#379 |
Drives: Red SCion FRS
Another question i have. This might be a very stupid question but i will ask anyway haha. So without SC, I hit 70mph at around 3000rpm in 5th gear, with Vortech SC will i hit 70 mph at a much lower rpm or more in the same gear? Thats where i am usually at when cruising on freeway anyway. Thanks
Sent from my HTC One using Tapatalk 2 |
#380 | |
Drives: Forced Induction and LSx Swaps!
#381 |
Drives: Sc10n Series FR-S
Will you need to upgrade you exhaust system if you boost?
Will you need to upgrade ANYTHING if you boost? I know high PSI requres a build, but what's a decent PSI to run that will gave it some more fun power, without needing to build the engine? |
#382 |
The standard kit comes with boost designed for the stock motor.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#383 |
1337
Drives: 2013 BRZ WRB S/C
#384 | |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
#385 | |
Can the stock engine handle all of these no problem? Also, what sort of exhaust would I need, or can that be stock as well? (I'll probably get the Perrin 2.5" because it sounds awesome) |
#386 | |
Thupercharged
It even comes with a blocking plate so you can either block off the standard vent port, or the "loud" vent port depending on how you want it. I also adjusted the spring pre-load on mine, the boost pressure seems to be even more "instant" when going from vacuum to WOT. Perhaps it transitions from open/closed(Sealed) a little quicker, not sure.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#387 | |
Drives: 2013 FRS
can you explain the second part some more? did you mean that it blows off in lower rpms as well? |
#388 | |
Thupercharged
The exit with the "horn" on it has the cutout higher, so that the piston has to travel much higher to dump air that way. Normal idle /cruise air dump is mostly/all out of the barbed exit, and it only vents to the "horn" exit during letoff at high rpm when there is boost in the charge pipes/vacuum in the manifold. The barbed end is threaded into the body of the valve, as well as the horn end. You can swap them to whatever configuration you desire, or install the blockoff plate. I only hear a loud release if I am cruising at very high RPM, or during shifting/letoff at high rpm. By high RPM I'm talking above 5K. I could dial it in more using the adjustable spring to make it happen sooner/later, but it works just fine on any setting. I tried full soft up to about 75% tighter, and it just works. Always seals up when it should, and lets off excess when iti should
2013 FRS
| The Following 4 Users Say Thank You to DJCarbine For This Useful Post: |
#389 | |
Drives: 2013 FRS
i guess the horn would be the one i want since it's the loudest and it seems i would need to adjust the spring to where it blows off even at like 3 haha. i just love the sound. |
#390 |
Drives: 2013 BRZ DMG manual Limited
I started the install, so far so good! only bad thing is that I placed my bumper in the grass when I took it off so it wouldn't get scratches, and the dam wind caught it and flipped into the drive way and scratched it.
#391 | |
Drives: Red Scion FRS AT
i will start installing my SC tomorrow but in my Garage so I don't get my bumper blow away like yours. )
#392 |
Something I haven't really seen mentioned yet.
How well does the Vortech tune support an upgraded exhaust system to include headers? I was checking out the Perrin Overpipe, Frontpipe, midpipe, and catback system and was thinking about combining that with the Borla UEL headers. I did see a post about the Visconti tuning providing enough fuel for headers so I was wondering how the vortech tuning held up |
| Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 07:48 PM |
| New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 06:49 PM |
| Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 04:58 PM |
| Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 07:26 PM |
| Supercharging: the forgotten form of FI | madfast | Engine, Exhaust, Transmission | 76 | 03-02-2012 06:06 PM |
