Old 05-21-2014, 11:11 AM   #351
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Originally Posted by CARNZ View Post
I had some more ideas for diy guides adapting parts off the DIT cars, but I've since sold the BRZ. I'll make sure these pictures stay hosted for future reference for all.
Thanks for making sure this DIY stays up.
What other adaptations did you have in mind?
The Following User Says Thank You to Guillaume For This Useful Post:
Model Citizen (05-21-2014)
Old 05-21-2014, 07:58 PM   #352
Model Citizen
Lacking brains
Drives: frz
This
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 05-22-2014, 02:34 AM   #353
kavanagh
Fat on Corn Syrup
Originally Posted by Model Citizen View Post
This
And that
Old 05-30-2014, 11:09 AM   #354
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
@Model Citizen what are the specs on the Rad-T that you used?
zoth is offline   Reply With Quote
Old 05-30-2014, 12:22 PM   #355
Model Citizen
Lacking brains
Drives: frz
http://www.jagsthatrun.com/Pages/Par...rass-Tees.html
I got 1 9/16 x 1/2 since my sti sandwich plate used 1/2 on each barb. You can order pretty much any size you want there.
The 1 9/16 was incredibly tight, as in just about didn't work and only did with a bit of lubrication tight on the perrin hoses.
Old 06-03-2014, 07:14 AM   #356
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Just wanted to add a bit of data to this thread.
Went to Mid-O yesterday for a HPDE with the BRZ.
Car
-OFT stg 2 93 octane
-Revworks header, dp & Q300
-0w-20 motul
-stock coolant system
-full forrester oil cooler (obviously)
Ambient temps started out in the mid 70's.
-oil temps hovered around 230-235 while on track
Last session ambient temps were in the low 80's. I was making my best lap times at this point also.
-oil temps ranged 235-238 peaking at 240.
I figured this is fine for a NA car but I dont figure it would hold up too well with any future mods. I dont think additional water cooling mods would do much for it either. Would be time to upgrade to a thermostatic air\oil cooler I imagine.
Hope this helps.
cruizin01 is offline   Reply With Quote
Old 06-03-2014, 07:03 PM   #357
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I wonder if there is a way to combine this with a oil cooler plate( like a Setrab unit)
glamcem is offline   Reply With Quote
Old 06-03-2014, 07:11 PM   #358
glamcem
glamcem's Avatar
Car
-0w-20 motul
I figured this is fine for a NA car but I dont figure it would hold up too well with any future mods. I dont think additional water cooling mods would do much for it either. Would be time to upgrade to a thermostatic air to air oil cooler I imagine.
Hope this helps.
I wonder what would be easiest way to upgrade to a thermostatic air to air oil cooler, since we already tapped the coolant system and added the Forester pipe.. I think the ideal setup would be keeping this and add some sort of plate but I am not sure if that is possible
Old 06-03-2014, 10:09 PM   #359
keen as
keen as's Avatar
Drives: 86 GT MT
Perhaps a lower temp coolant thermostat would reduce the coolant temp
http://www.mishimoto.com/scion-fr-s-...mostat-13.html
keen as is offline   Reply With Quote
Old 06-03-2014, 10:30 PM   #360
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
I didn't keep great track of the coolant temps but I don't remember them getting past 200* so I don't think that's an avenue for looking into. I need to look around and see what other setups are seeing as far as both temps.
sent from HTC one M8 while driving
Old 06-03-2014, 10:52 PM   #361
keen as
keen as's Avatar
Drives: 86 GT MT
Yes, the coolant temp is stable. With a lower temp coolant thermostat, the coolant may be held at a lower temp. This enables a bigger difference (delta) to oil temp and may allow the cooler to work better and keep lower oil temps.
It's a thought. I haven't tried it. My car is NA.
Old 06-04-2014, 07:29 AM   #362
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
I understand that, Im just not gonna go that route at least while NA.
The Following User Says Thank You to cruizin01 For This Useful Post:
keen as (06-05-2014)
Old 07-09-2014, 10:06 PM   #363
fstlane
fstlane's Avatar
Drives: BRZ Limited
Thanks for the awesome DIY op. I installed mine today and everything went smoothly following your guide.
I went a different route on the manifold fitting as I found an oem Mercedes fitting the worked perfect.
http://www.ebay.com/itm/110860307014
Thanks again!
fstlane is offline   Reply With Quote
The Following 7 Users Say Thank You to fstlane For This Useful Post:
CARNZ (07-10-2014), FearBoy (07-09-2014), Guillaume (07-23-2014), Hanakuso (11-13-2014), hmong337 (12-01-2014), jcw99 (01-17-2015), keen as (07-14-2014)
Old 07-13-2014, 07:35 PM   #364
zoth
zoth's Avatar
Is the in and out of the oil cooler very specific? Can I flip them around? The setup I'm thinking might need them to be flip around. Thanks in advance.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
