pull on the top end. I made a good 25% more horse power at peak than the innovate guys (I am waiting on this dyno from the shop to show). However the torque was lower. So when it came down to higher rev's and acceleration the vortech was better. But when it came out to balanced torque distribution the innovate wins. It is your choice as to which you want.
Also note the vortech has a decent amount of headroom. I am not even maxing mine out revolution wise and I dyno'd almost 50% higher peak power than the innovate (which was not maxed out, but afaik it doesn't have too much headroom above that).
I love both the kits, and feel they both have their place. If you have access to E85 then that is another bonus, the innovate ran great after we pumped e85 into the system.
Either way it's preference. Your car is on more psi via the pulley you have. I feel the Innovate will be a bit more of a surprise intercooled and with a smaller pulley 😈 For now Vortech wins power and probably will hands down without a doubt. Just no way to even compare closely without an IC and more boost.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-30-2013, 03:37 PM   #380
Boblhead
Drives: Asphalt FR-S
Originally Posted by JDLAutoDesign View Post
Took a look at both cars. Brents was leaking due to heat cycles. Theses need to be re torqued after a heat cycle. I pulled the header off and checked the flanges. Bother were straight. I re installed it, got it hot, re torqued the header, and added some sea foam to ensure we had no leaks. Car is leak free now
The other car def had an issue and im correcting that now. It would be nice if we didnt get throw us under the bus as soon as there was an issue. We are here to help you guys so dont hesitate to ask
We recommend starting with the single bolt and then torque the outer 2. Also stainless steel expands and contracts with heat cycles so it would be a good idea to check on them from time to time
I guess from now on we just won't talk about it.
sent from
Boblhead is offline   Reply With Quote
Old 08-30-2013, 03:53 PM   #381
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
You all can talk about it all you like. It would nice if the facts would be mentioned if you (whoever) do. The pics that had a piece of another gasket is from a customers install. I told him I would look over everything to ensure our product was good to go. That is what I found upon removal of the header.
JDLAutoDesign is offline   Reply With Quote
Old 08-30-2013, 04:19 PM   #382
Bonks86
Drives: Gt-86
Hey buddy I told you over the phone i stuck that up in there to help with the leak after I put it all back together Monday night. lol It got me along for the week and I never threw anyone under the bus or even posted about it leaking, I asked if you could take a look at it
Bonks86 is offline   Reply With Quote
Old 08-30-2013, 04:23 PM   #383
JDLAutoDesign
Drives: 13 FRS
Not you at all. You and Brent called us to let you know you had issues and we have no problems helping you out
Old 08-30-2013, 04:26 PM   #384
Bonks86
Drives: Gt-86
ooo Ok, I was like damnnn son I didn't say anything about a leak on the forum at all. I knew it was either my poor install or that there was a small adjustment needed. I was fed up with trying to fix it myself on Monday that i fab'd up that sweet little piece of a gasket you found haha. It did help keep down the leak a bit for the time being
Old 08-30-2013, 04:27 PM   #385
Bonks86
Drives: Gt-86
@JDLAutoDesign glad to see it wasn't a huge deal! Now we need to find some time to re-dyno
Wher are we hitting up a dynojet?
Old 08-30-2013, 04:31 PM   #386
Sivtec
Sivtec's Avatar
sent from
Ha Bobby didn't mean anything by "we just won't talk about it". To the JDL guys, it was an ongoing joke we had for dyno weekend. Apparently no one wanted to talk about anything. Just giving you some insight from what that phrase now means. We were think about getting shirts made? @Ninjin
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
-2013 Scion Raven FR-S
-2009 Honda Green/Black CBR600RR
Old 08-30-2013, 04:35 PM   #387
EZWood
BAMF
EZWood's Avatar
I have to say I am impressed with the 8 extra HP bonks car made with the JDL header. I would like to compare our dyno plots to see what the differences are on the whole rpm range.
Old 08-31-2013, 12:56 AM   #388
redsuns03
Speaking of re dyno can I join in on this? Getting 5pc light weight pulleys from @Raceseng and would love to do it when it arrives! And wanting to see how the trd exhaust perform.
Sent from my SGH-T999 using Tapatalk 4
Old 08-31-2013, 01:00 PM   #389
nelsmar
I can overlay them later when I get to my desk.
My flickr - Canibeat
Local magazine scout
Old 08-31-2013, 01:00 PM   #390
nelsmar
Of course! I just need to get some work done and we will figure a day out here soon. I think Keith has a dyno jet in mind. I plan on going to both a dynojet and back to goodspeed
Old 08-31-2013, 03:20 PM   #391
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
its mostly marins car that we dont talk about. The day right after the dyno day when it broke... I dont wanna talk about it.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 09-03-2013, 12:21 AM   #392
nelsmar
What about the day of the dyno day when it broke down? Shit. Me and @Ninjin just got the car permanently fixed... Now to hit the dyno for final numbers and to get the overlays -.-
idontwannatalkaboutit
OFFICIAL ARIZONA AREA REGISTISTRY jeffsides Arizona 206 11-08-2021 09:28 AM
Looking for a Tune(r) in Phoenix area Chase86 Southwest 18 06-06-2013 09:05 PM
STREETRACING WEEKEND AT KILLARNEY: SAT 23RD & SUN 24TH FEBRUARY 2013 Razzle AFRICA 3 02-26-2013 05:36 PM
March 23rd and 24th PDX, HPDE at Barber Motorsports Park naikaidriver Southeast 2 02-13-2013 01:12 PM
Anyone in the Phoenix area evo4g63 Southwest 0 02-06-2013 11:19 AM
