Old 11-11-2012, 12:29 AM   #309
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
What width will work on the front for tires?
I'm probably going to run 18x9 all around on street and 17x9 all around for track. I'd like to have a big contact patch, but obviously with coilovers and such I'm worried about rubbing.
I'd like to do 255s or 265s... but will that work up front?
Just wondering what you guys are running and how its affected the car, please leave personal experience
Thanks
seven is offline   Reply With Quote
Old 11-11-2012, 12:33 AM   #310
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
http://chicago.craigslist.org/nwc/pts/3393508106.html
Yum Yum. 5Zigen ProN1 will deff fit.
Double4Free is offline   Reply With Quote
Old 11-11-2012, 12:37 AM   #311
dsgerbc
Drives: BRZ(sold), STI
^At that price, they're probably bent or cracked.
dsgerbc is offline   Reply With Quote
Old 11-11-2012, 12:41 AM   #312
Double4Free
Ashes to ashes.
Gonna check first before i buy ahha. Thinking if they are in good condition, gonna mount my summers on there and winter on stock rims.
Old 11-11-2012, 02:56 AM   #313
Double4Free
Ashes to ashes.
4th rim is cracked beyond hell. Took a look at it. Failure of epic proportions.
It is in change that we find purpose.
Old 11-11-2012, 03:32 AM   #314
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Freed Engineering is running 18x9 +38 with 255/35 all around and it looks very good. I'm running 235/40's and wouldn't want anything narrower, no negative effects from the wider tire in my opinion.
http://www.ft86club.com/forums/showt...ighlight=freed
JoeBoxer is offline   Reply With Quote
Old 11-11-2012, 09:32 AM   #315
gmookher
the answer varies if you're talking about looks or for speed
Hoosier R6 225/45-17 will be my next victim at the track..
gmookher is offline   Reply With Quote
Old 11-12-2012, 01:31 AM   #316
Stance86
Drives: Toyota 86 GTS
18 x 9.5 + 38 on stock suspension
Hi guys,
Has anyone sucessfully ran an 18x9.5 + 38 on lowered springs only?
I am worried after measuring the gap between the strut and the wheel on the stock wheel..
My car is lowered on Eibach Sportline springs only and I just ordered 18x.95 + 38 and I am worried they wont fit without coilovers.
Plan is to run a 245/35 on the front and a 255/35 on the rear..
Stance86 is offline   Reply With Quote
Old 11-12-2012, 02:48 AM   #317
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I think you might have an issue.
I have seen no info about a 9.5 inch rim fitting with out coil overs. But of course that doesn't mean it cant be done.
Check the fitment sticky at the top of the wheels topic.
Good luck.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 11-12-2012, 10:21 AM   #318
JoeBoxer
JoeBoxer's Avatar
I would think it would hit the strut, might need about a 8mm spacer up front.
Old 11-12-2012, 01:05 PM   #319
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
i'm gonna be running an almost identical setup so hopefully someone can answer this! on sportlines as well. i've only read reviews of people fitting 9.5 +38 up front on coils so hopefully stock suspension clears...
gabeg86 is offline   Reply With Quote
Old 11-12-2012, 01:10 PM   #320
ModBargains.com
ModBargains.com's Avatar
You can do it, but you'll need to stretch it out, you wont be able to do wide tires... It's already been done before, check it out here:
Fitted 9.5inch wide rims, on the FRONT.. No rubbing, no guard rolling
If you need any additional help with wheel fitment, or the tire sizes/suspension to get it done, send me a PM/Email or call me up - 714.582.3330 extension 8002, and ask for Jurrian of course
ModBargains.com is offline   Reply With Quote
Old 11-12-2012, 01:47 PM   #321
gabeg86
gabeg86's Avatar
these are on coils tho, not stock struts with lowering springs. i know a guy on the forums fit 18x9.5 +38 rpf1's with 245/35 all around with no fender mods or crazy camber either and no issues, but on coils. the stock sized springs are larger in diameter, and thus may create an issue. i'm no expert on measurements of the stock components, but i have yet to see it done on lowering springs for verification
Old 11-12-2012, 02:20 PM   #322
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Wheel Gurus.. need your help on TE37SLs
Hello,
I have decided to get some TE37SLs (pressed graphite finish) for my car.
I know that for 18's (in 5x100), they come in the following sizes:
18x8.5 +45
18x9.0 +45
18x9.5 +45
I definitely want to maintain a square setup. Also, I feel that 18x9.5 are way too wide for the front (too much poke).
So I guess the question is, should I go with 8.5 width all around or 9.0 width all around?
Tires will probably be a 245/35/18 if I run 9's, or a 225/40/18 if I run 8.5's... not really into that stretched look.
Thanks in advance!
Brian
brianlo622 is offline   Reply With Quote
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
