go_a_way1
Old 10-08-2017, 07:40 PM   #3557
Devin11498
Devin11498's Avatar
Drives: 2013 Subaru Brz Limited
Last Check
So just to get a confirmation. the 255's should fit well once I have coils? Only reason I'm set on this size tire is bc ambit has a pretty good wheel and tire package. and for the wheels I want this is one of the size options. 265 is too big for what I would like and the 245 is a /40 and one of you already confirmed that would be too tall
Here are the other options below-
245/40/R18
255/35/R18
265/35/R18
Coils of choice - Tein Flex Z
Planned Setup
Wheel
Ambit RE02
18x9.5 +38
Tire
Federal RS-R 255/35/R18
Devin11498 is offline   Reply With Quote
Old 10-17-2017, 12:45 PM   #3558
CAPSLOCK
CAPSLOCK's Avatar
Drives: Miata, 17' BRZ
Please forgive me, my math skills are rubbish. I’m running 17x8 +45 wheels with stock suspension. If I run a 12mm spacer, would I be “flush” or am I going to poke too much?
CAPSLOCK is offline   Reply With Quote
Old 10-18-2017, 04:13 PM   #3559
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The phrase "Poke too much" is totally subjective. A 17x8 +45 with a 12mm spacer is essentially a +33 offset wheel. An 8" wide +35 offset wheel is generally considered flush. So your wheel will stick out 2mm more.
Look at post #7. He has stock suspension with an 8" wide wheel and a+32 offset. Looks good to me. if you add camber bolts, it will help with the poke. they are very inexpensive.
http://www.ft86club.com/forums/showthread.php?t=25207
I LIKE TIRES!
Old 10-20-2017, 10:03 PM   #3560
Anthonyc77
Drives: 2017 Toyota 86 Halo
Tried out a set of 17x9 +45 rpf1s, and on full lock they hit the outer tie rod. No big suprise there its been documented a bunch on these forums, however 18x9.5 +38 seems to be a pretty popular size but only gives an extra 1mm more inner clearance. I have heard of people with the 17x9 +45 rpf1s running 3mm spacers and still not having enough clearance from the tie rod, so was curious why or how the 18x9.5 +38 didnt have any issues? Just the extra inch in diameter somehow move the wheel further away?
Anthonyc77 is offline   Reply With Quote
Old 10-31-2017, 07:28 PM   #3561
Chrisu
Chrisu's Avatar
Drives: 2014 Scion FRS
Hey guys I'm new here and a proud 86 owner Just installed an Invidia N1 exhaust last week and now I'm looking into getting some wheels and tires and I'm here for some advice.
Will this fit on STOCK suspensions(I'll get aftermarket suspensions later) without any issues?
18X8.75 +36 offset all around
225/40/18 tires all around
I'm trying to keep my budget under 1k for the wheels and tires. I already have my eyes on a few options. Any recommendations or feedback are greatly appreciated! Thank you!
Chrisu is offline   Reply With Quote
Old 10-31-2017, 09:36 PM   #3562
swarb
Shape of the barrel is different and different wheels mean different results.. Also every car is slightly different. 2-3mm cleaeance isn't exactly a lot. Some people have problems, some don't. I personally would just get spacers or lower offset.
Old 10-31-2017, 09:40 PM   #3563
swarb
You are good. Suggestion to get decent tires and not cheapies.
Old 11-03-2017, 12:46 AM   #3564
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
Hey guys,
Just ordered a new set of wheels for my BRZ. Konig Ultraform 17x9 +40
Will I have any clearance issues with ~1" Lowering Springs, 5mm Spacers all around and 245/40/17 tires?
I was also thinking of adding the Subaru Crash bolts in the front for Camber adjustment
NyX_Nick is offline   Reply With Quote
Old 11-07-2017, 04:22 PM   #3565
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by NyX_Nick View Post
Will I have any clearance issues?
Nope.
I LIKE TIRES!
Old 11-07-2017, 06:39 PM   #3566
NyX_Nick
Nope.
Are those wheels similar offset to mine? I've had a fair few people say that it'll be close, especially in the front, but should fit. I'll test fit them first, but if not then it's not a huge deal, I'll just get Flex Z's or something
Old 11-07-2017, 06:47 PM   #3567
Leonardo
Country Boy 4 Life
Leonardo's Avatar
17x9 +40 with a 5mm space is essentially a +35 offset wheel. You shouldn't have strut clearance issues, and with camber bolts, you also shouldn't poke that much either. What tires are you getting?
I LIKE TIRES!
Old 11-07-2017, 06:51 PM   #3568
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The is is a test-fit of the same wheel (konig ultraform) and offset but 8" wide. I already have about 1.5 degrees of negative camber using Toyota crash bolts.
Twinz is offline   Reply With Quote
Old 11-07-2017, 06:51 PM   #3569
NyX_Nick
Oh sorry, I saw a picture attached to your comment on the Tapatalk app that showed much more aggressive wheels than the ones I was fitting, that's why I asked.
As for tires, I'm probably gonna go with Yokohama S.Drives or BFG G-Force Sport Comp-2's. Whichever one gives me the better rebate when Spring time rolls around
Old 11-07-2017, 06:52 PM   #3570
NyX_Nick
Originally Posted by Twinz View Post
The is is a test-fit of the same wheel and offset but 8" wide. I already have about 1.5 degrees of negative camber using Toyota crash bolts.
That picture is immensely helpful, thank you
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
