Old 03-13-2014, 07:37 PM   #323
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by GT86FI View Post
My engine was pulled out two weeks ago because of the oil leak issue.
Valve cover gaskets and rear camshaft caps on both sides of the engine were resealed.
This repair can actually be done in the vehicle, strange they would have pulled the engine.
Oil is coming from the seam between camshaft housing and cylinder head.
I've seen a few cam carrier leaks. It does require removing the engine. If they went to the trouble of pulling the engine the first time, they probably should have gone ahead and resealed this. At least it's being taken care under warranty for you.
andrew20195 is offline   Reply With Quote
Old 03-14-2014, 06:30 AM   #324
GT86FI
Drives: GT86
They explained that the engine had to be pulled in order to remove the old liquid gasket properly before resealing.
Anyway, now they have to reseal basically all liquid gasket seams of the engine once more.
GT86FI is offline   Reply With Quote
Old 04-05-2014, 12:55 PM   #325
SasaGT86
Drives: Toyota GT86 Lightning Red MT
I got my camplate resealed and two days later the smell came back. I was driving my car pretty hard to test it. Drove my car back got it resealed again. I've been driving it now for around 1500km and no smell.. Hopefully it's worked this time.
SasaGT86 is offline   Reply With Quote
Old 04-06-2014, 12:56 PM   #326
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Verdict was leaking camshaft housing. Parts just came in, taking her back soon for work.
I sure hope no leaks ever develop outside of warranty. Ah well, about 4.5 years left on the powertrain.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 05-23-2014, 01:48 PM   #327
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
I have the oil smell since the last oil change (~1 month ago). When I went for a drive with my car club, some other drivers mentioned black smoke coming from the tail-pipe. A couple of days ago I checked oil and found that the dealer had overfilled by almost a 1/2 quart. I removed the excess oil and the oil burning smell has decreased significantly but is not totally gone.
355rockit is offline   Reply With Quote
Old 05-23-2014, 02:40 PM   #328
355rockit
FR-S is at the dealer today looking at the oil leak. Oil is dripping onto the garage floor.
Old 10-16-2014, 05:20 PM   #329
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by DSOmegaX View Post
Smelled burnt oil in the cabin twice in two weeks. Took it in. Minor leak from both sides of the valve cover. Replacing both valve cover gaskets. Parts ordered so need to bring it in again in a few days for the actual repair.
I just found a small leak at the back/bottom of my drivers side camshaft cover.
Taking it in to the dealership on Monday. Were your leaks in a similar location??
Old 10-16-2014, 07:10 PM   #330
MmmHamSandwich
Drives: '13 FR-S
Looks similar. My engine was pulled and the cover was totally removed and resealed. Here are the notes...
CAMSHAFT (ALL) ~|~CUSTOMER STATES THERE IS AN OIL BURNING SMELL IN THE CAR PLEASE ADVISE ~|~OIL SEAPAGE FROM PASSENGER SIDE CAM CRADLE DUE TO IMPROPER SILICONE BONDING. ~|~18723 OIL SEAPAGE FROM PASSENGER SIDE CAM CRADLE DUE TO IMPROPER SILICONE BONDING. WTY... FOUND OIL TO BE LEAKING FROM THE PASSENGER SIDE CAM CRADLE WHERE IT MOUNTS TO THE CYLINDER HEAD. EVACUATED FREON FROM THE VEHICLE AND REMOVED ENGINE. REMOVED FRONT E
REPAIR PARTS NUMBER QUANTITY
GT SUPER LLC BLUE 00272GTBC1 3
0W20-SINGLE QUART (W 002790WQTE01 5
GASKET F SU00301111 1
GSKT SU00301110 4
GSKT-SPARK PL PIP SU00300100 2
O RING-39.0X2.0 SU00302190 1
O RING-15.4X1.8 SU00302184 1
GSKT-INT MANIF SU00300290 2
GSKT-FUEL PIPE SU00300347 1
GSKT-ROCKER COVERLH SU00300281 1
GSKT-ROCKER COVERRH SU00300280 1
SEAL-OIL LEVEL SU00300306 1
O RING-12.1X2.5 SU00302183 3
O RING-23.8X2.8 SU00302186 1
OILSEAL-50X62X7 SU00302180 1
THREE BOND FIPG TB1217H 2
OPERATION
CAMSHAFT (ALL)
CAMSHAFT (ALL) ADD: AIR CONDITIONING
PAYMENT
WARRANTY PAY
Says Thank You to
MmmHamSandwich For
This Useful Post:
Old 10-17-2014, 12:12 PM   #331
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Where are those pictures located? It is very hard to tell.
blackfireball5 is offline   Reply With Quote
Old 10-17-2014, 01:27 PM   #332
ATL BRZ
ATL BRZ's Avatar
Mine are pics of the bottom rear of the driver's side camshaft carrier.
The TSB is attached: 02-136-12R - Oil Seepage Diagnosis and Repair Procedures.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
blackfireball5 (10-17-2014), grst1 (10-21-2014), Marrk (10-21-2014)
Old 10-21-2014, 08:26 AM   #333
grst1
grst1's Avatar
Drives: '94 Ford Aspire
Mine has exact same problem (09xx 2013 BRZ). Didn't develop until very recently - car has 36.5K miles. Will be taking it to the dealer.
grst1 is offline   Reply With Quote
Old 11-21-2014, 04:13 PM   #334
Astroboy
Astroboy's Avatar
Drives: None
Oh, that's not good.
Astroboy is offline   Reply With Quote
Old 12-20-2014, 01:39 PM   #335
JCE17
JCE17's Avatar
Drives: 2013 Scion FR-S - Asphalt 6MT
I noticed a couple oil spots in my driveway yesterday and today. Also started noticing a burning oil smell. I am taking the car to the dealer today to see what it is. Hopefully nothing major.
JCE17 is offline   Reply With Quote
Old 12-22-2014, 02:50 PM   #336
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I took my header off over Thanksgiving and found oil in the gasket. It came from the oil seep where many of you have (Driver side on the timing chain cover right behind the cam sensors)
This is a fire hazard
F1point4 is offline   Reply With Quote
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 05:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 04:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 05:43 PM
