Old 09-07-2012, 02:05 PM   #337
2forme
Originally Posted by AJUSA.com View Post
What lids are you guys using that are having screw problems. One has a foam strip on the bottom, the other did not.
Mine came with the foam backing separate... so you could apply to either lid.
The Following User Says Thank You to 2forme For This Useful Post:
AJUSA.com (09-07-2012)
Old 09-07-2012, 03:59 PM   #338
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Now that you mention this, if I were to switch to the silver lid, I won't have any insulation on that lid.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-07-2012, 05:01 PM   #339
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
I still have no bogging issues, Ive been meaning make a video if my tests just so you can see first hand how im testing it but yea, 1st gear roll @ 1000RPM its a smooth climb, given theres no torque in that range but it does not bog in anyway, reacts just how it should, I still really wonder what it is, I know 2forme was solved with a tune but how come not all of us have the issue. Wierd
Bu-Tang is offline   Reply With Quote
The Following User Says Thank You to Bu-Tang For This Useful Post:
Old 09-07-2012, 05:02 PM   #340
Bu-Tang
I asked for a second one when he sent me another clamp , however now im missing 2 screws I hope they will send me when I send my rebate Monday, tho those bolts are easy to find.
civicdrivr (09-07-2012)
Old 09-07-2012, 05:10 PM   #341
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Only one screw has backed out on my lid the other have no moved at all. Right now I'm rocking 3 screws but they are held in there real good.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 09-07-2012, 05:12 PM   #342
lopro25
lopro25's Avatar
Drives: Hot Lava FR-S
Was it the bottom-right screw by chance? That one backed out on me but all the other ones are in there strong.
Sent using mobile Tapatalk App
lopro25 is offline   Reply With Quote
Old 09-07-2012, 05:18 PM   #343
UncleFester
I had minor issues the first day I drove mine, then those went away. However, I noticed earlier this week that I have a hard fuel cut [assumed] at WOT.
So... now the diagnosing begins.
UncleFester is offline   Reply With Quote
Old 09-09-2012, 11:14 AM   #344
Visconti
Drives: 05 STi
Did you locate a cable so you could try and data log your STOCK TUNE?
Visconti is offline   Reply With Quote
Old 09-09-2012, 12:56 PM   #345
whataboutbob
AutoX-10/10ths every run
Originally Posted by Plxdjake89 View Post
So, I just received my intake today, took the liberty of slapping her on.
Before
Attachment 13170
After
Attachment 13171
I decided to leave the resonator tube, and....I wasn't really able to roll around seeing as how I had a couple of these Attachment 13172
Just from revving in the garage sounds great, can't wait to take her out tomorrow
MMMMM. Newcastle! Fine choice.
Old 09-09-2012, 02:02 PM   #346
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
You know it!
Plxdjake89 is offline   Reply With Quote
Old 09-09-2012, 03:16 PM   #347
Reason
Reason's Avatar
Drives: Whiteout 6MT FR-S; E30 BMW's
Also had one of the screws back out on mine. I reinstalled them with slightly larger washers. They don't seem to be backing off this time, but it took a month or so last time so time will tell.
For reference I'm using the black lid. Foam was applied at the time of install as the foam does not come pre-applied to one of the lids (which makes sense if you included the second lid as a customer choice for which they would like to use)
Reason is offline   Reply With Quote
The Following User Says Thank You to Reason For This Useful Post:
AJUSA.com (09-10-2012)
Old 09-09-2012, 03:57 PM   #348
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I had a couple screws back out. There was nothing wrong with the screws, seemed like a mistake during install on my part. My thoughts were it has to do with the foam seal being compressed/heated during use and/or sun. I figured it got softer and or more compressed when the other screws went in so there was less pressure against the plate. Which would have made it more susceptible to vibration. Either way, i went to home depot and spent $3 on some new screws and washers and havent had a problem since. Plus the stainless replacements match the aluminum much better anyways .
Edit Add: I don't think these issues are in any way bad for Airaid. I mean it's not like the parts are faulty, a bit of loctite, or more careful installation would have prevented the issues. It really says a lot when the company is so behind their product that they'll rush out parts to customers no questions asked.
Ravenlokk is offline   Reply With Quote
The Following User Says Thank You to Ravenlokk For This Useful Post:
Old 09-09-2012, 08:15 PM   #349
Subaruwrxfan
Subaruwrxfan's Avatar
Drives: 2015 Mustang EcoBoost
Had two screws rattle out on mine, so rocking it with only two screws for now until I can find some replacement screws.
Check out my BRZ videos on my YouTube page: youtube.com/subaruwrxfan
Subaruwrxfan is offline   Reply With Quote
Old 09-09-2012, 08:33 PM   #350
W2
W2's Avatar
Drives: Firestorm FR-S
Originally Posted by Keith@AIRAID View Post
Hey guys, on the loose screw issue I would like to point out that we use the same brass threaded inserts on all of our kits and have never had this number of complaints about them coming loose. My first thought was that it's because it's a boxer and it runs a little rough, but that doesn't make sense when diesel's and UTV's are fine. All I can think is maybe the black coating changed something? We usually use plain stainless steel hardware, but we made the lid and hardware black at the forum's request.
Either way, please understand that this can happen when you lead with the first product of any kind. We went above and beyond on R&D, but we still can't match the thousands of miles on hundreds of vehicles that you guys will put our product through. I hope the community can see our commitment to stand behind the product and make everything right.
A step has been added to the instructions about using thread locker, and that should be all that is needed.
The issue I found was the foam seal, this broke and compressed around the screw holes and caused the lid to loosen up with the excess space. I'm assuming the engine heat and thin area around the screw hole is what made the foam deteriorate. I just finished a 1500 mile road trip and they are still good to go now after the re-tightening.
W2 is offline   Reply With Quote
Official Hawaii Pictures Thread touge-n00b Hawaii 172 08-24-2014 11:15 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 08:27 AM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 07:36 PM
Does anyone have pictures of TRD intake Pekingduck Engine, Exhaust, Transmission 2 04-26-2012 11:37 PM
