#366 |
Drives: 2013 Raven FR-S
#367 |
Sideways and Smiling!
Drives: Scion FR-S
#369 |
Drives: LexusGS,Lotus Exige S240,LexusLX570
Since its a low mounted turbo, would any aftermarket headers be ok to install? EL UEL...
#370 |
Seems Legit
Drives: Toyota
They've said throughout the thread that they'll provide details as they become available and when they're done testing.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#371 |
Seems Legit
Drives: Toyota
They've confirmed that any aftermarket header would work...including their own.
| The Following User Says Thank You to ecko04 For This Useful Post: | mnsayer (05-16-2013) |
#372 |
Drives: 400whp Scion tC
#373 |
Dismember
Drives: 2013 Red Scion FR-S
Here, http://www.ft86club.com/forums/showthread.php?t=30737, they show about 737 engine hp if you scale the 164hp baseline at about 22% drive train loss. I certainly prefer dynos run from steady idle (unspooled turbo) to redline, not from over 3000 after revving the engine to spool up. My understanding, and correct me if I'm wrong, is that helps them kick the turbo in at a lower rpm to get a nicer looking curve at the bottom.
Last edited by EAGLE5; 05-17-2013 at 01:54 PM. Reason: Put whp when I meant engine HP. |
#374 | |
Drives: 2013 Subaru BRZ
#375 | |
That's the 604hp thread. And I have NEVER seen a dyno operator that does a pull from idle. All dyno operators start at around 3k rpms that I have seen. Starting at 3k rpms have nothing to do with there being or not being a turbo. Even N/A they do a pull from 3k rpms. The pull is not in 1st gear remember, it's in the gear closest 1:1 ratio. Which is most the time 4th gear in most cars. You not going to do an idle pull in 4th gear. |
| The Following User Says Thank You to SnapOv3st3r For This Useful Post: | WRXGuy1 (05-20-2013) |
#376 | |
Dismember
Here is an example of a dyno from 1000rpm. http://www.bmw-post.com/2012/10/16/b...iesel-on-dyno/ Seems like useful info to me. For day to day driving, I spend most of my time between 1000 and 4000rpm, but mostly around 2000. I'd really want to know if a twin screw or turbo was giving any boost then. Certainly the factory turbos in many cars do. |
#377 | |
That was a dyno from Germany, so don't know what their specifics are. I'm in the states. Be it a low rpm, it's not idle still and he went up gears before doing the official pull. |
#378 |
Drives: 2013 Whiteout FR-S
Some Pics from this weekends Dyno Day (Car made 392whp). Piping has been updated along with Oil Cooler (Located on the top right hand corner of the front end) Direct air Flow, Won't Block Intercooler or Radiator. Thanks for hosting the Dyno Day @Mrc@ptuning @ptuning
Video of Dyno Coming soon. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Oil Cooler Intake Vent is Right beside the Drivers Headlight ![]() ![]() ![]() ![]()
| The Following 10 Users Say Thank You to kanundrum For This Useful Post: | AZFA20 (05-19-2013), Chewie4299 (05-20-2013), cmss2000 (05-19-2013), EAGLE5 (05-19-2013), Lonewolf (05-19-2013), ptuning (05-19-2013), ScottDRFT (05-20-2013), SnapOv3st3r (05-20-2013), Sonolin (05-19-2013), WRXGuy1 (05-20-2013) |
| Tags |
| over 9000, ptuning, turbo kit |
| FA20CLUB.com Turbo Kit Sneak Peek.... | FA20Club.com | Forced Induction | 98 | 12-14-2013 02:34 PM |
| Sneak peek at new 57Xtreme? | vividracing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-07-2013 03:24 PM |
| Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. | P&L Motorsports | Forced Induction | 179 | 01-31-2013 08:32 PM |
| AFE PROTOTYPE EXHAUST: SNEAK PEEK! | autofashionfred | Engine, Exhaust, Transmission | 20 | 08-13-2012 02:22 PM |
| Tsukuba Circuit BRZ/FRS showdown Sneak Peek | AVOturboworld | BRZ First-Gen (2012+) — General Topics | 19 | 06-23-2012 12:13 PM |
