go_a_way1
Old 04-08-2017, 07:17 PM   #3431
arxm
Drives: 2013 FR-S, 2023 BRZ
whats a good tire size for an 18x8.5 rim I bought it with 275s all around and the fronts rub, i was thinking 245/40's or 245/35 but I'm not too sure, any input?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 04-08-2017, 08:24 PM   #3432
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
245/35/18, perfect dimensions for the twins and fits a 8.5" wheel very well
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
arxm (04-08-2017)
Old 04-08-2017, 10:38 PM   #3433
arxm
perfect thanks a ton!
Old 04-09-2017, 04:01 PM   #3434
Kcyl
Drives: Subaru Brz 2013 LTD
I am a bit confused after using multiple sites trying to get the right rim. Both the wheel directory and tirerack site shows the enkei raijin 18x8 +45 do for the subaru brz. However 1010tires says that it does not fit the subaru brz. Can someone confirm which to be the correct info.
Kcyl is offline   Reply With Quote
Old 04-09-2017, 05:09 PM   #3435
swarb
They fit.
Old 04-09-2017, 06:00 PM   #3436
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I'm currently running 17x9 +35 wheels with 255/40 tires on stock suspension. It fits fine right now but if I run swift spec r lowering springs and try to get about -2.0 up front will I run in to fittement issues?
rcm47 is offline   Reply With Quote
Old 04-09-2017, 06:47 PM   #3437
dsc_pat
Drives: Too fast
Originally Posted by dsc_pat View Post
Ended up buying +35 as camber is a priority. Thanks for the input !
I'll post some pics when everything is all done, as the snow keeps falling up here.
Here we go.
Upper oe crash bolt, lower moog/spc all at max camber, 17x8 +35 on 255/40 RE11. String aligned, rack numbers soon. Non official -1.8.
No rub at max lock, under load (street load i am not a dumb ass) and i doubt anything will ever rub on track. 1st track outing of the season april 30th.
Peace !
dsc_pat is offline   Reply With Quote
Old 04-10-2017, 11:24 PM   #3438
rcm47
rcm47's Avatar
Bump for answers to my question in post #3436
Old 04-11-2017, 12:36 AM   #3439
swarb
It will be very close.
Some report 1.3-1.5 camber fits fine, anymore they needed to add a 3mm spacer.
Every car is slightly different.
I'd tell you to go look in the rpf1 17x9 +35 and see what others experience.
What tires? A street tire should be ok, a 200tw summer tire might be cutting it close.
Swift r's are the lower ones?
Do you feel safe with 3-5mm of clearance? how about 2mm?
The Following User Says Thank You to swarb For This Useful Post:
rcm47 (04-11-2017)
Old 04-11-2017, 02:25 PM   #3440
rcm47
rcm47's Avatar
I'm using hankook rs3s. The spec r is a 1.1 inch drop up front. I've seen some ppl here make it work with -2 camber up front but I would like more conformation. Thanks!
Old 04-11-2017, 04:15 PM   #3441
swarb
http://www.ft86club.com/forums/showthread.php?t=100400
Good luck, post your experience when it happens.
rcm47 (04-11-2017)
Old 04-15-2017, 03:34 AM   #3442
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
WedsSport TC105N
17x9 +35
with Michelin Pilot Super Sport 245/45r17 fit with stock suspension? how about 1" drop?
I just want a slight higher ride height since work speed bumps, and bad roads at killing my bumper and frame. Also fill the wheel well better w/o modifying suspension.
I understand 245/40 fits with stock and with 0.7 - 1.0 inch drops.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 04-15-2017, 04:09 AM   #3443
swarb
Originally Posted by SmartedPanda View Post
WedsSport TC105N
17x9 +35
It'll fit. On bigger bumps/more compression it will be close to the bumper tab.
Scroll down a little to the red frs, it has it on the rear. You should be ok as you won't be as low. I believe that car belongs to Charles, I forgot his screen name and not sure if he is still around.
http://www.modbargains.com/forgestar...-brz-17-in.htm
Old 04-15-2017, 02:04 PM   #3444
SmartedPanda
Yeah, I'm 90% sure it'll fit on the rears, someone with RPF1's fit on the rears w/ stock. I'm more worried about rubbing on the front with 245/45, 245/40 is basically the common fitment for stock and 1" drops.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
