Old 06-30-2013, 09:32 AM   #337
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Originally Posted by serialk11r View Post
So what? A supercharger that's not spinning still has a giant gap for air to go through.
Compressor wheels have very tight tolerances to the housing. Not enough air for an engine to breath freely. It would be like breathing through a straw
Old 06-30-2013, 10:52 AM   #338
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
The motor spins semi freely. And the compressor still has an inducer connected to the exducer even when not moving lol.
Toma is offline   Reply With Quote
Old 06-30-2013, 04:16 PM   #339
ft_sjo
Drives: GT86
You may not have much relevant experience with turbocharged engines, but I can try and clear something up for you. A lot of engines, particularly those with larger turbochargers, do not spin the turbo until load demands it. Particularly when the oil is cold.
Old 06-30-2013, 05:04 PM   #340
FT_Monk
Drives: Over the hill WRX
My WRX turbo generates light air pressure even at idle. I have a port for water injection and you can feel air pumping out at idle.
FT_Monk is offline   Reply With Quote
Old 06-30-2013, 05:11 PM   #341
SloS14
SloS14's Avatar
I've installed a turbocharger or ten. A stationary compressor wheel is going to be a huge bottleneck cruising down the highway. A stationary car isn't going to require a lot of air to idle or rev.
The Following User Says Thank You to SloS14 For This Useful Post:
DylanFRS (06-30-2013)
Old 06-30-2013, 05:18 PM   #342
Dodzilla
Drives: 2013 Subaru BRZ
That seems like a pretty simple issue to work out as long as the alternator can feed the batteries enough current to cover whatever free wheeling/spinning the compressor needs not to be a restriction while cruising. If not, alternator upgrade? This system seems like it could have enough potential to investigate bigger alternator, more batteries, larger compressor etc...
Dodzilla is offline   Reply With Quote
Old 06-30-2013, 05:44 PM   #343
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
It probably could but you'd have to figure out the right speed, which might need to be a variable speed to be efficient.
The other answer as has already been mentioned is a bypass when the compressor is not in use.
Edit:
A centrifugal clutch on the compressor wheel is also a possible solution but again adding to the complexity.
Old 06-30-2013, 05:51 PM   #344
fenton
Happy to report that fuel mileage is not effected. 5.8 liters per 100km which is right what I got before on long hauls with cruise on.
The new motor controller is in that will detect low pressure and pulse the turbo to maintain atmospheric pressure :-)
That will go on the car this week
Sent from my HTC One using Tapatalk 2
fenton is offline   Reply With Quote
Old 06-30-2013, 05:54 PM   #345
Robftss
Drives: VW
'Restriction' requires airflow, and enough that the constriction of the compressor creates a delta P. The throttle plate is a variable constrictor and creates all the restriction of airflow up to a certain point. Once the compressor constriction has enough flow it will create a restriction (delta P). Typically, 0-50% TB there is no P drop across the compressor and therefore no restriction. Above 50%... opening the TB slightly more than normal will maintain airflow. There is no loss @ highway cruising speed. From 50% to on set of boost (~80%), partial activation to maintain stock intake slight vacuum can be signalled by the delta P.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
serialk11r (06-30-2013)
Old 06-30-2013, 08:42 PM   #346
nonicname
Drives: it has 4 wheels and a motor
Im gonna guess that this kit is making more power than innovates SC at sea level. Simply because of the lack of parasitic loss.
Their SC kit is Only running 4.5 psi on stage 1.
nonicname is offline   Reply With Quote
Old 06-30-2013, 09:04 PM   #347
fenton
If we were at sea level we would have 1 more psi across the band.
One psi that lacks parasitic drag equals more than 20hp from our experience.
I mean we made 30 peak HP with 1.3 psi :-) not to mention 90tq with only 3 psi.
Old 06-30-2013, 09:57 PM   #348
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
i really want this kit
brichard0625 is offline   Reply With Quote
Old 07-01-2013, 12:23 AM   #349
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
So at idle your boost gauge shows positive pressure? It should be in vacuum.
Old 07-01-2013, 12:26 AM   #350
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Wrx is fitted with a small turbo stock, a light impeller could produce positive intake pressures even at idle
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
