View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 04-02-2014, 12:21 PM   #3893
Pete156
I like to eat!
Originally Posted by FyeaFRS View Post
Getting new fuel pump installed at dealer today under warranty. Guy told me they might come back. I told him that if they come back every few thousand miles or so that they'd be giving me a new pump on the same schedule till Toyota actually fixes the problem.
Guy is correct. Might as well schedule your car in every other month. There is NO fix for the crickets other than using ethanol free gas. Just read the last 3900+ posts.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
Marchy (04-03-2014)
Old 04-02-2014, 12:32 PM   #3894
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
If u run a tank of non ethanol premium through your car ever few tanks of gas u wont have crickets. I think I read on here somewhere as well that toybaru is no longer or is soon to be stopping warranty replacements on fuel pumps with crickets since other than a chirping noise they are working as intended.
ilpad is offline   Reply With Quote
Old 04-03-2014, 01:52 PM   #3895
ilpad
ilpad's Avatar
Originally Posted by Marchy View Post
i've noticed that heat is also a culprit to how loud the crickets can be, during the winter i barely heard it (might also be the blend of winter gas) whereas last summer it was getting pretty noisy (except the two tanks of E0 i tried).
I might alternate between e10 and e0 tanks this summer and see how it goes.
I'm pretty much on the program now that I try to get ethanol free gas at the North Plains Chevron whenever possible, but since I am out and about quite often I fill up when i need to and generally have to settle on standard premium. I get enough fillups with non ethanol though by doing this that I have been able to avoid getting the chirps for at least a year now. I took a long road trip last summer and filled up 4 or 5 times and never got my crickets back, so for my car at least this system has been working.
Love your signature btw. So true.
The Following User Says Thank You to ilpad For This Useful Post:
Marchy (04-03-2014)
Old 04-03-2014, 02:23 PM   #3896
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Do your crickets appear after the car has been warmed up?
It seems like mine start coming out of the woodworks when the engine has been running for at least 20 min or so.
subiestyle is offline   Reply With Quote
Old 04-03-2014, 02:26 PM   #3897
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
Mine come after the car has been running for a bit.
Zero90 is offline   Reply With Quote
Old 04-03-2014, 07:01 PM   #3898
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I have been running ethanol free since I got the car. Got up to 35,000km with no chirping but they just started occasionally last month. Recent posts bring up a good point about additives being the problem.
Whatever it is, Toyota/Subaru just fix it damn it
aghuman is offline   Reply With Quote
Old 04-03-2014, 09:38 PM   #3899
KenTron3030
Drives: 2013 FRS
So I've done a few things to test this, just as many have.
I tried only using Shell, same station every time. This seemed to keep the chirps from being sooo loud. If I went to Mobile or Chevron, they would come back with a pretty high volume level.
I recently went to Hess, and the chip noise seemed to die down a bit, I think even more lower than with Shell gas.
There is a gas station near me that has 90 with no corn added, so I filled up to give it a test. I don't hear a thing now and it's really nice. Now, this brings up a question for everyone.
Will running 90 octane harm the engine? Here in FL we have 93, and that's all I've ever put in.
I'd love to hear some experts, or at least opinions on this. I would never run 87 as someone previous tried, but I wonder about 90. I think there are states that only have 91, so is 90 that much lower/worse?
KenTron3030 is offline   Reply With Quote
Old 04-04-2014, 10:05 AM   #3900
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
I've read that switching to an e85 setup has eliminated crickets, can anyone confirm?
FyeaFRS is offline   Reply With Quote
Old 04-04-2014, 10:14 AM   #3901
HunterGreene
Hail Magnet
HunterGreene's Avatar
The cost of changing to a flex-fuel setup just to eliminate the crickets is ridiculous to me.
Nothing "eliminates" the crickets, either E0 or E85 is a different fuel formulation that makes the noise go away as long as you use that fuel. Only true "elimination" would be if the pump part that may be causing the chirps was actually replaced with something that didn't chirp when using E10.
It has priests in it?
Old 04-04-2014, 04:29 PM   #3902
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
I've been on ethanol free gas since day 1, but the heat brings out the crickets...
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 04-04-2014, 09:16 PM   #3903
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Originally Posted by JonAvalon View Post
It was nice while it lasted, after 2,700 miles they have returned
hmm odd i thought they were back. But since the day i posted this i haven't heard anything
JonAvalon is offline   Reply With Quote
Old 04-05-2014, 08:39 AM   #3904
EnFonde6
Drives: Toyota GT 86 2013
I also have this awful noise, even with fuel 98 Excellium from Total (best fuel available in France that I can find).
So with 98 octane, from a good manufacturer, sadly it doesn't change anything for me
EnFonde6 is offline   Reply With Quote
Old 04-05-2014, 07:16 PM   #3905
BRZJunkie
Drives: BRZ Sportech
Can someone check the part number on the HPFP on the new Forester XT and the new WRX 2015. If it's the same we should hear a lot of chirping going on unless they work at a lower pressure since they only have the DI to worry about. Just a thought.
BRZJunkie is offline   Reply With Quote
Old 04-05-2014, 11:06 PM   #3906
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Those use Subaru's DIT system, so they are different. We get Toyota's wonderfully loud DI system, which I believe is a Champion sourced HPFP. Could be wrong about brand.
Only fix is a new HPFP design, as three revisions haven't fixed this one.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
