Old 03-17-2014, 03:41 PM   #337
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by AdrianG View Post
I know you've got a lot on your plate and unless something terrible happens that probably won't change. Just letting you know there is interest for this.
Absolutely. I'd like to see it implemented asap as well since it's really not that much work
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
gonzo (03-19-2014)
Old 03-17-2014, 03:52 PM   #338
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Hire some new people to come out to CA and get this stuff rolling. I officially nominate myself as Logistics Operator so that your staff can focus on the product improvements you guys have been making. I bring experience and a Limited BRZ
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Shiv@Openflash (03-17-2014)
Old 03-17-2014, 05:27 PM   #339
wparsons
wparsons's Avatar
Originally Posted by s2d4 View Post
Yeah, won't be doing that.
What jamesm was talking about was for flkc, what we are seeing is fbkc.
Negative, he was talking about FBKC too.
http://www.ft86club.com/forums/showp...8&postcount=76
Originally Posted by jamesm View Post
Most of the tip in knock I see shows up in fbkc. It'll write into fine learning sometimes though, particularly when tipping in to a long pull.
flickr
Old 03-17-2014, 05:34 PM   #340
s2d4
s2d4's Avatar
Yes, I was referring to the IAM "fix" you were talking about.
Old 03-17-2014, 05:41 PM   #341
Shiv@Openflash
Drives: 2013 FRS
We just ordered an Innovate LC-2 so the ball is rolling
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
FrsDuke (03-17-2014), Luckrider (03-17-2014)
Old 03-17-2014, 05:56 PM   #342
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Man, it never ends! Don't know what to spend money on anymore... Seems like you have something new every few weeks!
1Cor10:23 is offline   Reply With Quote
Old 03-17-2014, 06:02 PM   #343
steve99
Drives: FT86
Make it four, unless you're counting me in the original 3.
This isn't unique to Shiv's tunes at all, I would bet that if people were logging most canned tunes (and even lots of custom tunes) they'll find the exact same thing happening. I haven't pulled any logs on the stock tune, but I know I get knock on the stock tune occasionally on heel/toe downshifts on the throttle blip (clutch in, so no real load). I would imagine the same behavior would show up in logs on the stock tunes.
The "fix" for it is to change how the ignition tables are mapped out a bit.
You basically have to minimize (or zero out) the advance cells in certain rpm/load ranges and move all the ignition advance to the base timing table.
The final applied ignition advance is base timing + (IAM * advance timing).
The formula for figuring out if a knock event goes into fine or coarse (dropping IAM) correction is more complicated, but the only part that matters is that if the IAM * advance portion is under a certain value (2.9 or 3.9 IIRC?) it won't go into coarse correction and the IAM will stay up.
I call it a "fix" more than a real fix because you'll still get knock (which happens even with a LOW IAM, and even on e85), but it won't take out the IAM in the process.
Disclaimer, I haven't actually edited my own tune for this yet, just basing it off what other people have been experimenting with.
@jamesm posted a bunch of good information about this before being banned, and @nelsmar has posted a few times too IIRC.
If you look at some of my earlier posts i have fixed this issue of iam dropping i my car by small reduction in rpm/load advance cells in the ignition advance table, without resortiing to disabling course correction .
Old 03-17-2014, 06:29 PM   #344
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
OFW FTW!
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-17-2014, 08:20 PM   #345
wparsons
wparsons's Avatar
As far as I know, you can't disable coarse correction, but you can stop knock from affecting it by reducing the values in the advance cells so they're lower than a threshold (2.9 or 3.9 IIRC).
I would bet that what you did was reduce the values enough that it doesn't affect coarse correction at all?
jamesm's suggestion was to move the timing from the advance down to the base timing so that you don't change the overall timing (assuming an IAM of 1.0), but your method would definitely work to stop it from reducing IAM too. You may have lost the tiniest bit of power in that range, but I doubt it's noticeable.
flickr
Old 03-17-2014, 08:46 PM   #346
s2d4
s2d4's Avatar
Not getting knock is better than ignoring it just to see a 1.
Old 03-17-2014, 09:11 PM   #347
Victor Draken
Drives: Toyota Gt86
When are we gonna see the 1.6 maps out?
@shiv@vishnu
Victor Draken is offline   Reply With Quote
Old 03-17-2014, 09:43 PM   #348
steve99
Drives: FT86
nope thats not what I did see here
http://www.ft86club.com/forums/showp...0&postcount=64
most of the values in the knock prone area are still above 3.9. Some were already below this threshold .
I specifically did not want to "effectively" disable coarse correction by moving all the timing to the base map or reducing values below 3.9.
The max retard amount was 0.35 of a degree.
I have used tactrix logging which can monitor fbck & flck at 20Hz and have logged noticeably less occurrences of both and the values are also less for fbck and flck in the knock prone areas with these changes.
I believe it the less knock severity and less occurrences that are resulting in the ECU not entering coarse correction mode and dropping IAM.
If your IAM is dropping to even to 0.7 then your pulling 30% of the timing values in the entire knock correction table for the entire rpm/load range which is going to result in retard amount somewhere from 1 to 3 degrees which is going to rob you of far more power than my 0.35 degree adjustments in a few cells I believe.
I am not saying this will work for everyone but its working for me on Aussie 100 RON fuel.will try on 98 next week.
Old 03-17-2014, 10:16 PM   #349
Luckrider
Luckrider's Avatar
Awesome. Does this mean we are that much closer to seeing you progress to the turbo? Someone needs to really hit the stock .bin file harder to find out how the WRX handles boost. I can only imagine there is a way to do it, otherwise other cars would not be so successful with RomRaider.
Old 03-17-2014, 10:26 PM   #350
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Hey gang,
I just got (and installed) my OFT this afternoon. Flashed stage 1, feels good - quite a bit sharper, a bit more eager to rev. Good news. Excited to get a header and run some E85.
When I connect it to the OF Manager on my PC I see that my OFT is running FW v. 1.24. Other than a new map format, is there a compelling reason for me to upgrade?
Thanks for your advice - there are so many "open flash xxx" threads going that I get lost sometimes. :-)
DJ
Sirsimon is offline   Reply With Quote
The Following User Says Thank You to Sirsimon For This Useful Post:
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
