Old 10-25-2015, 07:31 PM   #365
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by ryoma View Post
I have read through both this extensive guide as well as the other guide posted by Wayno and wow, it is pretty informative. I am completely new to tweaking tunes and I have a few questions regarding it. Since I am in California and only have access to 91AKI here, what tables are "safe" for me to copy over from the examples to the OTS tune? I'm assuming that the O2 rescaling, MAF scaling, load limits, DI range, and the utility tweaks are safe considering they don't have specific tables that rely on 98RON? and am I understanding correctly that timing shouldn't have to be touched on the OTS ROM for 91AKI unless I am knocking? I just want to make sure that I have my facts correct before logging and making changes.
Yep pretty much keep your existing timing and maf scale. Or keep your entire tune for starters and do plenty on logging on it first.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
gonzo (09-09-2016), ryoma (10-25-2015)
Old 10-31-2015, 06:31 PM   #366
burrowsc
Drives: 14' Firestorm FR-S
I'm having a hard time opening the XML file for editing. I added the correct B00D XML to the definitions and I'm about to open the OFT stage 2 .bin file but when i go to open the B00d.xml file, it keeps saying the definitions were not found..
This is the only step I'm struggling with. any suggestions?
burrowsc is offline   Reply With Quote
Old 10-31-2015, 07:05 PM   #367
ryoma
ryoma's Avatar
did you click apply after adding the definitions? try adding the other B definitions like B01D as well
Old 10-31-2015, 10:54 PM   #368
burrowsc
Yes I clicked apply and save. I'll try adding the others as well when I get home. Any other ideas?
Sent from my SM-G900V using Tapatalk
Old 10-31-2015, 11:01 PM   #369
Wayno
Wayno's Avatar
There's nothing wrong with shiv's roms. Don't know about the OFT defs. I'm using mine.
846,539 bytes, dated 11 ‎August ‎2015
Do you only have one B00D def in the list?
Are you opening OFT 2.06x/2.07x rom files?
Old 11-02-2015, 01:25 AM   #370
Wayno
Wayno's Avatar
Added v87.
Changes:
- Smoothed and consolidated MAF scales
- Throttle tip in changes
- Tweaked BPB timing
- Adjusted and consolidated idle speeds
- Adjusted load limits under 3000 rpm.
The Following 3 Users Say Thank You to Wayno For This Useful Post:
drewbot (11-02-2015), freerunner (11-02-2015), phrosty (11-02-2015)
Old 11-02-2015, 08:58 PM   #371
burrowsc
I have the OFT .bin opened. no problems.
You can see i have the B00D.xml added in definitions but when i go to open image and open the b00d.xml for editing, keep getting the definitions not found pop up.
Old 11-02-2015, 10:49 PM   #372
JB86'd
JB86'd's Avatar
Drives: JAWS
Delete all of your definitions, apply and save. Quit Romraider and reopen, and add ONLY the B00D.xml. Then try opening B00D bin.
Wait you realize you don't need to open an XML file in Romraider to edit right? You only need the XML in the definitions, and you open and edit the BIN file.
Old 11-03-2015, 04:32 AM   #373
Kodename47
Kodename47's Avatar
Drives: UK GT86
As above, the xml is only the definition. The .bin or .hex are the tune files.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-03-2015, 03:52 PM   #374
burrowsc
Ok. I'm not sure what i was thinking before.
Started from scratch. Added OFT defs and the A01 def.
Opened my B00d.bin file and the v87 98oct rich.bin
now its just a process of comparing the tables and copying and pasting table values correct?
Old 11-03-2015, 04:32 PM   #375
JB86'd
JB86'd's Avatar
Drives: JAWS
Correct. Now when using the OFT definitions, you won't see certain tables that you would see in Wayno's definitions, as his definitions have some tables added.
Old 11-03-2015, 04:41 PM   #376
burrowsc
And im guessing those tables need to be added into my B00d.bin correct?
Old 11-03-2015, 06:19 PM   #377
Wayno
Wayno's Avatar
No, you're not modifying any structure of the rom. The definitions simply contain pointers to memory locations already in the rom and how to interpret the data.
Old 11-03-2015, 06:48 PM   #378
burrowsc
Gotcha! Thanks for the help.
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 10:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 11:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 01:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 06:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 05:26 PM
