go_a_way1
Old 02-18-2014, 04:53 PM   #3711
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Originally Posted by keen as View Post
Hi Guys. Please excuse my ignorance. Is there further info about shortening the intake snorkel? For example, where to shorten, any pics and what benefits?
See here - http://www.ft86club.com/forums/showp...0&postcount=77 - and also that thread generally
VR46 is offline   Reply With Quote
The Following User Says Thank You to VR46 For This Useful Post:
keen as (02-18-2014)
Old 02-18-2014, 05:13 PM   #3712
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
I wonder when the RHD version will be available?
The unit is placed at the center of the engine, so unless a few inches of power cable are needed to route to batteries on the other side I don't see why there would be a RHD version.
bee_are_zee is offline   Reply With Quote
Old 02-18-2014, 05:54 PM   #3713
Robftss
Drives: VW
Wish it was that simple.
RHD:
- Compressor and intake bits are the same.
- Controller mount hole is used by the hood release cable.
- Main dump cables and charge cables need to be ~ 2.5 times longer and since they will be 'crossing' the engine a proper secure route (alt conduit) makes this length a trial and error process ( having an extra 200 mm of cabling is detrimental). Going up a gauge is most likely.
- Starter battery is mirror image, the hold down block/ neg extension need to be flipped/reversed and tabs flipped as well.
- WOT switch mount stud is again mirror image, but the pedal bar is the same, an entirely new mounting bracket is needed to achieve correct activation.
- I think the sound tube hole (cabin access) for the harness is the same, but the pedal cluster is near and may have some interference (other pedals).
I'm workin on it
Rob.
Robftss is offline   Reply With Quote
The Following 5 Users Say Thank You to Robftss For This Useful Post:
BRAWL (02-19-2014), cuddefred (02-18-2014), Gums (02-18-2014), keen as (02-18-2014), s2d4 (02-18-2014)
Old 02-18-2014, 05:57 PM   #3714
keen as
keen as's Avatar
Drives: 86 GT MT
Yes a RHD model is planned.
I contacted rob a month ago and provided photos of engine bay, accelerator pedal and measured runs for wiring. I am "thinking out loud" on the forum, and wonder if anyone has further info, especially about package deals with OFT.
(Thanks Rob, beat me to it)
keen as is offline   Reply With Quote
The Following 3 Users Say Thank You to keen as For This Useful Post:
DAEMANO (02-18-2014), Gums (02-18-2014), s2d4 (02-18-2014)
Old 02-18-2014, 05:58 PM   #3715
bee_are_zee
Drives: GBS BRZ
haha yea I dont have one yet so I was basing everything on general compressor location...
Old 02-18-2014, 06:04 PM   #3716
keen as
keen as's Avatar
Drives: 86 GT MT
Rob, I'll have a look if there is an easy way to route wiring to left side of engine bay, in front or on top of airbox to join a controller in a similar location to where Shiv had his accessory charging box thing bolted on the left side near the washer bottle filler.
What do you think?
The Following User Says Thank You to keen as For This Useful Post:
Gums (02-18-2014)
Old 02-18-2014, 06:09 PM   #3717
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Originally Posted by Khyron686 View Post
I'm sold on the 250 SC, just not sure about the OFT/package. Worth it? If I set it to 91 and then never touch it again, is it still worth it (or can I borrow someone elses machine and just pay for the flash program?). Or just buy the kit and that will be plenty?
Kind of new to the whole issue of tuning and haven't tweeked a car in a long, long time. When I joined the forum and asked how I catch up, the OFT was the first thing people were suggesting. I'm ordering mine as soon as the budget says yes.
Blu-by-U is offline   Reply With Quote
Old 02-18-2014, 06:16 PM   #3718
Robftss
Drives: VW
What do you think?
Removing the hood release cable clip and securing that cable with some other means is the way to go. Then that frame hole can be used by the controller...extending the 3 phase cables to reach the 'washer bottle' side will reduce efficiency.
Old 02-18-2014, 06:29 PM   #3719
keen as
keen as's Avatar
Drives: 86 GT MT
OK, yes, I can see that the 3 phase cables from controller to ESC will need to be longer to reach washer bottle side
Old 02-18-2014, 07:09 PM   #3720
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Horrible comparison video *now with slo-mo instant replay*
[ame="http://www.youtube.com/watch?v=nPmLl1ss6jc"]NA vs Phantom ESC - YouTube[/ame]
The Following 6 Users Say Thank You to SloS14 For This Useful Post:
clintavo (02-18-2014), DAEMANO (02-18-2014), Gums (02-18-2014), mxsled (02-18-2014), normancw (02-19-2014), wawro569 (02-18-2014)
Old 02-18-2014, 10:11 PM   #3721
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Has anyone with the kit noticed any oil in the compressor intake? .. or to put it another way, does anyone think it necessary to put a catch can between the compressor intake coupler, and the crank case vent hose?
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
Old 02-18-2014, 10:45 PM   #3722
Thatruth2001
Drives: Raven FR-S
Great question. I have a catch can and need to check it. Will report back I the next few days on the matter. But I doubt there will be anything in the can.
Thatruth2001 is offline   Reply With Quote
The Following User Says Thank You to Thatruth2001 For This Useful Post:
Old 02-18-2014, 11:05 PM   #3723
fenton
I don't run a catch can and have zero oil in the intake after 24,000km of boost.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (02-18-2014), Gums (02-19-2014), Target70 (02-19-2014)
Old 02-19-2014, 07:38 AM   #3724
WNDSRFR
Drives: FR-S,GTI
Had to bring my car in to the dealer to get a new transmission. Drove home in a loaner Prius. My God it's like driving a bus.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
