Old 02-28-2019, 06:25 PM   #323
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Chuckls View Post
How are those installed?
Sent from my SM-G960U using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 03-01-2019, 08:28 AM   #324
Chuckls
Moutain Runner
You unclip the original ones...pop the new ones in.
Chuckls is offline   Reply With Quote
Old 03-11-2019, 03:52 PM   #325
JIM THEO
Drives: BRZ 2018
Originally Posted by gpvecchi View Post
Guys, I fitted the lower stoppers, adding them between the bushes and the lower brackets. Now I feel that the rear feels like is moving during hard steering. I noticed that there is one smooth side and one with some texture. Do I have to reverse them?
I fitted them in my BRZ MY18 also, smooth side down but along with the lower stoppers you should fit the wider-longer STI subframe bolts.
JIM THEO is offline   Reply With Quote
Old 03-11-2019, 05:46 PM   #326
gpvecchi
gpvecchi's Avatar
Yes, I used longer bolts. I think that stock bushings are too soft for this mod. I'm planning STi bushing replacement.
Old 03-11-2019, 06:25 PM   #327
JIM THEO
Drives: BRZ 2018
tS and STI BRZ respectively have same exactly subframe and bushes with us (20152CA000) so there is no reason to change bushes that is a painful procedure!
Old 03-12-2019, 02:02 AM   #328
gpvecchi
gpvecchi's Avatar
2015 models had different subframe bushings...
Old 03-12-2019, 02:18 AM   #329
JIM THEO
Drives: BRZ 2018
Same rear subframe part number for MY15 limited with our MY18 cars and the new tS, where did you find those info?
https://parts.subaru.com/a/Subaru_20...10-201-01.html
Old 03-12-2019, 08:36 AM   #330
gpvecchi
gpvecchi's Avatar
In the OP. Subaru Parts website has a lot of errors.
Old 03-12-2019, 09:42 AM   #331
JIM THEO
Drives: BRZ 2018
I don't know about Subaru Parts site but Subaru parts program has no errors:
Old 03-12-2019, 04:15 PM   #332
norcalpb
norcalpb's Avatar
I think gpvecchi is talking about the JDM rear subframe, which includes stiffer bushings.
You are right tho, the 18 usdm ts is more similar to a regular brz than not.
Old 03-12-2019, 05:30 PM   #333
JIM THEO
Drives: BRZ 2018
Correct me if I am wrong but this subframe applies to 12-15 cars only, we both have MY18 cars.
Old 03-12-2019, 05:34 PM   #334
gpvecchi
gpvecchi's Avatar
I think that 2017+ have all the same subframes, but the lower stoppers are made for the 2015 Ts that had stiffer bushings. I tried and didn't work fine for me on my 2018 model. I will switch to stiffer rear bushings as I actually have all the front on TRD and STi bushings...
Old 03-12-2019, 10:21 PM   #335
norcalpb
norcalpb's Avatar
From what I remember, the 12-18 86s have the same rear subframe. Only change was I. The chassis itself.
Old 03-13-2019, 09:25 AM   #336
Chuckls
Moutain Runner
Just in case people are still on the fence about how ricey the mirror caps are
The Following User Says Thank You to Chuckls For This Useful Post:
yurikaze (03-14-2019)
** TRD JAPAN GT-86 PARTS LIST ** Carson Toyota Exterior Parts - The Rest 222 08-28-2014 01:43 PM
I wish list of parts for my FRS jflogerzi Scion FR-S / Toyota 86 GT86 General Forum 19 04-28-2013 10:55 PM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
List of all parts you want on your BRZ/86 StarsGarrador BRZ First-Gen (2012+) — General Topics 72 05-22-2012 05:20 PM
Lexus IS-F parts wish list aspera Engine, Exhaust, Transmission 21 08-18-2011 01:59 PM
