Old 02-11-2014, 12:03 PM   #3333
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by DeliciousTuning View Post
Innovate Supercharger with Intercooler is going on our development car this weekend. So expect to see more improvements in the map in the coming weeks, month, year.
Cheers,
William Knose
And expect to see money coming from me in the coming weeks, month, year. I still need to buy my tune.
Dustin is offline   Reply With Quote
Old 02-11-2014, 12:09 PM   #3334
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Venator View Post
Does anyone have an innovative kit that is inter cooled with a 70mm pulley? If so what numbers does it put down?
I am going to get tuned on saturday. Will report back.
Not sure of the process but probably will be tuned first on 93, then e85 for flex fuel.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Venator (02-12-2014)
Old 02-11-2014, 04:50 PM   #3335
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Area86 View Post
@PrimeMotoring please pm me the price for the flex fuel kit as well. Thanks
Also I got a p0351code for the ignition coil the other day. For those who had the same code did it come back after replacing the coil pack? I already have one ordered just wondering if I need anything else. Thanks
Sent from my DROID RAZR using Tapatalk
We have seen this happen on 2 vehicles so far and it always seems to be the front cylinders which is lucky for us, as you do not need to lift the engine to change the coil packs.
Cheers,
William Knose
Old 02-11-2014, 06:00 PM   #3336
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by xjohnx View Post
odd, my wideband was showing a little lean this morning on my way to work when flooring it (~13.2-13.5). It usually reads right around 12.0-12.3. Hopefully it was just a fluke. I'm going to take it easy on my drive home for lunch and if it's still doing it get some logs fired off to @DeliciousTuning
Make sure you have no vacuum leaks after the MAF sensor. If you do this can cause the lean condition you are seeing. Otherwise send me some logs and I will review them.
Cheers,
William Knose
Still doing it. I've checked everywhere I know of for vacuum leaks (even pulled and reseated the port injectors.). I removed the power harness for the IC fluid pump all together, as well as moving the power harness to a different port injector incase that was the issue, Still no dice.
Hopefully Bill will be able to see something in the logs I sent him.
Old 02-11-2014, 10:44 PM   #3337
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Cheers,
William Knose
Hi Bill,
Have the other coil pack failures been on the intercooler kit?
Mine went 2 months after install and after I hit 250whp.
Be nteresting to keep record of this, with many changing to IC, as I have not seen much reported with the non IC kit. My Toyota dealership advised not to replace under warranty to prevent any investigation into the failure so for $70 I did not want to make a issue and replaced.
Ryan
Ryan86 is offline   Reply With Quote
Old 02-11-2014, 10:46 PM   #3338
Ryan86
Road Warrior
Ryan86's Avatar
What problem you expiriencing.
Old 02-11-2014, 10:49 PM   #3339
Ryan86
Road Warrior
Ryan86's Avatar
Catch can info
After majority of people saying a OCC does nothing and is just a bling in the engine bay,
A mate sent me this, thought worthwhile sharing. Sorry for pic format was sent to me like this.
Old 02-11-2014, 10:50 PM   #3340
Ryan86
Road Warrior
Ryan86's Avatar
Part 2
Old 02-11-2014, 10:59 PM   #3341
xjohnx
Grip>Slip
xjohnx's Avatar
leanness during WOT. in the 14.5:1 neighborhood, so right now it's parked until i can figure out what the deal is. hopefully the answer is in the logs.
Old 02-12-2014, 12:27 AM   #3342
DeliciousTuning
Hi Bill,
Ryan
Ryan,
Actually both pf them have been with intercoolers. I will be putting one on this weekend with an intercooler. We shall see what happens. Usually happens on the front cylinders also.
John,
Looking at your logs now.
Cheers,
William Knose
Old 02-12-2014, 12:41 AM   #3343
choi0706
Drives: t
why not use a long stud, and two nuts? one nut for the blower to manifold.. and the extra to hold the reservoir if you are paranoid the leak is there..
choi0706 is offline   Reply With Quote
Old 02-12-2014, 01:00 AM   #3344
Dustin
Twin Screw You
Dustin's Avatar
Who has relocated their IAT sensor post blower?
Old 02-12-2014, 01:15 AM   #3345
DeliciousTuning
Haven't found a need for them to be honest. The tunes we have work on the OEM MAF sensor. Also when you upgrade to an intercooler, there is almost no need to change the location.
But if you want to you can. Just need to let your tuner know, so they can change the tune accordingly.
Cheers,
William Knose
Old 02-12-2014, 08:13 AM   #3346
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Boxer486 View Post
Ouch! They should be supplying those higher grade bolts with the black oxide finish at a minimum. Thermal change and vibration must be too much.
got a link to one you'd recommend? one of these?
http://www.mcmaster.com/#socket-head-cap-screws/=qnt21g
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
