Old 05-10-2013, 09:48 AM   #365
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
I think MD just does OB2 readiness check for 1997 and newer cars.
Darryljr11 is offline   Reply With Quote
Old 05-10-2013, 11:51 AM   #366
bdub85
bdub85's Avatar
Drives: 2013 Raven FR-S
Correct. My catless Evo passed with flying colors. As long as you aren't throwing any CEL's or recently cleared the CEL's, you'll pass.
bdub85 is offline   Reply With Quote
Old 05-10-2013, 01:19 PM   #367
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Makes me wanna get uel headers but my exhaust is already too loud lol.
Old 05-13-2013, 05:07 PM   #368
brocktwalker
Drives: Scion FR-S Black
Any idea of a price and available date?
brocktwalker is offline   Reply With Quote
Old 05-15-2013, 02:05 AM   #369
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Since its a low mounted turbo, would any aftermarket headers be ok to install? EL UEL...
mnsayer is offline   Reply With Quote
Old 05-15-2013, 02:21 AM   #370
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
They've said throughout the thread that they'll provide details as they become available and when they're done testing.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 05-15-2013, 02:25 AM   #371
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
They've confirmed that any aftermarket header would work...including their own.
The Following User Says Thank You to ecko04 For This Useful Post:
mnsayer (05-16-2013)
Old 05-16-2013, 12:12 PM   #372
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by jsimon7777 View Post
Please don't think I'm criticizing this kit. I think it's by far the most awesome turbo choice I've seen. Well, the FB 750hp thing is cool too.
Any thoughts on a quick spool valve?
Did they finally confirm or show a dyno of 750 said HP?
SnapOv3st3r is offline   Reply With Quote
Old 05-17-2013, 11:50 AM   #373
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Here, http://www.ft86club.com/forums/showthread.php?t=30737, they show about 737 engine hp if you scale the 164hp baseline at about 22% drive train loss. I certainly prefer dynos run from steady idle (unspooled turbo) to redline, not from over 3000 after revving the engine to spool up. My understanding, and correct me if I'm wrong, is that helps them kick the turbo in at a lower rpm to get a nicer looking curve at the bottom.
Last edited by EAGLE5; 05-17-2013 at 12:54 PM. Reason: Put whp when I meant engine HP.
Old 05-17-2013, 12:10 PM   #374
andrew20195
Drives: 2013 Subaru BRZ
Here, http://www.ft86club.com/forums/showthread.php?t=30737, they show about 737whp if you scale the 164hp baseline at about 22% drive train loss. I certainly prefer dynos run from steady idle (unspooled turbo) to redline, not from over 3000 after revving the engine to spool up. My understanding, and correct me if I'm wrong, is that helps them kick the turbo in at a lower rpm to get a nicer looking curve at the bottom.
Turbo systems produce boost in response to load, and a Dynojet can't load the car at low rpm like they would in the real world, so low rpm will always look weaker than it really is. I too am curious how the various turbo kits perform in the 2k-3k rpm range.
andrew20195 is offline   Reply With Quote
Old 05-17-2013, 12:33 PM   #375
SnapOv3st3r
That's the 604hp thread. And I have NEVER seen a dyno operator that does a pull from idle. All dyno operators start at around 3k rpms that I have seen. Starting at 3k rpms have nothing to do with there being or not being a turbo. Even N/A they do a pull from 3k rpms. The pull is not in 1st gear remember, it's in the gear closest 1:1 ratio. Which is most the time 4th gear in most cars. You not going to do an idle pull in 4th gear.
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
WRXGuy1 (05-20-2013)
Old 05-17-2013, 01:31 PM   #376
EAGLE5
Dismember
EAGLE5's Avatar
Yeah, I meant engine HP. Edited above. And duh (on me), idle only works for autos. I suppose 1000rpm would work. A load bearing dyno would also be good. I guess I look at these charts and see more marketing than a real-world representation. That's why I like Car and Driver's 5-60mph test. It shows what the car will do more realistically.
Here is an example of a dyno from 1000rpm. http://www.bmw-post.com/2012/10/16/b...iesel-on-dyno/
Seems like useful info to me. For day to day driving, I spend most of my time between 1000 and 4000rpm, but mostly around 2000. I'd really want to know if a twin screw or turbo was giving any boost then. Certainly the factory turbos in many cars do.
Old 05-17-2013, 02:59 PM   #377
SnapOv3st3r
That was a dyno from Germany, so don't know what their specifics are. I'm in the states. Be it a low rpm, it's not idle still and he went up gears before doing the official pull.
Old 05-19-2013, 01:10 AM   #378
kanundrum
Drives: 2013 Whiteout FR-S
Some Pics from this weekends Dyno Day (Car made 392whp). Piping has been updated along with Oil Cooler (Located on the top right hand corner of the front end) Direct air Flow, Won't Block Intercooler or Radiator. Thanks for hosting the Dyno Day @Mrc@ptuning @ptuning
Video of Dyno Coming soon.
Oil Cooler Intake Vent is Right beside the Drivers Headlight
The Following 10 Users Say Thank You to kanundrum For This Useful Post:
AZFA20 (05-19-2013), Chewie4299 (05-20-2013), cmss2000 (05-19-2013), EAGLE5 (05-19-2013), Lonewolf (05-19-2013), ptuning (05-19-2013), ScottDRFT (05-20-2013), SnapOv3st3r (05-20-2013), Sonolin (05-19-2013), WRXGuy1 (05-20-2013)
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 01:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 07:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 11:13 AM
