go_a_way1
Old 09-19-2017, 03:52 AM   #3543
azynneo
any options for running a 10width in the rear with a 265/35 meaty tire to prevent rubbing? I'm sitting at -2.3 rear camber and not even lowered that much but it's seeing rub at each and every small dip. Will running an after market LCA and more camber help out? Or am I looking at fender pull / widebody.
azynneo is offline   Reply With Quote
Old 09-23-2017, 12:26 PM   #3544
HECK EM ALL
Drives: Asphalt 2013 FR-S
Will this fit? (width, offset and tire size Qs)
HECK EM ALL is offline   Reply With Quote
Old 09-27-2017, 04:23 PM   #3545
wally
SosMula
wally's Avatar
Drives: 2013 DD White pearl
Any1 know if these wheels would fit on my GT86? Rota Grid 18x9.5 ET(23)
Rota Grid 18x9,5 ET+38 Valenti CBW GCS Shark Antenna Acrylic Headlight Covers
wally is offline   Reply With Quote
Old 10-01-2017, 03:05 PM   #3546
krat0$
Drives: 2017 BRZ
Hi guys! I'm quite new on this one. I have a 2017 brz with the performance package and I'm planning to get a new set of wheels. Would a 17x8 +45 sit perfectly on my car with the stock suspension and wouldn't rub the brembo calipera and would it look better than the stock ones in terms of the aggressive look? TIA
krat0$ is offline   Reply With Quote
Old 10-04-2017, 02:22 PM   #3547
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
16x6.5 +55 JDM Legacy BBS Wheels
Looking at these for a winter setup on my car, and wondering if these wheels will fit. They are 16x6.5 +55 JDM Legacy BBS Wheels.
JBezugs is offline   Reply With Quote
Old 10-04-2017, 04:44 PM   #3548
Devin11498
Devin11498's Avatar
Drives: 2013 Subaru Brz Limited
Will this fit?
I have a general idea when it comes to Tires and wheels but not enough to trust my judgment. My Brz suspension is currently stock. I do plan on getting coils before I get the wheels. I'm just curious as to if it will rub? What do yall think? Will I have any issues fitting these wheels on stock suspension? Would I need spacers possibly? I have no idea, thanks
Coils of choice - Tein Flex Z
Planned Setup
Wheel
Ambit RE02
18x9.5 +38
Tire
Federal RS-R 255/35/R18
Devin11498 is offline   Reply With Quote
Old 10-04-2017, 05:22 PM   #3549
swarb
It won't fit without 3-4++ camber all around and/or 225/40 tires or smaller. The offset for 9.5 is 35-38 up to 40(may need 2-3mm spacer up front)
The Following User Says Thank You to swarb For This Useful Post:
wally (10-07-2017)
Old 10-04-2017, 05:23 PM   #3550
swarb
Not all wheels are the same. The rpf1 17x8 +45 fits, but the +35 for example doesnt. You need to look for the PP wheel fitment thread.
Old 10-04-2017, 05:24 PM   #3551
swarb
Yes those should be fine.
JBezugs (10-04-2017)
Old 10-04-2017, 05:28 PM   #3552
swarb
Planned Setup
Wheel
Ambit RE02
18x9.5 +38
Tire
Depends how low you are, the fronts should be ok, but the rears will be very close to the bumper tab and will probably rub a little. RSR's run wide. Also check out the newer RSRR. At full lock or if you are lower than 1.5 inches they will fit very tightly and may rub the side marker area.
Old 10-04-2017, 05:34 PM   #3553
swarb
http://www.ft86club.com/forums/showthread.php?t=28174
+7mm offset difference in the thread above.
Outside wheel clearance should be fine. I only worry about caliper clearance, but I highly doubt you will have any problems.
Old 10-04-2017, 05:38 PM   #3554
Devin11498
Devin11498's Avatar
I don't know yet how low I might want to go. I'm not trying to get some stance but would like a low fitment. I also have the option of going with a 245/40/R18 instead of the 255/35/R18. As mush as I would like to run a 255 I wouldn't mind a 245. Anything is better than the stock tires lol. Do you think the 245 would be good enough to where I wouldn't have to worry about any rubbing what so ever?
Old 10-04-2017, 06:00 PM   #3555
swarb
245/40 is too tall, you will rub more. 245/35 is closest to stock size.
Old 10-06-2017, 07:21 PM   #3556
krat0$
Drives: 2017 BRZ
Thanks!
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
