06-30-2013, 09:32 AM | #337 |
Drives: 2013 FR-S whiteout
06-30-2013, 10:52 AM | #338 |
Drives: Viper, Mustang, FD RX7, FFR GTM
The motor spins semi freely. And the compressor still has an inducer connected to the exducer even when not moving lol.
06-30-2013, 04:16 PM | #339 |
Drives: GT86
You may not have much relevant experience with turbocharged engines, but I can try and clear something up for you. A lot of engines, particularly those with larger turbochargers, do not spin the turbo until load demands it. Particularly when the oil is cold.
06-30-2013, 05:04 PM | #340 |
Drives: Over the hill WRX
My WRX turbo generates light air pressure even at idle. I have a port for water injection and you can feel air pumping out at idle.
06-30-2013, 05:11 PM | #341 |
I've installed a turbocharger or ten. A stationary compressor wheel is going to be a huge bottleneck cruising down the highway. A stationary car isn't going to require a lot of air to idle or rev.
The Following User Says Thank You to SloS14 For This Useful Post: | DylanFRS (06-30-2013) |
06-30-2013, 05:18 PM | #342 |
Drives: 2013 Subaru BRZ
That seems like a pretty simple issue to work out as long as the alternator can feed the batteries enough current to cover whatever free wheeling/spinning the compressor needs not to be a restriction while cruising. If not, alternator upgrade? This system seems like it could have enough potential to investigate bigger alternator, more batteries, larger compressor etc...
06-30-2013, 05:44 PM | #343 | |
Drives: '13 GBS Subaru BRZ
The other answer as has already been mentioned is a bypass when the compressor is not in use. Edit: A centrifugal clutch on the compressor wheel is also a possible solution but again adding to the complexity.
06-30-2013, 05:51 PM | #344 | |
The new motor controller is in that will detect low pressure and pulse the turbo to maintain atmospheric pressure :-) That will go on the car this week Sent from my HTC One using Tapatalk 2 |
06-30-2013, 05:54 PM | #345 |
Drives: VW
'Restriction' requires airflow, and enough that the constriction of the compressor creates a delta P. The throttle plate is a variable constrictor and creates all the restriction of airflow up to a certain point. Once the compressor constriction has enough flow it will create a restriction (delta P). Typically, 0-50% TB there is no P drop across the compressor and therefore no restriction. Above 50%... opening the TB slightly more than normal will maintain airflow. There is no loss @ highway cruising speed. From 50% to on set of boost (~80%), partial activation to maintain stock intake slight vacuum can be signalled by the delta P.
The Following User Says Thank You to Robftss For This Useful Post: | serialk11r (06-30-2013) |
06-30-2013, 08:42 PM | #346 |
Drives: it has 4 wheels and a motor
Im gonna guess that this kit is making more power than innovates SC at sea level. Simply because of the lack of parasitic loss.
Their SC kit is Only running 4.5 psi on stage 1. |
06-30-2013, 09:04 PM | #347 | |
One psi that lacks parasitic drag equals more than 20hp from our experience. I mean we made 30 peak HP with 1.3 psi :-) not to mention 90tq with only 3 psi. Sent from my HTC One using Tapatalk 2 |
06-30-2013, 09:57 PM | #348 |
Drives: 2013 Scion Frs(Scarlet)
i really want this kit
07-01-2013, 12:23 AM | #349 |
Drives: 2013 Firestorm FRS
07-01-2013, 12:26 AM | #350 |
Reverse Burnouts
Drives: 2013 Argento FRS
Wrx is fitted with a small turbo stock, a light impeller could produce positive intake pressures even at idle
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
