Old 06-06-2016, 08:39 PM   #351
stevesnj
stevesnj's Avatar
Originally Posted by LastRep View Post
Just fill until it starts leaking out the fill plug?
Yep
My 2016 Build thread
Old 06-10-2016, 09:20 PM   #352
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
So I just got my trans replaced under warranty (Went out at around 44K completely). When I first picked it up, I could wiggle my shifter 2" to either side while it was in gear, which they discovered they didnt install a pin, so thats fixed. However the transmission feels, extremely notchy. Shifting gears kinda makes a crunch sound. Should I replace the fluid asap, or wait XXXX miles and then replace it with the suggested ones in this thread? (If I should wait, how long?) Bought the car used at 22K and she wasn't taken care of. The engine has been solid but my transmission has left me with a loaner for a total of 2 months since I've owned her. I really want to avoid further issues down the line.
Kerber23 is offline   Reply With Quote
Old 06-14-2016, 11:17 AM   #353
HeartbeaT91
Drives: 2013 Sterling Silver BRZ Limited
transmissions are covered under powertrain warranty (and not the bumper to bumper) right?
HeartbeaT91 is offline   Reply With Quote
Old 06-15-2016, 11:43 PM   #354
sato
sato's Avatar
Drives: Dodge Patitas
Yep
Sent from my E6653 using Tapatalk
Old 06-19-2016, 03:22 AM   #355
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Finally did this with Gear 300. First couple cold startups afterward felt a little bit rough shifting into gear, but now it's just buttery smooth. Unbelievable difference.
XanRules is offline   Reply With Quote
Old 07-06-2016, 11:53 AM   #356
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i changed tran & diff yesterday with Motul 300. my stock fluids were not looking that bad. fluid made improvement on shifting as well as grinding.
I couldnt use my pump to motul gear 300 bottle since cap size was different. it was very difficult just using their tubed-cap. i just squeezing bottle to filled half then use new bottle then combined both bottles then fill again. made all mess on my drive way.
Old 07-06-2016, 01:36 PM   #357
DarkSunrise
DarkSunrise's Avatar
Haha used the same process here. Didn't think it was too bad, but not looking forward to changing out my fluids again this fall especially with the smell.
2022 BRZ Build
2013 FR-S Build
Old 07-06-2016, 02:18 PM   #358
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I just used my normal fluid pump and shoved it into the Motul bottle, lol. I wish manufacturers would just settle on a standard though, pretty annoying to own tools that become useless as soon as somebody wants their packaging to be snazzier.
Old 07-06-2016, 02:42 PM   #359
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by 504 View Post
I've tried ALL the high end 100% synthetic fluids (yes I have binned 500 dollars plus). Stock fluid was amazing, it was my first manual tranny and naturally thought I could improve with fresh stuff to get rid of break in material. Oh was i wrong. Redline anything (I tried my alone, mt90) felt like death. Honestly running no fluid would've been better, second gear crunched almost every hit and got to the point I avoided driving
I stepped upto amsoil synchromesh and it was better, still Grindy on second, added 1 quart amsoil mt90 and that improved nothing.
Next up a fresh dose of gear 300 by motul, I remember it being similar to amsoil
Finally pentosin mtf2 and is so far the best. My second never grinds anymore but sometimes difficult or clanky. It's definitely the best of the fluids and becomes butter when you push the car.
I don't know anymore, maybe synchros damaged alittle after redline but I have driven my friends 86 which is older than mine as well as a brand new one and both feel butter in any condition on stock fluid.
*Sigh* try to do something good and you get yourself into a hole
I believe our trans is the biggest variation on this car. Lot units has different feel from each others. My friends used frs that was FIed is butter smooth & feels wonderful with everything stock......
I had grindy 2nd gear with stock fluid & it was so bad. Tried eneos & motul after that.... Motul made life a lot easier for me thou I think it's too smooth that it takes away good amount of feel.
Old 07-06-2016, 04:09 PM   #360
zc06_kisstherain
Drives: SWP BRZ
seriously, they need to use standard cap...
i dont want to do this again for next change
x 2
Old 07-06-2016, 05:26 PM   #361
qqzj
Drives: MDX, Camry
why not just dump it to a mobil 1 engine oil bottle and pump away? it is not that hard.
x 2
qqzj is offline   Reply With Quote
Old 07-06-2016, 05:29 PM   #362
gramicci101
Off Topic
I don't understand. With the spout in the Motul bottle, I was able to change both trans and diff fluid without a pump at all. Just hold the bottle up above the fill hole so it can pour down. Which is good, because I don't have a fluid pump.
Old 07-06-2016, 08:29 PM   #363
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I didn't use Motul for the trans, but for the diff I couldn't get the last 1/4 of the bottle out with the built in funnel. With a pump I can get 99% of it out...
Old 07-06-2016, 11:45 PM   #364
zc06_kisstherain
Drives: SWP BRZ
how? i cant move up because there is no room
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
