go_a_way1
Old 03-09-2014, 01:41 AM   #3865
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I read the first 30 pages of posts again tonight. A lot of the pics seem to no longer be there.
Would someone be kind enough to post the pics or send me the link to pics of what the batteries look like and where they're being installed?
Would also like to know the exact batteries that are recommended for this kit...
Thanks a lot!
robwbright is offline   Reply With Quote
Old 03-09-2014, 01:47 AM   #3866
jpit
Drives: Subaru BRZ
You will need a different harness from Rob for the dual battery pack. You will also need a different wood support and battery tray. Here's a photo of my installation. All the ground connections are made to the new terminal that you can see. No need to run a ground wire to the starter battery - just find a different ground in the back. I used a 4 gauge wire for the power lead to the back and seems to be working fine. Rob does recommend a 2 gauge.
jpit is offline   Reply With Quote
The Following 5 Users Say Thank You to jpit For This Useful Post:
Boofneenee (03-09-2014), DAEMANO (03-09-2014), Gums (03-09-2014), nlowell (03-10-2014), robwbright (03-09-2014)
Old 03-09-2014, 03:10 AM   #3867
robwbright
Thanks! I did just find the batteries he recommends on the phantom website. So it's the kit + $90 for the ESC batteries plus $50 or so for the compact starter battery...
"Wood support"? Not sure what that is.
Where are people getting the different battery tray? Or perhaps I could just manufacture one.
Also, when you say "in the back" in reference to a different ground, do you mean in the back of the engine compartment?
Old 03-09-2014, 03:42 AM   #3868
projectXTR
Drives: Sterling Silver BRZ
Sorry if this has been asked before but searching this topic didn't give me the answer I was looking for...
To get an idea how much of a bump in performance this gives, I'd like to know how much the acceleration times improve with the esc ?
Thanks in advance !
projectXTR is offline   Reply With Quote
Old 03-09-2014, 05:03 AM   #3869
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
For the base install you just need the ESC kit and the three batteries listed. It re-uses the stock battery tray and location.
If you want to upgrade to the dual-battery pack you will need two of the $90 battery kits (2 dump batteries in each kit), a modified ESC harness, a modified battery tray, and you'll need to relocate the starter batter to the trunk with a recommended 2 gauge power line. I understand you don't need to run a ground line because the battery and accessories can be grounded in the trunk and engine compartment respectively.
That's what I've gathered anyways...
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
Old 03-09-2014, 05:08 AM   #3870
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
If you look at Jpit's pic above you will see the wood support (I believe it is the black block on top of all the batteries used to help hold everything down in conjunction with the factory battery tie-down..
Not sure about the battery tray, maybe just a universal at the parts store.
"in the back", means that when you relocate the starter battery to the trunk for example, you will just run the ground wire to the body. If you look at the pic above, you will see the black factory ground wire hooked up to a post installed in a spare hole in the fender (Jpit did you have to drill the hole larger to get it to fit?) and the following image also courtesy of jpit, shows the negative battery terminal being grounded to what looks like the spare tire tie-down.
The Following 3 Users Say Thank You to Target70 For This Useful Post:
DAEMANO (03-09-2014), nlowell (03-10-2014), robwbright (03-09-2014)
Old 03-09-2014, 05:28 AM   #3871
Target70
Target70's Avatar
Thanks in advance !
Other than dyno numbers I don't think anyone has anything else in terms of performance data, like track times or 0-60 but there is this:
Originally Posted by SloS14 View Post
Horrible comparison video *now with slo-mo instant replay*
Old 03-09-2014, 09:10 AM   #3872
raven1231
Thanks a lot!
Batteries that are recommended are on Phantoms website, there are two links. They are installed in the same location as the stock battery.
Old 03-09-2014, 12:07 PM   #3873
raven1231
Originally Posted by Sojhinn View Post
@shiv@vishnu I know you are busy bro, but any updates on tunes for the phantom and/ or your trip down here to San Diego?
@shiv@vishnu, any updates on this? Sorry just really want to order my OFT/OFH combo....but want to see results first.
Old 03-09-2014, 01:16 PM   #3874
robwbright
Thanks in advance !
I read the first 30 pages of this thread last night and watched some of the videos.
Months ago Fenton got 6.5 secs 0-60 at altitude - 3500 feet, I think he said (and he says he's not very good at shifting... LOL). I believe that's significantly faster than the time he had gotten before. Someone asked for a side by side 0-60 test against a stocker, but it was noted that 0-60 is a very inaccurate measure car to car and driver to driver because of different skills in shifting.
He also ran a 60-120 and I think it knocked the time down by like 5 or 6 seconds.
I seem to recall that in one of the videos someone at lower altitude was in the mid to high 5s 0-60. If you look back through pages 20-30, I think it would be around there.
The Following User Says Thank You to robwbright For This Useful Post:
projectXTR (03-09-2014)
Old 03-09-2014, 01:19 PM   #3875
robwbright
Thanks - got it. I was under the impression that - if you used only two batteries and a compact starter battery - that you could fit it all under the hood.
I realize that if you add 2 more on top of that you're going to have to move something to the trunk. Which is not ideal since my sub box is already taking up 1/4 to 1/3 of the trunk. LOL.
Old 03-09-2014, 01:23 PM   #3876
robwbright
Originally Posted by fenton View Post
Video update 2!
Tried a 60 to 120mph: started at 5 seconds ended at 23seconds for a total of 18 seconds
Also tried my hand at the torque app 0-60.... ive said this before im not that great of a shifter but even with my modest effort i got 6.5 sec at +3500ft altitude
The car is sooo much easier to launch now.... i tried what i see people doing online... that was a mistake, launch at 4500 rpm with this system and you will spin ALL THE WAY to redline lol.
See above re: 0-60 and 60-120.
Old 03-09-2014, 01:36 PM   #3877
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I was the one that was running the mid 5s but I was also on e85.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 03-09-2014, 01:51 PM   #3878
robwbright
So I'm guessing ESC, Header, Tune and 93 oct = high 5s?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
