CANADA Canada
Old 01-05-2014, 11:34 PM   #309
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Was at my old highschool with a friend and his mini cooper S. I was showing him how fun my BRZ was, and I got into his mini and he sliding around and it wasn't as exciting LOL!
Haven't been back to my highschool area for nearly 8 years.
ShibaYuki is offline   Reply With Quote
Old 01-06-2014, 03:25 AM   #310
congee
congee's Avatar
Drives: SSM BRZ
loll got stuck on my buddies driveway this morning from the heavy snow. Rear wheels couldn't get over the packed up snow/ice :'(
congee is offline   Reply With Quote
Old 01-06-2014, 10:42 AM   #311
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by automatic View Post
Oh boy...-24 this morning.
Windows frozen, car cranked slow, clutch pedal sticky, radio not turning on. Fun drive into work.
Originally Posted by 1Cor10:23 View Post
Yeah...sucks when the electronics stop working. My DVR won't turn on half the time now. Kinda defeats the purpose of it all...especially given that accidents occur more often in inclement weather...
As much as I give myself credit for owning and driving this car during the winter, you guys up north take the prize for biggest winter balls. Good luck through the rest of the winter, guys.
And, side note: This makes all the bitching and moaning about single-digit highs (in F) and lows in the negative teens sound like whining.
Originally Posted by congee View Post
Does anyone here garage their brz/frs?
I usually park my car in a non-heated garage but found out today that garaging your car in a heated garage could speed up corrosion. The garage is usually 5-6 degrees above the outside temperature. Should I start parking outside now?
I absolutely garage my car. Previous owners of the house insulated the garage like crazy (even the door is insulated). So once both cars are in there at the end of the day, it can be as much as 20-30 degrees warmer than the outside freezing temps. Can it speed corrosion? Possibly, but the water drains off the cars and dries fairly quickly, if it doesnt refreeze (as it usually does this time of year). But, frankly, having a car I don't have to clear off in the mornings, possibly messing up the paint if I have the wrong type of brush, is worth the increased possibility of rusting.
It has priests in it?
Old 01-06-2014, 10:57 AM   #312
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Garaging a new car doesn't speed up corrosion because the corrosion protection is good. Garaging an older car can result in faster corrosion.
It depends on your locale. Out here a heated garage is mostly dry so garaging even an old car will not speed up corrosion. In the East it may.
One tip is to try and dry out the garage between snowstorms. It doesn't take much re-heating of the garage air to dry out the standing water.
Suberman is offline   Reply With Quote
Old 01-06-2014, 11:53 AM   #313
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I had very little problems driving home last night.
Conversely, the X5 in front of me was fishtailing (I suspect they left the Summers or All-Seasons on, "because 4WD") - until he got behind me, and later ended up sliding into the oncoming lane (thankfully, no cars there) and almost spinning out.
This car has behaved far better than expected so far in the slush and snow - of course, I haven't met any steep icy inclines yet...
daiheadjai is offline   Reply With Quote
Old 01-06-2014, 11:54 AM   #314
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes, steep icy inclines will murder this car, unfortunetly... you'll need a bit of luck and momentum to get out of them
there are a few roads i avoid for this reason when the snow gets really bad.
i'm currently working on an aesthetics friendly trunk weighing option
Old 01-06-2014, 11:55 AM   #315
HunterGreene
Hail Magnet
I specifically avoid inclines in winter when possible
Old 01-06-2014, 12:46 PM   #316
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
As this topic has been discussed earlier in the forum, may I suggest *rice bags*? You put those in the trunk in winter and eat them when you don't need them. Then get new supply next winter. Very economical and environment friendly...
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 01-06-2014, 01:06 PM   #317
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no, i'm thinking of building a 3-or-2-piece enclosure to mimic the trunk floor using plywood and hardwood. Maybe 6-8 inches deep. Filling that with concrete and let settle, cover with plywood, and wrap the whole thing in felt once done.
removable, re-usable for future winters, and retain use of trunk.
Old 01-06-2014, 01:13 PM   #318
HunterGreene
Hail Magnet
I'm assuming you do, but do you know how much concrete ways per cubic foot? A 6-8" slab would bottom out your suspension and likely break an axle. Keep in mind most residential driveways are poured at about 6", sidewalks at 4", and airport runways get a hefty 18" minimum. There's your random fact of the day
Not saying you shoudln't go this route, but be careful!
The Following User Says Thank You to HunterGreene For This Useful Post:
7thgear (01-06-2014)
Old 01-06-2014, 01:16 PM   #319
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
well in that case
1 full foot it is!
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
HunterGreene (01-06-2014), wparsons (01-07-2014)
Old 01-06-2014, 01:28 PM   #320
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i love the "tags" in this thread, haha
Old 01-06-2014, 02:31 PM   #321
daiheadjai
daiheadjai's Avatar
Yeah - generally, in exceptionally bad situations, I plan my route to avoid them like the plague...
The Following User Says Thank You to daiheadjai For This Useful Post:
Old 01-06-2014, 11:38 PM   #322
Suberman
Hey, we don't have no ricers up here, eh?
7thgear rulz, kryptonite allergy, suberman cant drive
winter driving jmaryt Scion FR-S / Toyota 86 GT86 General Forum 88 11-11-2013 12:15 PM
Winter Driving Tip. NOHOME Scion FR-S / Toyota 86 GT86 General Forum 22 03-06-2013 06:38 PM
Practice winter driving 4U-GSE Scion FR-S / Toyota 86 GT86 General Forum 4 01-26-2013 11:29 AM
How many are planning on winter driving? NV Auto CANADA 109 01-11-2013 10:30 PM
winter driving paraguin BRZ First-Gen (2012+) — General Topics 25 08-03-2012 06:26 PM
