Old 05-03-2013, 03:58 AM   #351
Staf00
Drives: SWP DZE
Hmm yes, reference numbers do match...but $20.74 for a 5 pack just seems too cheap. Unless "5 PAC" doesn't mean 5 pack lol.
Staf00 is offline   Reply With Quote
Old 05-03-2013, 06:38 PM   #352
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I just replaced the Tranny oil with Motul 300 and all I can say is wow. Very noticeable smoothness on each shift. Highly recommend it.
Old 05-16-2013, 07:43 AM   #353
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Gem:
To those of you who have enjoyed my recommendation for Pentosin, I have found something less expensive that also fits the bill, has the right specs and works great in our MT. Recently filled mine with this stuff I found at the Nissan parts counter, for like $12 and on amazon for like $19, still cheaper than pento in that you may be able to get this without having to pay shipping from a specialty vendor like with Pento(tho its also bmw branded LL- MTF2) the Elf should be able to be had at ANY nissan counter.
Its a 75w-80 GL4, with a 8.5cst
http://www.lubadmin.com/upload/produ...ang_1/7194.pdf
amazon asin B00ARDCYCC
enjoy!
-g
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 05-16-2013, 09:11 AM   #354
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Hi guys, I couldn't find a proper / quick way to get the Pentosyn here, so I went with Pennzoil Synchromesh. I used that oil in a k20 honda in the past and a celica with very good results.
So far, I've put 200 KM on it and while the difference it not night and day (this transmission is great stock in my opinion) it does makes a difference. The shifter lands with less effort into each gear and I need lev "revs" when I double clutch when the box is still cold. I can litteraly go into any gear at any time without reminding myself if the car is warmed up or not..I like that.
The notchyness is still there in 2nd and 3rd but that's how this box is designed it seems. The main reason for me to change the fluid was because I drive in the winter and the stock fluid was totally crap, it wouldn't let me shift into 1st until I was completely stopped and sometimes wouldn't go come out of 1st and not even want to go into 2nd.
Linky
Total cost 45$ including taxes.
Rayme is offline   Reply With Quote
Old 06-08-2013, 07:48 PM   #355
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
So I finally had time to order this, along with 3 gallons of Idemitsu 0w-20. Since I had to basically order from Autohaus, this was a good way to get free shipping while also getting a good oil.
Doing the fluid change on simple ramps shouldn't be too big a problem right? I don't have access to a lift. Need to go find a tube that will fit my funnel...
My driveway is slightly slanted as well, will that make a difference or is the fill hole centered pretty good?
michaelahess is offline   Reply With Quote
Old 06-08-2013, 10:26 PM   #356
roddy
roddy's Avatar
Drives: '13 Ultramarine
You'll need to get the front and rear of the car fairly even, as the transmission needs to be filled to the bottom of the "fill" hole on level ground. Having the car up in the front only could lead to under/over filling, depending on how close the fill hole is to the center of the transmission. Too little, and you risk transmission damage. Too much will likely lead to leaks.
Old 06-08-2013, 11:23 PM   #357
michaelahess
Cool, I'll have the car facing down the driveway and put it on the ramps, that will get it nearly level. Just fill to bottom of fill hole right? Thanks!
Old 06-09-2013, 02:07 PM   #358
vgi
Drives: frs
Originally Posted by Hawaiian View Post
Gem:
since he promised to send his pentosin fill for uoa and now he switched to elf, any results yet on pentosin?
vgi is offline   Reply With Quote
Old 06-09-2013, 03:35 PM   #359
wootwoot
Drives: FRS
He switched off this stuff? Is there a thread about his new fill? He pushed this stuff so hard... I am amazed he is using something else.
wootwoot is offline   Reply With Quote
Old 06-09-2013, 05:47 PM   #360
Hawaiian
That guy
Hawaiian's Avatar
Scroll up.. same specs as petosin, just less expensive.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 06-10-2013, 04:44 PM   #361
vgi
Drives: frs
@Hawaiian well, since it looks like it's been replaced with Nissan MTF, what about the latter? would you pls ask gem about Nissan MTF and also uoa results on pentosin?
Old 06-25-2013, 11:00 PM   #362
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
well the cheapest pricing i've found is from this thread from here: http://store.propartsusa.com/pentosi.../i-543929.aspx
almost the same price as the nissan that he mentioned
Old 06-26-2013, 02:08 AM   #363
KpAtch3s
Drives: 2013 Scion F-RS
Just read this whole thread...I've been having grinding issues going into 6th recently. Usually seems to be under heavy load from 3rd or 4th gear.
Thinking about making the switch to pentosin in hopes of fixing this problem. Only 4.2k miles on the car!
KpAtch3s is offline   Reply With Quote
Old 06-26-2013, 03:24 AM   #364
ft_sjo
Drives: GT86
It'll make two-fifths of fuck'all difference. The issue isn't the oil, even though the placebo'ites will argue it to the death.
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
