02-28-2019, 06:25 PM | #323 |
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
03-01-2019, 08:28 AM | #324 |
Moutain Runner
03-11-2019, 03:52 PM | #325 |
Drives: BRZ 2018
I fitted them in my BRZ MY18 also, smooth side down but along with the lower stoppers you should fit the wider-longer STI subframe bolts.
03-11-2019, 05:46 PM | #326 |
Yes, I used longer bolts. I think that stock bushings are too soft for this mod. I'm planning STi bushing replacement.
03-11-2019, 06:25 PM | #327 |
Drives: BRZ 2018
tS and STI BRZ respectively have same exactly subframe and bushes with us (20152CA000) so there is no reason to change bushes that is a painful procedure!
03-12-2019, 02:02 AM | #328 |
2015 models had different subframe bushings...
03-12-2019, 02:18 AM | #329 |
Drives: BRZ 2018
Same rear subframe part number for MY15 limited with our MY18 cars and the new tS, where did you find those info?
https://parts.subaru.com/a/Subaru_20...10-201-01.html |
03-12-2019, 08:36 AM | #330 |
In the OP. Subaru Parts website has a lot of errors.
03-12-2019, 09:42 AM | #331 |
Drives: BRZ 2018
03-12-2019, 04:15 PM | #332 |
03-12-2019, 05:30 PM | #333 |
Drives: BRZ 2018
03-12-2019, 05:34 PM | #334 |
I think that 2017+ have all the same subframes, but the lower stoppers are made for the 2015 Ts that had stiffer bushings. I tried and didn't work fine for me on my 2018 model. I will switch to stiffer rear bushings as I actually have all the front on TRD and STi bushings...
03-12-2019, 10:21 PM | #335 |
03-13-2019, 09:25 AM | #336 |
Moutain Runner
Just in case people are still on the fence about how ricey the mirror caps are
The Following User Says Thank You to Chuckls For This Useful Post: | yurikaze (03-14-2019) |
Similar Threads | ||||
** TRD JAPAN GT-86 PARTS LIST ** | Carson Toyota | Exterior Parts - The Rest | 222 | 08-28-2014 01:43 PM |
I wish list of parts for my FRS | jflogerzi | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 04-28-2013 10:55 PM |
R Magic Parts List | quik1987 | Engine, Exhaust, Transmission | 9 | 07-30-2012 01:55 PM |
List of all parts you want on your BRZ/86 | StarsGarrador | BRZ First-Gen (2012+) -- General Topics | 72 | 05-22-2012 05:20 PM |
Lexus IS-F parts wish list | aspera | Engine, Exhaust, Transmission | 21 | 08-18-2011 01:59 PM |
