#338 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
Hire some new people to come out to CA and get this stuff rolling. I officially nominate myself as Logistics Operator so that your staff can focus on the product improvements you guys have been making. I bring experience and a Limited BRZ
| The Following User Says Thank You to Luckrider For This Useful Post: | Shiv@Openflash (03-17-2014) |
#339 | |
http://www.ft86club.com/forums/showp...8&postcount=76
#340 | |
#341 | |
Drives: 2013 FRS
#342 |
Man, it never ends! Don't know what to spend money on anymore... Seems like you have something new every few weeks!
#343 | |
#344 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
#345 | |
I would bet that what you did was reduce the values enough that it doesn't affect coarse correction at all? jamesm's suggestion was to move the timing from the advance down to the base timing so that you don't change the overall timing (assuming an IAM of 1.0), but your method would definitely work to stop it from reducing IAM too. You may have lost the tiniest bit of power in that range, but I doubt it's noticeable.
#346 |
Not getting knock is better than ignoring it just to see a 1.
#347 |
Drives: Toyota Gt86
When are we gonna see the 1.6 maps out?
@shiv@vishnu |
#348 | |
http://www.ft86club.com/forums/showp...0&postcount=64 most of the values in the knock prone area are still above 3.9. Some were already below this threshold . I specifically did not want to "effectively" disable coarse correction by moving all the timing to the base map or reducing values below 3.9. The max retard amount was 0.35 of a degree. I have used tactrix logging which can monitor fbck & flck at 20Hz and have logged noticeably less occurrences of both and the values are also less for fbck and flck in the knock prone areas with these changes. I believe it the less knock severity and less occurrences that are resulting in the ECU not entering coarse correction mode and dropping IAM. If your IAM is dropping to even to 0.7 then your pulling 30% of the timing values in the entire knock correction table for the entire rpm/load range which is going to result in retard amount somewhere from 1 to 3 degrees which is going to rob you of far more power than my 0.35 degree adjustments in a few cells I believe. I am not saying this will work for everyone but its working for me on Aussie 100 RON fuel.will try on 98 next week. Last edited by steve99; 03-18-2014 at 07:39 AM. |
#349 |
Awesome. Does this mean we are that much closer to seeing you progress to the turbo? Someone needs to really hit the stock .bin file harder to find out how the WRX handles boost. I can only imagine there is a way to do it, otherwise other cars would not be so successful with RomRaider.
#350 |
Drives: 2021 GR Supra A91 Edition
Hey gang,
I just got (and installed) my OFT this afternoon. Flashed stage 1, feels good - quite a bit sharper, a bit more eager to rev. Good news. Excited to get a header and run some E85. When I connect it to the OF Manager on my PC I see that my OFT is running FW v. 1.24. Other than a new map format, is there a compelling reason for me to upgrade? Thanks for your advice - there are so many "open flash xxx" threads going that I get lost sometimes. :-) DJ |
| The Following User Says Thank You to Sirsimon For This Useful Post: | Shiv@Openflash (03-17-2014) |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 12:12 PM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 01:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 10:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 01:10 AM |
